Go Back   RCCrawler Forums > Miscellaneous > 1:1 Full Size Vehicles
Thread: samurai gearing question
Old 04-07-2015, 09:55 PM   #1
Default samurai gearing question
i have an 86 sammie on 31s with all stock gearing and obviously its a slug. in order to get back some speed would i be better off regearing the diffs or the transfer case? also before anyone says "just drop in a 1.6" i know and i wish
tacocat is offline   Reply With Quote
Old 04-17-2015, 07:27 PM   #2
Default Re: samurai gearing question
I just had a simple 4 to 1 transfer case set and on 31's, it worked really great for trails. The only thing it had trouble with was mud.
diesel kawboy is offline   Reply With Quote
Old 04-18-2015, 11:42 AM   #3
You can regear the diffs to give you better gearing, even compensate for the tire size to get your speedo accurate.
I think the easiest way is to just put a turbo on it, and call it good.
Sarra is offline   Reply With Quote
Old 04-18-2015, 12:44 PM   #4
I have an '89 Samurai with 235/75 tires and went from 3.73 to 4.57 gears. Is still a slug but now the top speed dropped a good amount, the problem with regearing the transfer case is that your low range gets a lot shorter compared to the stock ratio, which sucks in situations you need some speed, like in sand dunes. I would go with 5.38 diff gears if you need some low range speed, or 4.16 transfer gears if you move slow off road
Pabust is offline   Reply With Quote
Old 04-18-2015, 12:49 PM   #5
Moderator
badhoopty's Avatar
diffs are the safest place to gear down. my old zuk had 5:13s or something around there with a 4:1 tcase, which on 31s was great for wheeling but driving on the hwy 55-60 top speed with the motor wound up pretty good.
badhoopty is offline   Reply With Quote
Old 04-18-2015, 10:11 PM   #6
you said before anybody says drop in a 1.6 and you wished.......but curious as to why not go ahead. would be about the same price difference as dropping in R&P and honestly doesnt even take a full day.
lawhorn_derrick is offline   Reply With Quote
Old 04-25-2015, 09:00 PM   #7
Thanks everyone for the input and lawhorn_derrick the only thing holding me back is the lack of knowledge to do it myself. I'm kind of a noob at working on vehicles and don't know anyone who is anymore capable.
Old 04-26-2015, 12:41 AM   #8
Zukiiholic's Avatar
Have you Checked out Zukiworld.com ?
Zukiiholic is offline   Reply With Quote
Old 04-27-2015, 08:44 PM   #9
understand that. like he said check out zukiworld. I've done lots of those swaps and honestly it would be a great project for ya to learn on unless you need it done asap then that might pose a problem.
samurai gearing question - Similar Threads
gearing question mxturd Axial AX10 2nd-gen 5 03-09-2015 07:05 PM
samurai transfer case question tacocat 1:1 Full Size Vehicles 7 12-02-2014 12:30 PM
Gearing question!!!! bradg2009 Axial SCX-10 13 11-29-2012 12:31 AM
Gearing question!!!! bradg2009 Newbie General 4 11-28-2012 11:23 PM
Gearing question, Magic Chit Chat 0 03-10-2008 02:47 PM
