Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.5 Scale Rigs
Thread: heinie_21 is finally building a SAS'd FJ-Cruiser
Old 09-30-2013, 12:05 AM   #121
Default Re: heinie_21 is finally building a SAS'd FJ-Cruiser
TTT
blakeski is offline   Reply With Quote
Old 10-01-2013, 01:36 AM   #122
Wow glad this got put to the top, I just went through all 7 pages and all I can say is wow this rig performs great, I really like the k44's under it they looked great, in the vid was it just me or do the tires seem stiff they look like they are filled with air and offer little flex, but all and all great build
Tontos_Touch is offline   Reply With Quote
Old 07-30-2014, 06:03 PM   #123
heinie_21's Avatar
Default Re: heinie_21 - SAS Toyota FJ Cruiser - "Eff Jay"
Played cars at Lake Powell this week
This thing is still so fun to drive. Although now that I own a 1:1 fj cruiser it makes me want to reduce the tire size and ride height of this rig just a little bit.
Anybody calculated out how big a size 315 tire would be compared to the Nikko fj? @pardonmynoob?
heinie_21 is offline   Reply With Quote
Old 07-30-2014, 06:52 PM   #124
This one belongs in the " is it real?" thread.
315 tire would be easy to calculate dimensions, just need all of the tire size. 315 is 12.4" wide, need the aspect ratio # and wheel size to get the rest of the numbers.
BigSki is offline   Reply With Quote
Old 07-30-2014, 07:03 PM   #125
Default heinie_21 is finally building a SAS'd FJ-Cruiser
What's that in English? 35's? For a 1/10 Nikko, 3.5 inches or there abouts.
pardonmyn00b is offline   Reply With Quote
Old 07-30-2014, 08:03 PM   #126
heinie_21's Avatar
35"s yes. Hahah. But if I remember right the fj cruiser body isn't quite 1/10th. I don't remember what it is. I'll have to compare wheelbase and widths with the real thing. I was hoping you would have already had cause to do that for me ;)
Old 07-31-2014, 04:27 AM   #127
The Nikko body is one of the few "1/10" bodies that is actually 1/10 scale.
Old 07-31-2014, 02:06 PM   #128
I thought that heinie_21 was basing the scale tire off of the 1:1 tire that is 315 mm wide. I still need the whole tire size to do the engrish conversion, then calculate that to a "scale" size tire.
Example: Let's say that the 1:1 tire is a 315/80R/17. I'm just making up a number for this example, I have no idea what size the actual tire is.
The 315 is the cross section in mm, so you divide 315 by 25.4 to get the number in engrish. It is 12.4" ( 25.4mm= 1") then you multiply the width by the aspect ratio number, which in this case is the '80', so you get 9.92" (the aspect ratio means that the sidewall is X % of the width, in this case it's 80% of the 12.4" width). So now you have 1 sidewall that is 9.92" tall. There are 2 sidewalls per tire, so you multiply 9.92" x 2 and you get 19.84". The last number in the size of the tire is the wheel diameter, so now you add that to the sidewall heights. 19.84 + 17 = 36.84", so this hypothetical tire is 12.4" wide by 36.84" tall.
Still with me?? Now that you know the dimensions of the 1:1 tire, you can divide that by whatever scale you are working with. In this case it's 1/10th scale, so you would divide 36.84" by 10 and get 3.68" tall X 1.24" wide by 1.7 wheel. This would give you the dimensions of a scale tire that is the scale version of the 1:1 tire.
Old 07-31-2014, 02:29 PM   #129
To put it simply, he needs a tire between 3.5 and 3.75 inches. We're dealing with tiny trucks, not going to get exact scale dimensions of metric tire sizes. Just not enough options on our end.
Old 07-31-2014, 02:38 PM   #130
heinie_21's Avatar
Maths are hard
heinie_21 is finally building a SAS'd FJ-Cruiser - Similar Threads
Old School SAS'd FJ Cruiser frankenstunk 1.9 Scale Rigs 5 12-23-2012 07:41 PM
Finally Building a 1/6 Scale Rob92k1500 Kyosho Crawlers 19 04-02-2007 09:51 PM
SWEET finally im building a tlt king_crawler Tamiya TLT Crawlers 17 01-27-2007 06:38 AM
Getting to building My Own Hi Lift Finally RPP Hobby 2.2 Scale Rigs 17 12-04-2006 06:13 PM
Building a crawler, finally! trickedoutTLT06 Newbie General 4 08-03-2006 03:47 PM
