Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.5 Scale Rigs
Thread: Nothing to see here...
Old 10-07-2016, 04:54 PM   #1
Default Nothing to see here...
This is by far my favorite build I've started to date. I need to throw a shout out to my buddy GIjoe for my inspiration on this build. We bounce ideas off of each other all the time and my mind never quits he sent me a photo of a model he built years ago
It's totally sparked my inspiration.
And after several Google searches I came up with several ideas
This is the final inspection.
So I scoured ebay for a body and came up with this.
The dimensions are kind of small but I can make do.
Ahhh... a fresh new body. Let's hack it up!
Now let's add some metal
It's taken several attempts to get some of these bends just right.
This cage work should make building the interior much easier, and it's a 2 row metal cage. So it adds some points also.
This motor is larger than I remembered. LOL some adjustments are in order.
Some bouncer styling later and presto!
Now I am gonna pick up a O.G. bruiser frame and see how much "customization" it'll need. This is awesome.
Sent from my SM-G935V using Tapatalk
baconbits is offline   Reply With Quote
Old 10-07-2016, 04:59 PM   #2
Interesting. Nice bar work so far
BadWagon is offline   Reply With Quote
Old 10-07-2016, 07:44 PM   #3
Default Re: Nothing to see here...
That's awesome, looking forward to the finished racer, x2 on the tube work. Is that a McAllister body?
Mike Flea is offline   Reply With Quote
Old 10-08-2016, 07:34 PM   #4
Yes it's a 37 dodge business coupe
Old 10-08-2016, 07:36 PM   #5
It's header / zoomie night in the shop. Let's see exactly how much patience I have. Lol atleast rc4wd drilled and tapped the block for headers... I wonder why they never released any... oh well.
Old 10-08-2016, 07:39 PM   #6
Did you consider moving the motor back?
IMO the motor is too far forward and up to be "scale". I dig the cage work, but the devil is in the details.
DrewHammer is offline   Reply With Quote
Old 10-08-2016, 07:51 PM   #7
The issue is the body is technically 12th scale and this motor I'd say is more 9th scale than 10th... and I don't want the block or oil pan to interfere with the axle placement. Once I get the frame Monday I'll have a better idea how everything will sit. Its just in the beginning on mock up stages and alot of things are subject to change.
Old 10-08-2016, 09:44 PM   #8
Team Blue Groove has a similar body with a 280mm wheelbase and 220 track width for the HPI Super RS4. I think it's a ferd.
Derek Larsen is offline   Reply With Quote
Old 10-09-2016, 08:04 AM   #9
They have alot of cool body's so does McAllister Racing
Old 10-09-2016, 08:18 PM   #10
This original bruiser chassis is way to big...
Nevermind
Old 10-10-2016, 12:50 AM   #11
I guess you could say things have escalated pretty quickly...
Old 10-10-2016, 12:51 AM   #12
I am just procrastinating building the headers for the other side... ugh. . .
Old 10-11-2016, 01:08 AM   #13
This shall be a rather over complex steering setup....
Old 10-11-2016, 02:48 PM   #14
Steering is coming together.
Below is the prototype for the new
scx10 1/2 axles I am building.
I have a special butcher making me some special beef...
Old 10-13-2016, 10:26 AM   #15
I finally stopped procrastinating and built the other header.
Old 10-13-2016, 11:24 AM   #16
Touchdown!!
Looks great bud
Old 10-15-2016, 02:44 PM   #17
Just a little sneek peek the front rims are 1.55 the rears are 1.9 but I felt this build belongs in the 1.55 section
Old 10-15-2016, 07:26 PM   #18
I managed to quick cut heat and bend the frame up and out of the way of the rear tires, tomorrow I'll clean it all up
But I did achieve the tucked look into was trying for.
Old 10-16-2016, 12:02 PM   #19
So it's tomorrow and like promised I cleaned up my rush work from yesterday and managed to fill some holes in the frame along the way.
Next on the punch list is to get the axles build and get the rc4wd R4 transmission and GCM LRT2 transfer case.
Old 10-16-2016, 12:04 PM   #20
Just some size specs so far.
8" wide frome outside tire to outside tire
9 1/2" long wheelbase
