01-02-2018, 11:11 PM | #21 | |
| Re: Chino63's F-150 a tiny tire tiny truck story. Quote:
What’s the final width hub to hub on the front? What output shaft did you use? I’ve got some pics saved now for later. | |
01-04-2018, 05:34 PM | #22 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
| Re: Chino63's F-150 a tiny tire tiny truck story. Using the stock MRC hex, it's 149.5mm the, to hex. The Yeti Jr axle with narrow hexes is 145.5mm. With the wide ones its juast under 155mm. I used GPM swing shafts for the Losi Mini-t.
01-04-2018, 05:52 PM | #23 |
| Re: Chino63's F-150 a tiny tire tiny truck story. That'll be hardly noticeable. Those GPMs looked a lot beefier than the Losi offerings.
01-04-2018, 06:37 PM | #24 |
| Re: Chino63's F-150 a tiny tire tiny truck story. Never saw the Losi ones. I went by the measurement on one of the eBay ads I saw, figured I'd try it. One thing bugging me is the amount of play in the Ti uni. The steel one is much tighter, can't say which will be stronger, probably neither. Lol Rime will tell, I might have to make something for it later, we'll see.
01-05-2018, 09:47 AM | #25 |
Quarry Creeper Join Date: Jan 2005 Location: Seymour, Tn
Can this rear axle with mods be used on the front of a yeti jr.? If so I may be interested in figuring a way to mount one on my yeti jr..
01-05-2018, 04:52 PM | #26 |
| Re: Chino63's F-150 a tiny tire tiny truck story. |
01-05-2018, 07:21 PM | #27 | |
01-06-2018, 01:08 PM | #28 |
These yeti jr. axles- are they using the ar44 ring and pinions or are they completely specific to these axles?
01-06-2018, 02:36 PM | #29 | |
They use a different gear set. Smaller and no pinion stub, uses a dogbone. The stock axle ratio is 2.33. Last edited by chino63; 01-06-2018 at 03:07 PM. | |
01-06-2018, 10:25 PM | #30 |
Thanks for the replies. Got some ideas spinning around in my head. Chino63 I will hopefully be able to get with you in about a month for an axle. Again thanks for the replies Wayne |
01-07-2018, 12:51 AM | #31 |
@chino63, Is that a mini transfer case or you just cut the side tabs off of a 1:10 TCase? |
01-07-2018, 02:39 PM | #32 |
Quarry Creeper Join Date: Jul 2015 Location: Moncton
I love Blackfoot bodied builds, I did one on and MST chassis and it’s been a great rig.
01-07-2018, 04:25 PM | #33 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
01-07-2018, 08:24 PM | #34 | |
Thanks, had a Blackfoot extreme body too but sold it to a friend. Kinda wish I had kept it but at least it will get used now. | |
01-07-2018, 08:42 PM | #35 |
Not too much more progress today. I spent a lot of time trying a few different locations for the battery and a few different sizes. After weighing the rig and checking the weight bias, i kept it simple and stuck it between tbe fromt frame rails as low as possible. So far, the frame weighs in at 6oz. Two more crossmembers, 4 shock mounts and it's done.
01-08-2018, 12:00 AM | #36 |
| Re: Chino63's F-150 a tiny tire tiny truck story. After looking up the GCM it looks like what I got from fleaBay to try in my d90 project. What tranny are you gonna pair with the YJr axles to make it a crawler?
01-08-2018, 09:15 AM | #37 |
| Re: Chino63's F-150 a tiny tire tiny truck story. Unfortunately, the GCM t-case got copied. It's a great little unit that fits in tight spaces. As fror the trans, ill be usi g a Losi MRC transmission. The little 380 motors are happiest in front of alot of gear reduction. I used this same setup in an earlier build with great results.
01-18-2018, 04:50 PM | #38 |
Quarry Creeper Join Date: Jan 2009 Location: pacific north west
This is gonna be sweet, I just picked up an extended cab black foot body and these ideas are great inspiration! Sent from my XT1650 using Tapatalk |
04-10-2018, 06:04 PM | #39 |
Got going on this again. Made some body mounts for this little guy.
04-10-2018, 06:08 PM | #40 |
Chassis and body test fitted and... check. All good! Went back to a traditional trans setup due to space constraints and installed a pair of SDI driveshafts for better scale appearance. Last edited by chino63; 04-10-2018 at 06:18 PM. |
Chino63's F-150 a tiny tire tiny truck story. - Similar Threads | ||||
New2Ascender - big tiny truck built by little little hands | new2rocks | Vaterra Ascender | 72 | 04-06-2018 09:01 AM |
1:87! THIS deserves the term "tiny truck" | fxman | Videos! | 0 | 07-03-2017 04:20 AM |
Gelande 2 FJ40 at Smiggin's Folly Tiny Truck Park for Trucks and Dolls | pardonmyn00b | Scale Videos! | 1 | 03-16-2015 08:55 PM |
Tiny | Bronco | Large Scale Rigs | 30 | 08-11-2007 07:49 PM |
