07-06-2013, 10:36 AM | #21 |
RCC Addict Join Date: Dec 2007 Location: London
| Re: 'Maddogs and Englishmen'
Haven't touched this for a while due to work and started to see a little rust appearing so thought it best to chuck some paint at it. Front Bumper is cut out to fit the Rc4wd Viking Fairlead. CMS mount on one side, Panhard Link Mount on the Other and a Bracket going across for the Servo Winch to hide. |
07-06-2013, 03:02 PM | #22 |
RCC Addict Join Date: Nov 2011 Location: cold state
Ok I'm officially drooling currently. Just amazed again and thinking this is gonna be my favorite. Well done I say!! |
07-06-2013, 03:05 PM | #23 |
| Re: 'Maddogs and Englishmen' |
07-06-2013, 03:38 PM | #24 |
Quarry Creeper Join Date: Jun 2012 Location: Rome, Italy
Why you're Made the cms @ the other part of the chassis panhard mount? Are you sure this will be right and without any bump steer?
07-06-2013, 03:41 PM | #25 |
07-06-2013, 04:02 PM | #26 |
| If you notice, it's a bolt on, not welded. I asked for detail on this and I'm pretty sure a lot of thought process went into this build. I have all the confidence in Dready.
07-06-2013, 04:05 PM | #27 | |
| Re: 'Maddogs and Englishmen' Quote:
A lot of thought yes but I did bolt it on the wrong side by accident I blame the Hot Weather we are having at the moment in England... | |
07-06-2013, 04:12 PM | #28 |
| Or the Cold drafty ones your having as well, not thinking weather. The one that come by the Pint. You deserve it, Cold and not a lot of foam.
07-06-2013, 04:36 PM | #29 |
07-06-2013, 05:17 PM | #30 | |
Roughly 10% of People in the World are Left Handed, what does this have to do with driving on the left well i'll explain. If you are Right Handed this tends to be the hand/arm that you do the most with, it is therefore stronger than the left. I'll continue... Right Arm does the Steering Left Arm does the Shifter, now you cant have a shifter on the left Hand Side of a Car so lets put it in the Middle hang on the Steering Wheel then has to go on the right then. So Steering on Right equals driving on the Left for obvious Overtaking and Safety concerns. Simple. Unless you drive on Dead Straight Roads where steering isn't an issue? You lot can sit on the left!! | |
07-07-2013, 02:13 AM | #31 |
Very nice thought and consideration.... As you can see from the nickname part of my parents are from Seychelles, where we drive on the left, so no problem of both the side.... But I don't Understand why the drive things are not UNIficated.. right or left... Last edited by seychelles; 07-08-2013 at 09:38 AM. |
07-11-2013, 09:17 PM | #32 |
Quarry Creeper Join Date: Oct 2010 Location: LOS ANGELES
Rig is looking great. I'm loving the detail. And if "Dready" is up for it i've got a build i would like to talk to him about. Thanks for sharing and again great build so far.
07-18-2013, 02:06 PM | #33 |
Update time and after lots of headscratching I think I can make the Roof and Doors Removeable in One Piece more of that later. Rear Bed's been started That slides over this piece and will bolt with Scale Bolts. The Removeable arches will tie all the sides in. Attached all 4 doors are tied together at the top And also got the Roof Pretty much straight And that gets stuck to the other piece, Started to cut the windows out and we're finally making progress on this build. |
07-18-2013, 02:50 PM | #34 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
Craziness..... Sir do you wear cotton gloves while you work - I don't see any finger prints on all that WHITE..... |
07-18-2013, 03:58 PM | #35 |
07-18-2013, 04:21 PM | #36 |
Wow! Between this and your 4-runner, you've been super busy It's turning out very slick, making it to my liking. Your ideas are brilliant and thank you for sharing. Very pleased with the whole build so far. Thanks again |
07-18-2013, 04:23 PM | #37 | |
07-20-2013, 02:00 PM | #38 |
Another update from Dready. I am so pleased and excited how this is turning out. The detail that is going into this is top notch!! More to come |
07-20-2013, 02:04 PM | #39 |
| Hope you like, cause I know I do! |
07-20-2013, 02:43 PM | #40 |
RCC Addict Join Date: Sep 2011 Location: Peoria, AZ
Me like it a lot Maddog, that is turning out sweet. Awesome job on that rig dready... |
