06-11-2014, 10:25 AM | #21 | |
Rock Stacker Join Date: Feb 2012 Location: Massachusetts
Thanks! I had to three link the front axle to prevent the steering servo from moving the frame instead of the tires... I also tested the Jeep outside, it's a fun Jeep to drive! Sent from my iPod touch using Tapatalk | |
06-24-2014, 12:43 PM | #22 |
| Re: Stretched and Comp Cut Jeep JK 2dr. Build
My Jeep is ready for some night driving! Besides the head and tail lights, I installed a 6" and 2" Rigid Industries light bars made by Vanquish Products. The 2" bar mount a throught the grille and the 6" uses the Vanquish Poison Spyder mounts. Both light bars are powered by a 1000mah 3s lipo. Here's some pictures: I also made a floor for my garage... Thanks for following! |
07-15-2014, 01:55 PM | #23 |
100mm King shocks have replaced the stock 90mm Axial shocks. The suspension has been adjusted so that the body is a lot lower than it was before! The hood has been hinged and the grille will be glued to the hood for easier access. I added an RC4WD Warn winch controller since I can't use my third channel. I will be adding a new stronger bumper for winch use. Electronics: I chose to use a Castle Creations SV3 because I liked how it worked in my TF2. I'm using a Hitec metal gear servo for steering. An RC4WD rebuildable 35t motor is under the hood, literally. The head and tail lights are powered through an Axial simple led controller, while the Rigid light bars are powered directly from a 3s lipo. The Warn winch controller is powered by a 2s lipo. Ride height before: Ride height after: Thanks for following! |
12-10-2014, 02:28 PM | #24 |
Quarry Creeper Join Date: Sep 2012 Location: Connecticut, USA
HaHaHaHaHa!!! When i saw your first picture in the thread, at first glance I thought it was an RC!! My first thought was "whaaaat?!? Where did he get that soft top?" These scale builds are getting too good! Nice work on yours!
Stretched and Comp Cut Jeep JK 2dr. Build - Similar Threads | ||||
Gerry´s stretched 2dr JK - Red Hornet | Gerry | 1.9 Scale Rigs | 33 | 02-15-2014 09:21 AM |
Blade chassis comp cut jeep wrangler scaler | xd3athstalk3rx | Micro Scale Rigs | 33 | 06-08-2013 12:08 PM |
Proline Jeep JK 2dr | wxgs333 | Axial SCX-10 | 21 | 04-18-2011 09:38 PM |
Need pics of Comp cut Jeep Rubicon bodies.. | Muddinguy | Newbie General | 10 | 05-21-2006 10:45 PM |
