12-23-2014, 09:13 PM | #21 |
Rock Crawler Join Date: Aug 2013 Location: Central Coast
| Re: Crawl Space's SFXJ - unlimited budget quick build!! PICS ADDED
The interior fits really well inside the body and on the chassis. I'll probably have to cut part of the dash/floorboard I t the center to clear the driveline and lower the body and COG but it should be pretty straight forward. Here's a pic I snapped before leaving home of the panhard/drag link in the "magic parallelogram" |
12-29-2014, 03:45 PM | #22 |
Ok, back in town! Ready to make some progress on this build! Put a RR steel idler gear in the dinky split skid for a full metal tranny! Also mocked up the body and decided I am going to cut off the rear seats in order to get everything mounted as low as possible. As you can see it sits kinda high in the pic. |
12-29-2014, 04:09 PM | #23 |
Nice build! Is the pan hard axle bracket a VP part? I couldn't tell from the parts list. |
12-30-2014, 01:07 AM | #24 |
Thank you sir! Yes, both the axle panhard mount and servo/chassis panhard mount are from VP. (updated the parts list, thanks!) I am still trying to eliminate all the bump-steer from the setup - I believe it may be caused the up/down swing of the 8* knuckles since they do not remain parallel to the servo horn throughout the steering cycle. I might steal the 0* knucks/chubs from my bronco to test this hypothesis. More updates coming soon! Last edited by Crawl Space; 12-30-2014 at 01:10 AM. |
01-04-2015, 12:14 AM | #25 |
Put the knife to the body finally! Also sawed the back seats off and dremeled the center console for driveshaft & transfer case clearance. Gonna keep the COG nice and low |
01-05-2015, 04:14 PM | #26 |
| Re: Crawl Space's SFXJ - unlimited budget build!! PICS ADDED
Got the homemade servo winch mounted - it's a perfect fit! It seems everything will tuck away neatly in the front of the truck. See pics below. Also masked up the body for paint tomorrow. Last edited by Crawl Space; 01-05-2015 at 04:46 PM. |
01-05-2015, 05:53 PM | #27 |
Rock Crawler Join Date: Nov 2011 Location: Asheville
Looking good, just made a winch out of the same servo for my brat build. What servo mounts are you using?
01-06-2015, 12:32 PM | #28 | |
| Re: Crawl Space's SFXJ - unlimited budget build!! PICS ADDED Quote:
I just used an axial aluminum spacer + 1 m3 washer to get the same offset (through the shock hoop hole) as the plastic axial chassis brace. You have a brat build thread? The D772 is wearing a Mad Dog RC 23t winch spool. That servo will break stuff on 3s - hope you have good winch line I'll be using the Hey OK 4amp fused relay controller with the R2104GF. The S-FHSS receivers are great with Hey OK winch controllers because if your radio dies or gets turned off, the winch won't auto-retract (if you have the fail-safe set for that channel). I'm hoping to paint the body today if it gets warm enough to lay down a few coats! However, I'm debating whether or not to trim the fenders more BEFORE painting since I know they interfere with the growlers. I want to give them a chance to work but want to minimize the amount of trimming after paint. Suggestions?!? | |
01-06-2015, 05:16 PM | #29 |
It's happening... |
01-06-2015, 05:39 PM | #30 |
Here's a link to my brat build My Subaru "WRAT" I wouldn't worry about trimming the fenders after you paint. You can always use a sanding drum on a dremel on low speed to smooth things out |
01-07-2015, 02:25 AM | #31 |
Oh, I brought the dremel out Waiting for a flat black coat... Wrat build looks like a sweet C3 |
01-07-2015, 02:54 PM | #32 |
Pebble Pounder Join Date: Aug 2014 Location: Middle
gonna be so sweet chevy's gonna need a facelift! |
01-07-2015, 03:11 PM | #33 |
Gotta get the metal shop goin' |
01-11-2015, 08:43 PM | #34 |
Spent too much time lookin' at this rig - had to do a shakedown run All I can say is wow - it's a total BLAST to drive and I can't wait to finish it |
01-14-2015, 03:56 PM | #35 |
Dremelition man |
01-16-2015, 09:58 AM | #36 |
I joined the Band! Join Date: May 2009 Location: lake county ,florida
Looking good, I have to ask why did you cut the rear out of the interior?
01-16-2015, 01:38 PM | #37 |
Thanks! I separated the seat rows and shaved off some material to shorten the gap between the front and rear seats. As it was, the shock hoops came up through the inside of the rear seats. Now the seats will clear the front of the hoops, I just have to make cutouts in the cargo area for the hoops and goo or glue the two parts back together again.
01-16-2015, 04:43 PM | #38 |
Pebble Pounder Join Date: Apr 2013 Location: traverse
Very nice, I bought a set of 2.2 methods (silver black rings) but dig the heck out of your orange ones. My lhs has a big vp order coming in next week, I hope a set of 1.9" orange and black methods like yours come in, I'll be walking out with them. I'm running 1.9" revolvers right now, just took the growlers off and put my new rock beasts on. Haven't had a chance to give them a go yet. At first I thought the smaller diameter would look less attractive but once you look a bit their quit pleasing the the eye. |
01-17-2015, 12:37 PM | #39 |
Thanks, your XJ looks sweet! I love the methods, which were a breeze to mount the growlers and CI foams to. I lucked out in that they were the ONLY colored methods available with black rings on rpp's site at the time. Just checked and they're all sold out at the moment. Lemme know what you end up with |
01-21-2015, 08:38 PM | #40 |
Been lagging a little on this since I'm actually in the process of getting a 1:1. Got the window masks off so I can see where things line up with the interior. |
Tags |
cherokee, class 2, crawl space, scx10, sorcca |
Crawl Space's SFXJ - unlimited budget quick build!! PICS ADDED - Similar Threads | ||||
Crawl Space's Isuzu Amigo Class 1 build (STRC) | Crawl Space | 1.9 Scale Rigs | 88 | 01-28-2017 12:34 PM |
Project Venom: Crawl Space's Wraith Poison Spyder Build | Crawl Space | Axial Wraith | 92 | 12-10-2014 08:32 AM |
Touring cars... budget and unlimited budget | jetboat | Chit Chat | 22 | 10-28-2013 06:27 AM |
new Rubicon unlimited kit budget build ?s | bigred22 | Axial SCX-10 | 16 | 03-06-2013 12:23 PM |
