Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: 59 ford f100
Old 03-19-2015, 06:11 PM   #1
Default 59 ford f100
Started on the chassis and interior with bench seats and dash.
Silverado1 is offline   Reply With Quote
Old 03-19-2015, 10:38 PM   #2
Zukiiholic's Avatar
Default Re: 59 ford f100
Awesome Scratch building skills.. :O
Zukiiholic is offline   Reply With Quote
Old 03-22-2015, 12:37 PM   #3
Working on interior roll bar, skid plate, steering stabilizer,primed the dash,seats and body.If anybody is interested in how I did the stabilizer let me know.
Old 03-22-2015, 12:56 PM   #4
Just lov'n the fab work and the build! Sean, I do have a question, your body lines, what tool do you use? I've been using a scribing tool, very rigid and sharp, but my lines don't turn out as defined as yours.
joe122 is offline   Reply With Quote
Old 03-22-2015, 01:23 PM   #5
[QUOTE=joe122;5181843]Just lov'n the fab work and the build! Sean, I do have a question, your body lines, what tool do you use? I've been using a scribing tool, very rigid and sharp, but my lines don't turn out as defined as yours.[/QUOTE
First I make the body out of .100 styrene then I cut a piece of styrene 0.20 as a e.g. door panel and glue it over top of the body and do this with each body panel after that and leave a hair gap between them to resemble panels. This also serves to cover up imperfections in your main body build. In other words I'm making a skin for each body panel. Around the curved areas the 0.20 bends real easily. Hope this makes sense let me know I can always send a picture if needed
Old 03-22-2015, 02:24 PM   #6
Genius! I did this with my M715 for the body lines but didn't think to stop and start them where door jambs would be. Very good idea. Thanks Sean. I'll have to live with scribe lines on this one.....but there's always next time.
Old 03-26-2015, 06:11 PM   #7
Finished my running boards and front & rear bumpers out of 16 gauge steel.
Old 03-28-2015, 06:36 PM   #8
Cut and fitted windshield, made a push bar and handles and door mirrors.
Drew a template out of cardboard
Traced the cut out on a sheet of clear acrylic
Curved the acrylic with a heat gun
Glued an edging of 1/2 round styrene to the outside edge to resemble moulding
Did the final fit with the file
Carved rear view mirror and door handles
Cut a groove in the bottom of my push bar in 16 ga steel wide enough for a 3mm threaded rod
Braised the threaded rod
Attached push bar to bumper
Old 04-01-2015, 07:13 PM   #9
Attachment 313824
Attachment 313825
Attachment 313826
Attachment 313827
Attachment 313828
Attachment 313829
Attachment 313830
Attachment 313831
Attachment 313832
Attachment 313833
Attachment 313835
Attachment 313836
I sprayed the body with silver paint, once dry I put glazing putty to fill all the minor imperfection then wet sand with 400#. I use silver paint because it show all the flaws so I can fill and sand. Before I put on my final color.
I put on a final coat of silver to ensure that there is no other marks left before I put on my final color. It is easier to cover up if you are using a lighter paint then the black primer.
Would anybody be interested in having a body built? I haven't decided if I want to do it but would there be any interest?
Old 04-19-2015, 04:02 PM   #10
Finally finished my truck less a windshield which I broke trying to install. OUCH that really sucked!!!!!
Old 04-19-2015, 06:15 PM   #11
Oh just watched GCM video with you and your rigs. Wow. Glad your here to share your creations of artwork. Amazing job! You say you have 70 or so, that will give us plenty of popcorn time. Can't wait to see your next!
Maddog Madigan is offline   Reply With Quote
Old 04-19-2015, 08:16 PM   #12
now those front and rear bumpers and that push bar are something i would pay money for if it was made to fit a scx10
roughneck is offline   Reply With Quote
59 ford f100 - Similar Threads
'66 Ford F100 Wroncho Build joe122 1.9 Scale Rigs 42 06-01-2015 08:28 PM
59 ford f100 Silverado1 1.9 Scale Rigs 7 03-13-2015 07:24 PM
Ford f100 kalifkid Non Crawler RC's 13 03-27-2014 02:31 PM
SCX10 - Ford F100 Truggy mxracer33x Axial SCX-10 6 12-21-2010 12:22 AM
