03-23-2015, 06:02 PM | #21 |
Rock Crawler Join Date: Nov 2011 Location: Kamloops
| Re: Fj40 on narrowed wraith axles chop chop |
03-24-2015, 06:06 PM | #22 |
03-24-2015, 08:41 PM | #23 |
Pebble Pounder Join Date: Feb 2008 Location: Mid Mississippi
Man I'm digging it! Can't wait to see how this turns out...
03-24-2015, 10:23 PM | #24 |
03-25-2015, 01:38 AM | #25 |
Tonight I started in on the rear shock positioning and welded in the starting bar just to see how the chassis will sit with the 110 kings out back. Rig is looking more and more like an ultra 4 rig . What I did notice is that the rear shocks carry a lot of the rigs weight because the front shocks are mount farther forward on the axle and chassis . I will have to test this out soon here is a few more pics |
03-25-2015, 03:41 PM | #26 |
03-25-2015, 06:18 PM | #27 |
03-25-2015, 07:25 PM | #28 |
Awesome work! Maybe some stiffer springs would help support the rear shocks. If needed that is.
03-25-2015, 08:08 PM | #29 |
03-27-2015, 11:33 PM | #30 |
last couple days I haven't worked much on this project. Got a piece of metal in the eye from the bench grinder under my safety glasses so I'm one eye ballin the work now lol. Built front shock hoop braces and started on the rear lower section on the back and built the mount to hold the sway . This is where it started from |
03-28-2015, 06:10 PM | #31 |
03-28-2015, 06:30 PM | #32 |
Pebble Pounder Join Date: Jun 2012 Location: las cruces
Man thats a sweet ride man can't wait to see it done
03-28-2015, 06:47 PM | #33 |
RCC Addict Join Date: Aug 2007 Location: Seattle
You almost have room for a firewall mount. Have you seen the venom 2100mah 3s flight packs? They're super cheap and the smallest 2100mah pack I've seen. http://www.amazon.com/Venom-2100mAh-.../dp/B004UZD4Q8 |
03-28-2015, 08:50 PM | #34 | |
| Re: Fj40 on narrowed wraith axles chop chop Thanks, it Looking better and better every day. Quote:
Thanks for the comments gentlemen | |
03-30-2015, 08:38 PM | #35 |
So today was able to get A little battery tray made up from 1/8 Rod it sits above the motor and extends into the cab. I will be adding some 3mm nuts to all the interior areas for the styrene panels and areas to mount the seats To. Started hitting the welds with a file Getting close to making an interior |
03-31-2015, 12:14 AM | #36 |
Rock Stacker Join Date: Apr 2009 Location: Round Lake
Looking sweet,,, great way to solve the battery problem.... Keep it up!!!
04-01-2015, 09:50 PM | #37 |
04-01-2015, 10:03 PM | #38 |
Finished the nuts for the interior and started on making the floor pans and made a little seat rack That bolts into the floor pan looks pretty good This first one is the for the back where the ess-one will go with the speaker pointing down . I will cover the ess-one with a styrene fuel cell and tool box for camping and such . Last edited by Rodamis; 04-02-2015 at 01:37 AM. |
04-02-2015, 02:41 PM | #39 |
04-03-2015, 02:46 AM | #40 |
Finished the rear axle up and assembled and ready for abuse. Bolted the axles in and loaded the chassis up . There are a few bars to go in. Still not sure if I am going to do any tubes across the open door area yet . I kind of like the open doors . Any comments on the door area would be appreciated. Tell me your thoughts . |
Fj40 on narrowed wraith axles chop chop - Similar Threads | ||||
"Rap Chop" featuring Vince from ShamWOW (Slap Chop remix) | wrx-n-ktm | Chit Chat | 5 | 04-29-2009 08:40 AM |
CC-01 chop | marmech | 1.9 Scale Rigs | 2 | 01-22-2009 08:46 PM |
