04-16-2015, 11:05 AM | #1 |
Rock Stacker Join Date: Feb 2013 Location: Newfoundland Canada
| Xr currie tube/axle issue.
Bought these for my 1.9 Mz U4 build so figured this would be the best place to post.. Having issues with finding a hex that will seat correctly on the Vanquish Rear Xr shafts. It seems the hex(axial) will not completly sit on the pin it only goes half ways over. i tried drilling out a spare hex I had and same issue persisted. i've since contacted Vp about this with pictures so waiting on a response. Just figured i'd see if anyone else was having the same issue as I have encountered. |
04-16-2015, 05:23 PM | #2 |
Rock Crawler Join Date: Nov 2011 Location: Kamloops
| Re: Xr currie tube/axle issue.
Pictures tell all . Does the hex pin itself sit flush in the hex . If it does then you might need to drill the center whole out a bit .
04-16-2015, 07:22 PM | #3 |
| Re: Xr currie tube/axle issue. Having some issues with my note 4 focusing. But you can see here that the hex will not go all the way over the pin. I tried drilling out one hex slightly and the issue still persists. |
04-16-2015, 09:11 PM | #4 |
OK so when the hex is removed and you take the pin and drop it into its slot does it insert all the way or half way ?
04-17-2015, 10:08 AM | #5 |
| Re: Xr currie tube/axle issue. The pin fits the hex fine. The little ridge just above the pin hole is what it seems the hex is catching on. |
Xr currie tube/axle issue. - Similar Threads | ||||
Currie centered axle issue | R6MAXX | Axial Wraith | 15 | 04-08-2015 08:17 AM |
Currie Axle for XL | busa1320 | Axial Yeti XL | 4 | 03-01-2015 12:07 PM |
vp currie axle | bigboy25 | General Scale Talk | 0 | 01-11-2014 10:25 AM |
VP Currie Rock-Jock rear swaybar issue. | LucasAutomotive | Axial Wraith | 2 | 09-05-2013 03:32 PM |
