05-15-2015, 07:55 AM | #21 |
Rock Crawler Join Date: Feb 2014 Location: ?
| Re: Mighty FC-ish
That was fun to watch. Sometimes the front springs look a little soft, but when you are on the rocks they look about right.
05-15-2015, 09:58 AM | #22 |
Quarry Creeper Join Date: Mar 2012 Location: I can see Canada from my house!
| Re: Mighty FC-ish |
05-15-2015, 02:13 PM | #23 |
| Re: Mighty FC-ish
This is officially a great day: |
05-15-2015, 05:40 PM | #24 |
| Re: Mighty FC-ish
UPDATE: I am a HUGE dummy. Out driving around in the woods and on the rocks today with the kid and found myself struggling in places where I shouldn't have been. Then when we went to get the mail and I was driving on blacktop I noticed the steering kinda sucked and tires were folding pretty hard in the back. Then it hit me. I put an overdrive gearset in the back. I had an overdrive set aside for my C3 build (that starts when this and my F250 are both done) in the same parts bin as the underdrive I meant to go in this and I installed the wrong one. I just watched the video again and it's really obvious now. Probably going to have to go run the same lines again just to compare. Dummy: |
05-17-2015, 12:40 AM | #25 | |
| Re: Mighty FC-ish Quote:
Takes some crazy ingenuity to reuse chopped or broken parts of a repairable New Bright JK hardbody in a whole new direction! Last edited by alexchen86; 05-17-2015 at 12:42 AM. | |
05-17-2015, 12:45 AM | #26 | |
05-17-2015, 07:44 AM | #27 |
| Re: Mighty FC-ish That's pretty much how it happened. My time to work on these projects is mostly limited to at night after the wife and kid are out. At least I figured it out now and not 3-4 months from now when I'm actually going to need the overdrive.
05-17-2015, 08:18 AM | #28 |
RCC Addict Join Date: Apr 2015 Location: New Brunswick,Canada
| Re: Mighty FC-ish
Was wondering about the cage.Do you make templates patterns before you start cutting up to make the real cage for the your rig.... Great job keep up the good work.. |
05-17-2015, 08:22 AM | #29 |
| Re: Mighty FC-ish
Glad you got that solved! Love your FC. |
05-17-2015, 08:33 AM | #30 |
| Re: Mighty FC-ish I drew up the area where the cage meets the frame back to the tire carrier to make sure I had the clearances I wanted, but other than that I just winged it. I start adding tube where I think it belongs and make notes as ideas come to me. It's already better than what i had in my head when I started, but driving it over the last few days has really given me a clearer picture of where I want to go with it and the changes I need to make when I tear it down again (very soon!).
05-19-2015, 09:00 PM | #31 |
| Re: Mighty FC-ish
Quick little run around the yard, playback at a mix of 1/4, 1/2, and full speed. Gears are the way I intended now and it's noticeable in the way it drives, better low speed, tighter turning, and far superior climbing. Surprisingly enough it's not near as good at speed on the gravel driveway, lower top end (obviously) and far more prone to tipping in the corners, but that's not what it's built for so who cares? I moved the battery to the right side of the transmission doghouse and it seems to help with twist a little. Built a little battery box today that'll get welded in there, I think it won't be hard to disguise and batteries should be quick and easy to swap. With the winch on the bench I'm really itching to tear it all apart again, controller isn't too far out so I'm going to move on to prepping the interior next and by the time that's done I should be all set to put everything in. TO PROGRESS! Edit - I forgot to add that I also broke down and got some CI foams on the way, should be here tomorrow. Last edited by forty2; 05-19-2015 at 09:11 PM. |
05-21-2015, 08:36 PM | #32 |
Pebble Pounder Join Date: Feb 2013 Location: Montana
| Re: Mighty FC-ish
I accidentally switched the over and underdrive gears in my wraith. It just did wheelies and backflips on inclines. Much easier to notice, especially compared to over and standard drive.
05-22-2015, 09:17 AM | #33 |
| Re: Mighty FC-ish
Same day as my CI foams showing up this guy found his way to the shop looking to drive for me. I told him he seemed a little too gung ho for the low key way I run my shop, he proceeded to break down my tires. I gotta hand it to him though, he is a pretty hard worker... ...when he actually works... ...but way too prone to screwing around methinks. He's all "I'VE GOT GREAT ARTICULATION!" And I reply "Sure, but your head is jammed sideways against the roof when you climb in the truck, it's just not going to work out." Aww crap, where the hell is he now? "EYE OF THE TIGER!" Well damn, you gotta admire his enthusiasm... Anyway, final tear down has begun in earnest, only part I'm waiting on is winch controller and by the time it shows I should be ready for final assembly. Now if I can only find a terrier to ride shotgun. Last edited by forty2; 05-22-2015 at 03:24 PM. |
05-22-2015, 09:28 AM | #34 |
Quarry Creeper Join Date: Apr 2012 Location: Toronto
| Re: Mighty FC-ish
LOL, that made me snort a bit :P
05-22-2015, 09:49 AM | #35 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
| Re: Mighty FC-ish
Stay classy RCC! |
05-22-2015, 01:12 PM | #36 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
| Re: Mighty FC-ish |
05-22-2015, 05:47 PM | #37 |
| Re: Mighty FC-ish
I need to do a scale garage lol! You boys have waaaay too much fun. What's next? Old school stop action with Ron giving some obnoxious poses? Lol....
05-22-2015, 06:25 PM | #38 |
| Re: Mighty FC-ish
Luv the build! It's original and hand built, you don't much of that going on any more. Different topic, but do you still have the back half of that SCX-10 chassis? |
05-22-2015, 07:27 PM | #39 | |
I know for certain one side is still floating around because I saw it last night in my scrap metal pile, it's not outside the realm of possibility I chucked the other though. If I can find the other do you want them? | |
05-24-2015, 03:14 AM | #40 |
| Re: Mighty FC-ish
That takes crazy patience, skills and trial and error to get the fit just right along all the panels! But once it's done it hurts to see it destroyed! Sent from my iPad using Tapatalk |
Mighty FC-ish - Similar Threads | ||||
The mighty CC01 | shenlonco | Scale Videos! | 0 | 10-03-2012 04:32 PM |
Mighty FC | xxgg | Scale Videos! | 3 | 05-19-2012 11:59 PM |
TTC-ish Scale-ish Budget-ish Wroncho-ish Build | Meatwad | Axial SCX-10 | 77 | 01-19-2012 03:00 PM |
Mighty Max(x) | Mechanicalbob | General Crawlers | 9 | 02-21-2007 12:30 PM |
