01-12-2016, 07:37 PM | #1 |
Newbie Join Date: Dec 2015 Location: McKeesport
| X-Trail build update, bumper mounting ideas needed!
Here's some current pics of my '92 Cherokee build on the X-Trail chassis. The new wheels came in Monday so I finally got to mount the 1.9's. (Don't mind the failed tire paint, that'll be coming off) They are GMade Sr02's wrapped in RC4WD Tomahawks. Great wheels, nice and heavy, good quality, and great looking imo. I also opted to get the GMade wheel bolt/center caps to finish off the look. I also wanted to bring up the topic of bumper mounting. I'm looking to get the wide set of the Pro-Line Ridge-Line bumpers and was curious if anyone could point me in the right direction? I've read SCX10 mounts don't work, width is different and they utilize the Axial's c-channel frame. I spotted some "universal" mounts off of RC4WD, anyone used these? If all else fails I don't mind fabbing something custom, but I could use some ideas. |
01-13-2016, 10:50 PM | #2 |
| Re: X-Trail build update, bumper mounting ideas needed!
Did a little bit of fine tuning today, measured up some limiting straps for the rear axle to mellow out the intense flex to match the front, also switched over to vertical posts and properly mounted the body. Still need some ideas for bumper mounts.. |
01-14-2016, 11:06 AM | #3 |
Quarry Creeper Join Date: Apr 2012 Location: Toronto
I had to build my own. I used the metal covers off the back of a PC where the video card goes. Cut those down to about a quarter inch by an inch and drilled holes. Once mounted I brazed on a bumper to that. If you search "bronco TLT" you can see how I did it. You could probably mount an RC4wd bumper to it between the chassis rails and use some spacers. Spacers are so key in scale builds. Sent from my MotoG3 using Tapatalk |
01-14-2016, 11:08 AM | #4 |
PS: try an SCX10 skid plate, you can triangulate your lower links. Sent from my MotoG3 using Tapatalk |
01-18-2016, 04:12 PM | #5 |
Newbie Join Date: May 2008 Location: Birmingham, AL
| Re: X-Trail build update, bumper mounting ideas needed! Here are some bumpers I got from RC4WD. When I had the AX10 skid plate I had to use spacers to mount them in between the frame rails. When I started a rebuild and changed over to an SCX10 skid plate the bumpers mounted directly to the frame. Then, I replaced the SCX10 Skid plate with a Dinky rc split skid transfer case and the bumpers still mount up directly. Although the GR7 motor mount needed a spacer to mount to the frame rails. Sent from my SAMSUNG-SM-G850A using Tapatalk |
X-Trail build update, bumper mounting ideas needed! - Similar Threads | ||||
week 2 update on trail trekker build | tbh2014 | Losi Micro-Rock Crawler | 0 | 08-09-2013 02:53 AM |
Week 1 : trail trekker build update | tbh2014 | Losi Micro-Rock Crawler | 0 | 07-28-2013 07:01 PM |
Winch mounting ideas for front bumper | P-diddy28 | Axial Wraith | 3 | 01-23-2013 08:02 AM |
Ideas on Mounting Front Bumper/Bull Bar?? | alexchen86 | Tamiya XC/CC01 | 5 | 03-15-2012 06:46 AM |
Ideas needed for mounting body | MOCRAWLER | General Scale Talk | 23 | 10-04-2007 10:14 PM |
