07-03-2017, 05:04 AM | #1 |
Rock Stacker Join Date: Jul 2014 Location: Hollis
| Droop shocks advice needed
Hi, When running a droop setup, should I go with a slightly longer shock? For example, I measured a height of 100mm, should I go to 110 with a droop setup? Thanks Scottn |
07-07-2017, 09:31 PM | #2 |
Newbie Join Date: Jul 2017 Location: san antonio
| Re: Droop shocks advice needed
Ya typically I see guys go with at least a 110 for a full droop, just depends on the height you want. even seen up to 130mm
Droop shocks advice needed - Similar Threads | ||||
Need advice on shocks, springs, and droop kits. | GTSLOW | General Crawlers | 3 | 02-08-2016 09:50 AM |
If you had to do it all over again... Advice Needed! | ericinMD | Axial AX-10 Scorpion | 21 | 02-23-2010 09:52 PM |
droop suspension = exactly what i needed | freakos | Videos! | 3 | 05-27-2008 05:23 PM |
Droop shock setups advice. | Jamus | Newbie General | 9 | 12-22-2007 07:39 PM |
