Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: Soze's HoBao DC1 Kit Build
Old 04-18-2018, 12:08 PM   #21
Default Re: Soze's HoBao DC1 Kit Build
Originally Posted by JatoTheRipper View Post
Last week I ordered over $400 in stuff from Tower and it got here in 3 days. So I think they are back to normal with some stuff.
The shocks on this also look great. Hopefully they're as smooth and leak free as they look.
I'm also interested to see the axles. So far the chassis is really cool.
That's good to hear (Tower).
The shock bodies are really sturdy looking. These shocks are more akin to the type of quality you see in the shocks of racing dirt buggies than the type of quality you see with the Axial Icon shocks if you know what I mean...
soze is offline   Reply With Quote
Old 04-18-2018, 12:23 PM   #22
Moderator
JatoTheRipper's Avatar
They do look really solid!
I know exactly what you mean! I pulled my dad's shiny new SCX10 II RTR out of the box and the cardboard looked like a Harley Davidson had been sitting there.
Old 04-19-2018, 06:20 AM   #23
Very stout looking truck. Almost overbuilt (that's a good thing imo) - I used to bash Ofna buggies back in the day, they were tough as nails for sure.
Can't quite tell from the pics, but look like 4mm threading in the links ilo the usual 3mm?
OSRC is offline   Reply With Quote
Old 04-19-2018, 09:19 AM   #24
3mm.... 3x12mm screws.
Old 04-19-2018, 10:28 AM   #25
Steps 14-15: Shift linkage, Panhard, and Steering Servo mounting
Here's a look at the shift linkage
Shift mechanism mounted up
Panhard mount
Using the HoBao HB-5518MG 18.6kg servo my friend threw in. Not sure what rebranded servo this is... maybe another JX.
Servo mounted up
I'm using a Boom Racing 25T Low profile aluminum clamping servo horn for now, but the length of the hole isn't quite right when compared to the stock plastic one. The hole on the stock plastic one is in between the 2 holes on the Boom Racing horn. I'll take a deeper look when the steering rod and axles are mounted up.
Old 04-19-2018, 11:17 AM   #26
That shift linkage is the first somewhat sketchy looking piece so far. Will be interesting to see if it functions properly/consistently.
2mtech is offline   Reply With Quote
Old 04-19-2018, 11:37 AM   #27
Those were my thoughts at first too. Then I hooked it up and was surprised. It actually works. I'll try to make a video of it working sometime soon.
The nice thing is that there is adjustability as far as those bushing/spring/brackets are concerned, and you aren't stuck with having servo adjustment only.
Old 04-19-2018, 11:41 AM   #28
Moderator
Shift linkage looks fine to me. They setup 1/8th scale buggy and truggy linkages like that.
The metal plate on the outside of the plastic panhard mount for reinforcement is awesome. This truck impresses me more each time I see it.
Old 04-19-2018, 11:45 AM   #29
That explains it. They have a background with 1/8th scale buggies after all.
Old 04-19-2018, 11:49 AM   #30
Moderator
I should have added the word "nitro" to my previous statement, of course.
Old 04-19-2018, 01:00 PM   #31
Very interesting. Wonder if or when individual parts will be available.
What is the height of the chassis rails?
hillbillyrc is offline   Reply With Quote
Old 04-19-2018, 01:55 PM   #32
In Europe they're widely available and priced lower or near Axial kits. But this looks so much better. The parts quality, I mean.
Ninomaniac is offline   Reply With Quote
Old 04-21-2018, 12:04 AM   #33
Will aftermarket SCX10 bumpers fit easily enough? I assume it will take most bodies with the right length posts.
mond is offline   Reply With Quote
Old 04-23-2018, 11:12 PM   #34
Steps 16-25 - Axles
Alright, we're getting to the fun part and some "different" ways of doing things.
Two bags for the axles.
So here's the first "different" way of doing things.... axles use 3 piece housings.
Parts for the gears, locker, and a diff gear mount/carriage?
One side of the axle put together
Diff assembly is a little different from others
Diff assembly mounts/carriage
The mount/carriage does make it easy to slide and secure the diff gear in there. Also if you look at the housing, you could easily swap the direction of the gear.
Axle housing bolted up
Front CVDs
Steering knuckles. The steering link mount is a metal plate screwed into the knuckle.
Steering knuckle, CHUB and CVDs all put together
All mounted up to the axle housing
Steering links added
Rear axle put together
Front axle mounted up to chassis
Rear axle mounted up to chassis
Old 04-24-2018, 07:36 AM   #35
That's some solid looking parts. If you break anything on this one you are truly hardcore. Interesting that they did a separate punkin and diff cover, I've never seen that.
Please continue, Sir
Old 04-24-2018, 09:26 AM   #36
Someone on reddit mentioned that these axles would look perfect for a 6x6 or military vehicle setup.
Now that I think about it even more... I know we all scratch our head when it comes to that link mount on the axles... but you know.... that link mount may make it really easy to convert that over to some type of mount for a leaf spring setup. Imagine that!
Old 04-25-2018, 11:21 AM   #37
Steps 26-28 - Shocks
So again, we see some different way of doing things....at least as far as crawlers are concerned. Overall the shocks seem like good quality with a minor issue as far as the piston goes. The piston was a little too "sticky/snug" on two of them. I could probably fix it by sanding down the sides a little.
Here is the instruction step showing what goes into building these shocks. I particularly like the bottom end with the flanged washers and o-ring setup. I think it'll help prevent leaks. The part I don't like as much is the piston. The piston is a disc with two cuts at the edges opposite each other rather than piston holes.
Here's the body of the shock. Good material and metal caps.
Ugh, I forgot to take a picture of the piston... but it's basically a disc with the edge chopped off on 2 sides.
1 shock put together. I feel like the springs are way too hard. I'll use them for now as they may compensate for a heavier body since the DC-1 has a body with a bunch of scale details on it.
All 4 shocks put together.
Alright... another different way of doing things. The shocks are mounted like a buggy. They're mounted from the front rather from the side like most crawlers do.
Notice the front to rear mounting at the shock mount and the axle
Same thing in the rear
Old 04-25-2018, 11:47 AM   #38
I like the shock mount methodology, seems more natural to the action of the shocks.
I also think the edge-relieved pistons may not be such a bad thing, especially if they foresaw holes being blocked by the e-clips and impeding flow, like in the case of stock Ascender shocks, that generally require the outer perimeter to be modified to allow flow.
Old 04-25-2018, 11:53 AM   #39
True, the pistons might actually be ok. I just gotta figure out why 2 of them are more sticky. Maybe I didn't trim it well enough? Shouldn't be the case though since the side-cutters shouldn't leave any flash.
I'll have to take them apart later on and check it again.
Old 04-25-2018, 12:22 PM   #40
That shock mount is different, i wonder what the advantages are ? More sturdier perhaps? Coming out great !
Frank211 is offline   Reply With Quote
Soze's HoBao DC1 Kit Build - Similar Threads
Soze's GMADE GOM GR01 Build soze G-Made Crawlers 69 08-20-2021 12:45 AM
Soze's MST CFX-W Build soze Max Speed Technology CFX 90 01-31-2019 01:02 AM
Soze's Axial Yeti Kit Progress tracker. soze Axial Yeti 31 03-09-2018 12:22 AM
HoBao DC-1 seedburns General Scale Talk 7 01-29-2018 06:39 PM
