09-23-2018, 05:55 PM | #21 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
| Re: The Bug Named Roach Ok...... flat belly isn’t complete without some tube and gussets. I am excited about the outcome of slider/ floor phase 1. Sent from my iPhone using Tapatalk |
09-28-2018, 06:07 PM | #22 |
| Re: The Bug Named Roach Outer bars.......check. I need to shave and shape the lower tamiya step and role out the fender to match the contour of the rod. But next I’m tying the new outer bar into the chassis with some tube. Sent from my iPhone using Tapatalk |
09-28-2018, 06:27 PM | #23 |
Quarry Creeper Join Date: Jan 2009 Location: pacific north west
Looking good! Those sliders/outer bars fit great! Sent from my SM-G965U using Tapatalk |
09-30-2018, 03:40 AM | #24 |
Quarry Creeper Join Date: Jan 2011 Location: Woody point
looking forward to seeing what you do with the bar work!
09-30-2018, 03:04 PM | #25 |
Thanks you fellas. This is the layout I’m leaning towards. I might run a smaller rod considering it it very solid as is. I will bend and burn the inner corners of the floor plate when I decide. This has been my distraction. Weather has been so nice. Have to take advantage. |
09-30-2018, 06:24 PM | #26 |
Forgot this angle Sent from my iPhone using Tapatalk |
10-06-2018, 01:48 PM | #27 |
| The Bug Named Roach
Some pretty solid updates to report on Roach. Got the sliders buttoned up other than a little clean up. Also tacked in front steering and winch servo cross members. Bumpers next...... Sent from my iPhone using Tapatalk Last edited by Bananaclip; 10-06-2018 at 05:48 PM. |
10-13-2018, 01:32 PM | #28 |
Knocked out a front bumper this morning. I might add something under to hide the steering arm...... Now I need to figure something out for the rear end. Sent from my iPhone using Tapatalk |
10-14-2018, 08:29 PM | #29 |
Quarry Creeper Join Date: Jan 2008 Location: Antioch
I say a rear cage with a motor. I did that on mine.
10-15-2018, 11:48 AM | #30 |
| Re: The Bug Named Roach That's the direction I am leaning..... There is several VW engine options.... Have any pics of what you did Venomous98? Links to preferred engines to use would be awesome...... I saw a Porsche motor on shapeways that was pretty rad.....
10-16-2018, 05:55 PM | #31 |
I just used the RPM engine/blower i found at my local hobby shop. Pretty cheap. Here is a link to my build, hopefully the pics still work. Some were posted from photobucket. The Ultimate V8 powered Baja Bug |
10-16-2018, 06:54 PM | #32 |
RCC Addict Join Date: Aug 2013 Location: Calgary - in the Great White North
If you have access to a 3D printer here's a cheap option that you could print yourself. You'd have to scale it down as it's 1/5 scale but that's easy enough to do. https://www.printable-3d-models.com/...printable.html |
10-16-2018, 07:58 PM | #33 |
Now you have me looking a Scorcher bodies, they aren't too expensive for a hard body which is awesome. If you search shapeways for sand scorcher you can get sucked down a rabbit hole of amazing but expensive prints, some of those might be helpful to look at for rear bumper/cage ideas. |
10-18-2018, 09:23 AM | #34 | |||
| Re: The Bug Named Roach Quote:
10-18-2018, 10:04 AM | #35 |
| Re: The Bug Named Roach You're not wrong there you can spend hundreds on little plastic do-dads. I was more thinking along the lines of look at their designs just for inspiration on what to build yourself (rear bumper or cage)
10-18-2018, 03:47 PM | #36 | |
Oh. That one buzzed by me. Yes I am seeing a few variations of the rear cage. Very helpful thank you. I think I have a direction planned out. I’m gonna do a tad more engine research and bite the bullet. Buy a slick printed engine and protect the little diamond with some cool (hopefully) tube work. Thanks my brother. Sent from my iPhone using Tapatalk | |
11-03-2018, 10:08 AM | #37 |
| The Bug Named Roach Roach is on the table for step one of a proper rear end makeover. Sent from my iPhone using Tapatalk |
11-03-2018, 10:19 AM | #38 |
| Re: The Bug Named Roach Step one done. Sent from my iPhone using Tapatalk |
11-03-2018, 12:22 PM | #39 |
| Re: The Bug Named Roach Sent from my iPhone using Tapatalk |
11-03-2018, 05:12 PM | #40 |
| The Bug Named Roach Needs something more........... Sent from my iPhone using Tapatalk Last edited by Bananaclip; 11-03-2018 at 05:18 PM. |
The Bug Named Roach - Similar Threads | ||||
I haven't named this one yet | crawl33oh | 1.9 Scale Rigs | 23 | 07-03-2014 02:17 PM |
A freak named....... | ser3100 | 1.9 Scale Rigs | 14 | 03-25-2010 10:44 PM |
Ax-10 yet to be named | BigRich | Axial AX-10 Scorpion | 26 | 02-02-2010 07:04 PM |
*no named 2.2 Tubed | Robbob | 2.2 Scale Rigs | 18 | 09-25-2008 06:37 AM |
