Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: A straight capra
Old 10-24-2020, 05:40 AM   #1
Default A straight capra
Start of a capra build biffs links and shocks done
Sent from my SM-G975F using Tapatalk
JKMIDDY22 is offline   Reply With Quote
Old 10-24-2020, 05:41 AM   #2
Default Re: A straight capra
Built in stock form
Axial ae-5
550 5 slot motor 11 turn
Ot the wheels and tyres ik gonna be using just a place holder
Old 10-24-2020, 05:44 AM   #3
Printed a jeep style grill and changed the diffs to scx10ii axles got it nice and low very very happy with how its turning out cant wait to test it
Old 10-24-2020, 05:44 AM   #4
Painted and detailed the fuel cell a little
Old 10-25-2020, 02:04 PM   #5
Looks awesome so far, what links did you use, kit or?
Sent from my SM-S767VL using Tapatalk
Spindctr is offline   Reply With Quote
Old 10-25-2020, 04:06 PM   #6
Just the stock kit links
Old 10-26-2020, 07:56 AM   #7
Thanks, and are you running the stock trans or?
Old 10-26-2020, 03:26 PM   #8
I'm wondering this as well. I have some scx axles to put in my Capra but I don't know how it will be since the stock trans has a higher gear ratio than the scx trans.
Turn'Nburn is offline   Reply With Quote
Old 10-26-2020, 10:05 PM   #9
Nah I got a sparetime hobby skid plate on the way to run an axial 3 gear transmission if you run the stock capra transmission it won't crawl properly
Old 10-27-2020, 03:20 PM   #10
That's what I figured. Thanks for the reply
Old 11-21-2020, 07:16 PM   #11
I run the stock Capra transmission and mine crawls just fine, volt up and gear down
Sent from my SM-G975U using Tapatalk
cushdog58 is offline   Reply With Quote
Old 11-23-2020, 03:22 PM   #12
Right, mine does too, with the stock capra axles. But, I went ahead and put a 3-gear in my AR44 capra. When using AR44 or similar axles that have a higher gear ratio it would be better to use the SCX10/10.2 3-gear trans. The capra trans is geared much higher to compensate for the combined lower ratio of the ring/pinion and portals. One probably could get away with Ar44/capra trans, but I imagine the slow speed control wouldn't be very good. Then again I may be wrong, it has happened once before...
Old 12-08-2020, 05:12 AM   #13
"I run the stock Capra transmission and mine crawls just fine, volt up and gear down"
Yes, because you're running the Capra Portal Axles with it - the OE configuration. (BTW - you need to rescale your pics - they're showing up huge)
The ratio in AR44's or similar is completely different and does not have nearly the reduction the portals provide. The OE Capra trans is geared much "taller" to accommodate the Portal reduction. Additionally, without hacking and making clearance on the Capra trans, 11T pinion is as low as you can go. This won't get you there with AR44's / similar.
Building my SSD Pro44 based straight axle Capra at the moment. After doing the math on ratios, I went 3 gear trans, 32P 57T spur, 10T pinion, OD in the front axle. I'll be running a tried and true combo of Hobbywing1080 with a Holmes Hobbies 13T Crawlmaster. Did some bench testing last night and it looks good. From neutral point at the Tx to adding just one click of throttle trim, the motor turns and just allows it to creep. Add a handful and there's giddy up to spare. Need to do more testing, but so far I'm pleased. I may go 11T on the pinion for a bit more up top since there seems to be creep to spare down low. Running 100C, 1500mah 3S.
mewalsh100 is offline   Reply With Quote
A straight capra - Similar Threads
VFD Capra...Can I Still Call It A Capra? mjensen Axial Capra 107 11-20-2021 03:56 AM
Capra trans & straight axle gearing...help Robotboy General Crawlers 3 02-16-2020 08:23 AM
RC Axle Master's Straight 4340 Chromoly Straight Axles Cruzin Illusion EnRoute Berg 48 08-29-2009 06:07 PM
New Berg Straight Rear Straight Axles Survey LetsHandleit EnRoute Berg 31 07-30-2009 07:58 PM
Hot Racing rear straight axle kit or stock Axial straight axle lockout? jmbones Axial AX-10 Scorpion 36 05-28-2008 04:28 PM
