Go Back   RCCrawler Forums > Scale Rigs General Tech > 1.9 Scale Rigs
Thread: Deerhurst's D21 Build
Old 06-23-2019, 05:25 PM   #1
Default Deerhurst's D21 Build
First time Ive done a build thread I believe. Ive done "look at this cool painted body" but never a full build. I fully expect this to take forever and to not go anywhere close to as planned.
So far the plan is to print a Nissan D21 body and put it on a chassis. I have 2 choices, a HiLift chassis or an Ascender chassis. The Hilift Hilux recently took a big tumble when I fell off a small cliff and it tumbled down behind me so it needs some TLC. Im leaning towards using the Ascender.
My inspiration is this:
So, itll be a MiniMe of my 1:1. Nissan bodies are hard to find.
Wheels will be a set of left over RC4WD Wagon Wheels. Tires are undecided. Maybe Proline KO2s. To leaf or not to leaf?
It probably wont handle great since the body will weigh a ton. The wheelbase will be quite long. Easily a couple inches longer than the HiLift.
Since my 3D printer is fairly small, 220x200x250, I had to split the cab and the box into 4 pieces each. About 23hours a piece. Then sand, prime, sand, prime, sand, prime and hopefully paint!
So far, I have a corner....
Lots to do! It will evolve as it goes. Need to order a couple more rolls of filament to keep printing.
Deerhurst is offline   Reply With Quote
Old 06-23-2019, 05:30 PM   #2
Default Re: Deerhurst's D21 Build
I’ll subscribe. The Flaming Marshmallow doesn’t live but maybe an hour or so from me.
Brake Weight is offline   Reply With Quote
Old 06-23-2019, 07:38 PM   #3
That is one cool hardbody! Havnt heard from the Flaming Marshmallow in a while. Maybe I'll have to do a camper in tribute!
Old 06-23-2019, 08:51 PM   #4
LOL. That thing is pimped out.
Old 07-06-2019, 10:11 AM   #5
Cab is 50% printed and still a long ways off from being mounted. The seam needs to be filled and the entire thing sanded, primed, sanded, primed.....etc. Hoping to print another quarter of the cab today.
Old 07-09-2019, 06:06 PM   #6
Cab is 75% printed and almost half way through the last piece. Its gonna be really big.
My Tamiya HiLift Hilux in the background. The width of the Nissan is based off the width of the Tamiya lid.
Old 07-10-2019, 10:29 AM   #7
Looking good - I briefly had a brand new 2wd D21 in black, with brushed aluminum 5-spoke wheels and BFG Radial T/A tires.
They're really nicely styled trucks...
durok is online now   Reply With Quote
Old 07-10-2019, 08:08 PM   #8
I like the little D21 too. Got the entire cab printed at this point. I need to take photos. It's big. It's the right width for the Tamiya HiLift. Probably 6 days in printing just for the cab. Plan to start the box this weekend.
Old 04-06-2021, 02:28 PM   #9
This is still a WIP. Just took a long siesta in the middle. Now with the new element IFS chassis I'm thinking of putting it on one of those but for now I'm back to working on the body. I'm impatient and don't like detailed work.
The entire body is printed, 8 pieces, welded together as a cab and a box. Started sealing the print with filler primer yesterday. I'll get pics us as I go. It needs some bondo for the bigger gaps too.
I'm thinking of using the IFS enduro chassis and going leafed in the rear but not sure. I have an Ascender already but it doesn't go long enough with the supplied links. Might chop the king cab out of the body bit not yet sure. The KC is growing on me.
Sent from my Phone 2 using Tapatalk
Old 04-06-2021, 02:47 PM   #10
Wow, this looks really good! Did you design this yourself?
I’d leave it as a King Cab, I’ve always liked them better.
_________________
https://www.instagram.com/island_crawlaz/
79 F150 SCX10 ii
TRXWalker
ScaleLifeNewbie is offline   Reply With Quote
Old 04-06-2021, 05:58 PM   #11
_________________
79 F150 SCX10 ii
TRXWalker
Did not design it myself. I wish. The grill would have been different as this has the 88-89/pathfinder grill and headlights. I prefer the D21 setup. I found the model as a 1/24 or 1/18 scale model and scaled it up poorly before I knew better then broke it into 8 pieces to fit on my printer and went from there!
Just put a can of primer filler on it and it'll need bondo or similar.
Old 04-06-2021, 05:58 PM   #12
Still working.on the body. Gonna need bondo.
Old 04-06-2021, 06:05 PM   #13
Oh ok.
If you have any E6000 on hand, it’s works in a pinch. I used it on this Bruiser body I’m doing to fill in the gap from the bob. I go more in depth on my thread “SLN’s Brusier Build” if you want to know more about it.
_________________
79 F150 SCX10 ii
TRXWalker
Old 04-15-2021, 06:57 PM   #14
Starting on bondo work. Need to fix the stance and wheelbase of the chassis too but that'll come after the body is ready for paint.
I keep screwing up the bondo ratios and it keeps hardening way too fast. First time I've ever done bondo or done a printed anything this large.
I might narrow the axles or find a narrower chassis too. Once the body is ready for final paint I'll get the chassis figured out.
In the mean time my HiLift needs some servo TLC!
Deerhurst's D21 Build - Similar Threads
Nissan D21 Hardbody Truck Body? JasonA Paint and Body 5 10-25-2014 08:21 PM
My D21 Build ( Might be pic heavy ) Deerhurst 1.9 Scale Rigs 3 07-02-2012 10:15 PM
D21 Hardbody 92PathSE 1.9 Scale Rigs 29 10-26-2010 06:19 PM
Nissan Hardbody King Cab build - D21 NissanNut 2.2 Scale Rigs 40 10-21-2006 06:02 PM
