10-24-2014, 02:34 PM | #1 |
Rock Crawler Join Date: Sep 2011 Location: Richfield
| "Angel of Death"
My buddy Parkflier and I are on a mission to build a pair of NASTY Class 3 rigs for the 2015 Scale Comp season. He has started Project "Iron Maiden"...(I need to get him to post a build thread! ) In keeping with the Heavy Metal theme, my new build has been named "Angel of Death", and I'm hoping this rig can live up to such an iconic song name (by Slayer for those who don't know! lol)! Its going to be a full tube chassis with custom formed body. Design ques will be LOOSELY taken from 1950's era Cadillacs. Complete with nasty big fins. Treated to the typical Class 3 / TTC body mods such as Pinching, Dovetailing and maybe Boatsides. It will be a 4 seater, Losi Axles (of course! ), 4 Wheel Steer and 14" WB. Also plan on trying a Direct Drive motor setup with T-Case....If that doesn't work out, a typical Metal Gear LNC Trans will be run. Here is the Direct Drive Mock-Up...not much to it! Smoothed out a stock Losi Skid. Going to cut in half and mount to a stock LNC Battery Tray...That whole assembly will in fact be my new "Skid Plate". Upper links mount to the old battery tray frame mounts. Giving me the 14" WB i'm after. Sliced out the middle section of some Uni-Strut Built a Jig to weld in some tube sleeves and mounted them to skid. This now gives me a good place to start the Rock Slider / Floorpans and tube work. Last edited by GiJoe; 12-19-2014 at 06:35 PM. |
10-24-2014, 02:59 PM | #2 |
| Re: "Angel of Death" The Hearse From Hell
Looking forward to this monstrosity!
10-24-2014, 04:48 PM | #3 |
Rock Crawler Join Date: Mar 2014 Location: Yorkville
questioning how that direct drive is gonna work out.
10-24-2014, 05:42 PM | #4 |
| Re: "Angel of Death" The Hearse From Hell Guys in Europe are experimenting with this in the 2.2S class. I'm gonna give it a whirl as a scaler! IMG_06421_zps29d3cd92.mp4 Video by Pettern | Photobucket |
10-25-2014, 06:16 AM | #5 |
| Re: "Angel of Death" The Hearse From Hell |
10-25-2014, 06:31 AM | #6 |
Are you sure the chassis is Class 3 legal? Doesn't it need frame rails that extend almost to axles? I'd have to read the rules to know for sure... and it's 7:30 am so time for bed! EDIT: I guess the tube is the chassis and the skid is just mounted different...? Last edited by johnnyh66; 10-25-2014 at 06:34 AM. |
10-25-2014, 06:40 AM | #7 |
if the whole direct drive works out im deffinetly gonna try it, its a cool looking set up, keep us posted!
10-25-2014, 07:14 AM | #8 | |
| Re: "Angel of Death" The Hearse From Hell Quote:
Its going to be a full tuber and the body / cage will extend beyond the wheelbase. As for the skid? Yeah its just a little different. Rectangular instead of square. • Class 3 body minimum specs: Rock sliders, mirrors, etc do not count in these measurements: - The distance between the inside of the tires (of any axle) can be no greater than 1.25" more than the width of the body at the doors. *Example* (7" inside-of-tire to inside-of-tire = body must be 5.75" wide). - The body must be at least 5" wide from the front to the rear of the doors. - Tire height can be no more than 0.5" taller than cab height. Height is measured from the bottom of the skid to the top of the bodywork/tube not including a light bar. (5.5" tire = 5" tall from bottom of skid to top of cab/tubework) - Body must be at least as long as the wheelbase of the vehicle. • Body modifications including, but not limited to, pinched front, dove-tailing and boat-siding are permitted as long as the final dimensions comply with the minimum I keep a copy of the current rules on my bench! Lol | |
10-25-2014, 10:52 AM | #9 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| Re: "Angel of Death" The Hearse From Hell Nope body needs to be same legnth as the wheel base. Interpreting that how you see fit is up to. You |
10-25-2014, 11:52 AM | #10 |
A little more tube work and some 16ga steel Rock Sliders / Floorpans For now, using a flux core MIG welder to tack all pieces together. Last edited by GiJoe; 10-28-2014 at 04:00 PM. |
10-29-2014, 02:41 PM | #11 |
10-30-2014, 02:52 PM | #12 |
10-30-2014, 05:47 PM | #13 |
Quarry Creeper Join Date: Nov 2008 Location: grand junction
Ugh you're making me want to keep my losi
10-31-2014, 08:48 AM | #14 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
Love your builds! Love the way you think outside the box! Since my losi sporty gets no driving anymore, you have inspired me to build a class 3 rig out of it! I'm in parts collection stage right now! |
10-31-2014, 12:40 PM | #15 | |
Keep it! Scale comps are a blast! Both Tgreer and mikro383, I can't rave enough on the performance of my Losi scalers! As you both know, the Losi Crawlers were first and foremost "comp minded" rigs! Keeping the Losi geometry and components is a no brainer for me! | |
11-01-2014, 09:44 PM | #16 |
11-03-2014, 06:45 PM | #17 |
Fabbed up a heavy duty brow ridge / visor out of 16ga steel! This will also double as a light bar mount... Re-Installed drivetrain and suspension! Time to get this beast rolling and shake out the bugs before paint and detail work begins! Damn the stance is sexy! Hahahaha. Yes....I'm doing some limiting straps! |
11-06-2014, 02:07 PM | #18 |
I hav'nt run these batteries yet, but on paper...they should work just fine. They are Airsoft batteries. 1200mah, 2S, 25 to 50c Going to run them saddle pack style low in the frame with a series wye connector for 1200mah 4S. Last edited by GiJoe; 11-06-2014 at 02:18 PM. |
11-07-2014, 05:29 AM | #19 |
Quarry Creeper Join Date: Aug 2014 Location: holland
| Re: "Angel of Death" The Hearse From Hell Lol. I thought you might go for a battery tray in style..... performance wise not the best option I guess. ;) Awesome rig man. Like to see how your panels turn out. keep it up. |
11-07-2014, 07:05 AM | #20 | |
Right now, the coffin will be built and permanently mounted to hide all those electronics. But removable coffin battery cases would have been sweet! Hmmmm. Maybe its not too late... Now I want to leave work early! Haha thanks! Last edited by GiJoe; 11-07-2014 at 07:10 AM. | |
"Angel of Death" - Similar Threads | ||||
"Angel of Death" Class 3 | GiJoe | Team Losi Comp Crawler | 0 | 11-04-2014 07:04 PM |
Our angel, Fallon Jade | eddievedder | Chit Chat | 5 | 01-31-2014 07:14 AM |
Please Vote for Angel.... | Krawler Konceptz | Chit Chat | 13 | 11-25-2012 06:23 PM |
Crawl Angel Stadium? | 860Crawler | Chit Chat | 7 | 10-22-2009 09:42 AM |
Chris Angel slices himself in half | ClodMonster | Chit Chat | 18 | 06-26-2006 06:20 AM |
