Go Back   RCCrawler Forums > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: Mantis Hybrid
Old 01-27-2015, 10:16 PM   #1
Y-Town Crawlers
Del Monte's Avatar
Default Mantis Hybrid
This truck started as a prototype Mattzilla Mantis build for Axialfest and U4 racing in 2014. The original build handled great but never quite as well as it should have.
Here's a pic of the original truck right after it went up in flames at Axialfest.
The original truck was torn down to build an S-Class rig for Worlds. Since then I've missed having a fast solid axle truck, so I decided to rebuild this one.
Here's the direction it's going now
Del Monte is offline   Reply With Quote
Old 01-27-2015, 10:32 PM   #2
Y-Town Crawlers
Del Monte's Avatar
Default Re: Mantis Hybrid
The original mantis rear end wasn't going to work with the huge Yeti rear shocks and VP Yeti trailing arms. The rear tubes had to go to make way for sway bars mounts and more travel on compression.
I hand cut the first rear plates in ABS, then scanned them and traced them in Corel draw.
From Corel, I imported the drawing into Mastercam to create a toolpath. Then things started to get interesting...
Old 01-31-2015, 09:52 PM   #3
Y-Town Crawlers
Del Monte's Avatar
I have a few more details to add, but the Hybrid is almost ready for KOH.
The current specs are:
VP TH trailing (leading?) arms for the front lowers
VP Yeti rear trailing arms
Yeti rear shocks
Losi front shocks (for now)
Futaba BLS177HV servo
Tekin Rx8
Holmes Hobbies 3300kv 4-pole 540
Holmes Hobbies spools
Voodoo U4's Gold compound
The stock wraith skid needed to be massaged to get a lot of up travel with the big VP links, but everything just clears on compression now. I was actually breaking revo rod ends pretty frequently on the last version of this truck, so hopefully the VP's hold up to more abuse.
I was tired of always having to pull the side panel off to change a battery during a G6 or long trail run, so I made added a hinge to the battery side panel.
Old 01-31-2015, 10:35 PM   #4
Nothing but performance updates right there. Great looking all-business rig.
Szczerba is offline   Reply With Quote
Old 01-31-2015, 11:20 PM   #5
Very nice looking rig. Pretty cool changes for sure.
Ballistic17 is offline   Reply With Quote
Old 02-01-2015, 12:02 AM   #6
Interesting using trailing arms up front, how's it perform? If you don't mind, where did you get your interior/drivers? Thanks!
COwraith is offline   Reply With Quote
Old 02-01-2015, 06:52 AM   #7
Y-Town Crawlers
Del Monte's Avatar
The front arms speed up the reaction of the front suspension, but add more body roll. I'm running a big .093" sway bar in the rear to combat the body roll. It could use a soft front sway bar too. Overall it eats up bumps and choppy climbs though
The interior is from an Hpi Apache.
Old 02-01-2015, 06:57 AM   #8
Is that front servo bracket something you made?
sally1800 is offline   Reply With Quote
Old 02-01-2015, 07:38 AM   #9
this is cool as ****k, i want it!
gunder463 is offline   Reply With Quote
Old 02-01-2015, 09:07 AM   #10
Nice rig, sure would like to see more of the servo bracket.
hotwheels000 is offline   Reply With Quote
Old 02-01-2015, 09:41 AM   #11
Thanks, oh and x3 on the servo mount. That looks like it is tucked away nicely.
Old 02-01-2015, 05:37 PM   #12
Y-Town Crawlers
Del Monte's Avatar
Here's my servo mount. 7075 plate mounted to a milled down VP truss. The plate is tapped for 3mm screws to hold the servo on from underneath. It would be easier to put the servo on top, but then it would be sticking up pretty high.
This is a pic with the old housing, but you can see how much I had to cut out of the truss and axle. The bottom of the servo is still about .100" above the bottom of the axle tube.
In that pic you can also see one of the coolest parts of the truck... My SMW/Rob_B angled link mounts
Old 02-01-2015, 09:09 PM   #13
Haha wow that's a bit of trimming! Looks good though, you notice any weakening in the axle or does the mount and truss make up for it.
Those link mounts are sick.
Old 02-02-2015, 06:33 AM   #14
www.ottsix.com
Looking forward to seeing this in person at KOH!
crawl-o-matic is offline   Reply With Quote
Old 02-02-2015, 07:33 AM   #15
As always with your rigs... True performer. Great idea on the servo. Looks very protected for U4.
What's the overall weight on this ripper?
tedo is offline   Reply With Quote
Old 03-06-2015, 12:43 PM   #16
Nice work Jake...completely missed this thread...lol
Can't wait to run with you again, will be a first for me in trophy, be easy....go slow!
Hope to see you tomorrow at the U4 race.
TheAxialNut is offline   Reply With Quote
Old 03-09-2015, 01:16 PM   #17
Y-Town Crawlers
Del Monte's Avatar
Thanks! I must have missed your post before. The truck is about 6.5lbs right now. It's a handful to drive on a track, but its very stable going over rough stuff at speed.
Thanks Derek! I was bummed to hear your trophy rig grind to a stop on Saturday. I guess a T8 might be too much motor
Also, no trophy class racing for this truck for now. It's too light and illegal on a few dimensions. It was fun racing it against all the Yeti's though. Next time I'll be racing a Yeti of my own
Old 03-11-2015, 05:32 PM   #18
HeHEEE!
Don't listen to those foul mouths... a T8 is a solid base from which to run a Ultra Trophy Rig. No grinding here buddy, my shock top snapped off, along with the upper link, stupid revo end, still took 4th. Weren't you in fifth with Jerrys rig? That grinding you heard was the first, second, and third spur gear, thanks Jason and Rich, that the piggy Wraith went through. 48P is really too small for that type racing. I gotta get rid of that thing and join you guys in the Yeti class.....
Old 03-12-2015, 01:32 PM   #19
Y-Town Crawlers
Del Monte's Avatar
HeHEEE!
My mistake. I still have motor envy
On Joel's recommendation I switched to a 54t Revo spur gear for my new trans and it has survived so far.
Mantis Hybrid - Similar Threads
Mantis - My way! craigrobbo Axial XR10 101 01-16-2013 08:47 AM
My old XR Mantis chopperray Axial XR10 16 12-14-2011 08:10 PM
My mantis knobbytrav Axial XR10 50 11-02-2011 11:53 PM
Mantis XR crawlinghulls Axial XR10 10 11-09-2010 04:21 PM
Rock hammer hybrid VS all weather Hybrid joesbruiser Tires and Wheels 1 08-05-2008 09:23 AM
