05-26-2015, 04:05 AM | #61 |
Pebble Pounder Join Date: Apr 2013 Location: Charlotte, Mi
| Re: Capo 1:8 Jeep CD15823 |
05-26-2015, 05:06 AM | #62 | |
Pebble Pounder Join Date: Mar 2012 Location: Upstate New York/Newfoundland
| Re: Capo 1:8 Jeep CD15823 Quote:
I may try some silicone chain lube I have but I'm weary of gumming things up, the cables seem to move pretty freely all ready. | |
05-26-2015, 05:30 AM | #63 |
Rock Crawler Join Date: Feb 2014 Location: ?
I would not use anything wet on the cables. Dri Slide or some similar dry lube would better. Maybe you can pre stretch the cables. This is a goofy idea idea but since it is pull/pull you could try something like Kevlar Tenkara Line instead of wire. Kevlar will have almost zero stretch. 19 Foot Kevlar Tenkara Furled Leader Line | eBay |
05-26-2015, 05:42 AM | #64 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
Oddly the issues of compression and things hitting is common on the 1:1 JK. Maybe not the same parts, but same issue, especially full compression of Passenger side. Perfectly scale of real problems! |
05-26-2015, 05:45 AM | #65 | |
Well thats interesting to know. Lol, who knew?! | |
05-26-2015, 07:59 PM | #66 |
Got to work on the engine/transmission. Shift forks Bolted on tranny tail Transfer case mounted Gears installed A look at the 2wd/4wd shift mechanism It seems to work really smooth. Only thing im not thrilled about is how open the top of the trans is to outside debris. Disc brake cam and piston No brake pads to speak of. Just metal on metal. Mounted up Using the 45 can motor that came with the cross 8x8. 45t is recommended in the manual and I had this one laying around so.... Notice the brass helical pinion gear. Hope its durable. Rest of the gears installed. All greased up and ready to close up. Oil pan installed. Started mounting the 3 sub micro servos. And this is where I leave it for the night. This thing reminds me alot of the original bruiser trans. It functions much the same way, with the exception that it looks realistic on the outside. Last edited by Prop Shaft; 05-26-2015 at 08:07 PM. |
05-27-2015, 05:49 AM | #67 |
Rock Crawler Join Date: Jan 2013 Location: Australia
Good progress. If you're open to suggestions for color, i'd personally go either white, gun metal grey, or orange. Matte or gloss though, I don't know.
05-27-2015, 03:27 PM | #68 |
05-27-2015, 03:52 PM | #69 |
So I made a trip to the local hobby store today, and boy my wallet payed for it... I was looking for a dx8 or futaba 7 channel but all they had was a DX9. A hefty price tag but I rationalized it by telling myself this will be the last transmitter ill ever have to buy. Im good at convincing myself I need to buy things lol. Now I can install servos and make sure they are centered properly. And I have my switch layout mostly figured out now. Plan is lights and a winch for the extra channels. Work will continue tonight! |
05-28-2015, 02:51 PM | #70 |
Got some work done on the jeep last night. I had to elongate the holes on the servos in order to screw the engine halves together. You screw one side of the servos in, then the other sides after the engine halves go together. I had to take the oil pan off in order to rout one of the cables through the transmission. Then I encountered a problem. The hole where the cable comes out is to large. It swallows the cable sheath. My solution was to take one of the spare brass cable mount pieces, (not sure what they're called) and remove some material from the side of it so it would fit into the hole. I had to do this because the side of the transmission case is very close to the hole. 1 very tiny motor and some tiny screws to mount it. This drives the accessory belt. I had a bit of a problem adjusting the servo for the brake. It was working fine, then it got a mind of its own, then it just stopped working. After spending some time trying to figure out what was going on, I realized my 2s lipo was basically dead. So i swapped it out, and still the brake servo wouldn't respond. Turns out I have a dead servo. I ordered 4, but now i dont have one to mount the steering wheel to. Heres the brake lever with brakes off And brakes applied. The 2wd/4wd cable was having a hard time operating as well, after staring at it for a while, I decided the sheath was to long. Shortened it up to the position its sitting in here. Works much better now. Last edited by Prop Shaft; 05-28-2015 at 02:55 PM. |
05-28-2015, 06:10 PM | #71 |
Rock Crawler Join Date: Feb 2015 Location: Melbourne
Nice build. Why did you go with a stick controller? No pistol controls with enough channels?
05-28-2015, 06:15 PM | #72 |
| Re: Capo 1:8 Jeep CD15823 Presicely. I did concider a hacked gt3 c but i couldnt find much info on them other then theyre a pain to program, and i never got an email reply back from the guy whose selling them. When will manufacturers wake up and make a 6 channel or more pistol..... *sigh*
05-28-2015, 06:19 PM | #73 |
You can buy a gt3b pre hacked. You would only need to program it once. Either way Spektrum make good gear.
05-28-2015, 06:22 PM | #74 |
| Re: Capo 1:8 Jeep CD15823 I know but couldnt find much info about the number of switches and locations of them etc. was hoping to find out more info in that respect. Im happy with this radio though, ill just have to get used to sticks again.
05-28-2015, 07:37 PM | #75 |
Got the transfer case shift linkage sorted. Bit of a breakdown of the accessory pulleys And installed Done for the night. Im at the point where i need to drag the airbrush out to do some painting. I want the valve covers red. Then its on to the body. Still torn on a color.... |
05-28-2015, 08:03 PM | #76 |
Holy Mother of God. I don't which is shinier the Transmission Case or the DX9 The little brass thing is a ferrule and I am surprised there wasn't one for the over large trans hole. It is not shown in the parts list? Seems like it would have to have one. The shorter and straighter you can run those cables the better they will actuate and less they will drag and stretch out. If they are not already lubed try DriSlide. It will run right down the wire inside the sheath and then dry...but it is a filthy mess. |
05-29-2015, 03:52 AM | #77 | |
06-03-2015, 03:55 PM | #78 |
Not much in the way of an update. Im busy at work, plus Im messing with the paint currently. A tedious process for me. Thinking I'm going with blue. Now Im just decided on which blue I want. Making a trip to the hobby store tomorrow to see what options there are in the Tamiya lineup. I did manage to get the engine painted and installed though. Along with the prop shafts. |
06-04-2015, 08:11 AM | #79 |
Quarry Creeper Join Date: Nov 2012 Location: spanish fork
Nice build!
06-07-2015, 05:30 PM | #80 |
Capo 1:8 Jeep CD15823 - Similar Threads | ||||
Capo 1582-2 Tatra 817 8x8 and Cross MC8 Man Kat 1 8x8 | Prop Shaft | Multi Axle Rigs | 24 | 06-18-2021 04:31 AM |
MadDogRC Capo Jeep CD15823 | Mad4Rnr | Large Scale Rigs | 46 | 11-22-2015 08:29 PM |
Capo R/C and some new stuff | Szczerba | Chit Chat | 27 | 07-08-2015 09:16 AM |
New ultimate scale rig from Capo rc | scale4x4 | General Scale Talk | 71 | 02-16-2015 12:48 AM |
Capo Rc making a new truck | jpf | General Crawlers | 17 | 09-23-2014 12:47 PM |
