Go Back   RCCrawler Forums > Scale Rigs General Tech > 2.2 Scale Rigs
Thread: Hairba11's 1:8 version of Hogan's Hot Rod (with Mad Moose Portals)
Old 02-08-2017, 07:38 PM   #21
Default Re: Hairba11's 1:8 version of Hogan's Hot Rod (with Mad Moose Portals)
Thanks guys! And speaking of suspension, I got the heim joints in this morning
hairba11 is offline   Reply With Quote
Old 02-09-2017, 05:45 PM   #22
Progress made on the suspension
I made uni-links for the axles
Old 02-10-2017, 02:46 PM   #23
Got my front upper suspension mounts in, front shocks on, and panhard rod.
Old 02-13-2017, 12:23 PM   #24
Got some roller chain for my rear shackles. Welded it to the top of the axle plates
Got two more highlift shocks from klabeume and took out the internal springs
The suspension sits in droop in the rear
The front is in semi-droop. Only about 1/4" up travel.
I'm getting about 4" of articulation.
Old 02-14-2017, 07:14 AM   #25
Got drive shafts in an turned the knuckles around for BTA steering
Of course now that they're turned around they hit the lower shock mount.
Here's a detail inside the portal
Old 02-15-2017, 08:19 AM   #26
Used a brake lathe at work with the double chuck and a dremel with a carbide deburr tool to open up my inner rings and clear the portals
I moved the front lower shock mounts so the knuckles would clear.
This thing is awesome!
Old 02-16-2017, 07:58 AM   #27
I got the spool reversed in the rear
And got a tie rod and drag link in and did a quickie servo mount
And got it outside under power
Ok. It has a wild amount of dog track I need to get out of the rear, the servo sucks, I broke a lower front shock mount and lost both springs out of the front end(still need to figure out how to retain them) but it drives amazingly!
It's as good as I had hoped.
Old 02-16-2017, 08:22 AM   #28
try and find tamiya cr-01 spring retainers. those might help.
CM9000 is offline   Reply With Quote
Old 02-17-2017, 08:54 AM   #29
Thanks! I'll look for them.
Still waiting on 'nese servos.
But I got some body panels made today
Old 02-22-2017, 08:36 AM   #30
Got the front panels on today
I also discovered that the 1:1 is for sale. Naturally right after buying the wife a car.
Old 02-22-2017, 09:14 AM   #31
A seriously rad build! Awesome everything. I know Hogan would love to see it done!
Szczerba is online now   Reply With Quote
Old 02-23-2017, 06:28 AM   #32
Old guy
ROCKEDUP RICKY's Avatar
Hairball !
My old friend.
I think it's great you building one of Hogan's rigs.
He my friend and a great guy.
I remember when he built this one.
Can't wait to see it done.
ROCKEDUP RICKY is offline   Reply With Quote
Old 02-23-2017, 07:35 AM   #33
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
It's a sweet full size for sure! Digging your project.
JohnRobHolmes is offline   Reply With Quote
Old 02-23-2017, 07:40 PM   #34
Ricky! I was hoping you were still around. It's been a while for sure!
I ordered a 50mm wide timing belt to duplicate the worn out sand paddle fenders. I'm going to try and get supports welded on then start in on the interior
Old 02-24-2017, 08:27 AM   #35
Used some paper and a sheet of styrene for floor making
Then cut out the floor and extended the motor wires and snapped the floor in
Then used some leftover chunks of foam and knocked out some seats
Then hooked everything up and went for a drive
Old 02-24-2017, 01:03 PM   #36
hi can you tell me what kind of hemi joints you used
steven318is is offline   Reply With Quote
Old 02-24-2017, 08:09 PM   #37
They came in a box of stuff from an auction. They're metal and 1/4-28 thread. That's all I know
Old 02-25-2017, 12:00 PM   #38
thanks
Old 02-25-2017, 12:03 PM   #39
great job.I wish i had the skills to that type of work...
rustneversleeps is offline   Reply With Quote
Old 02-25-2017, 04:20 PM   #40
RNS, me too I'm just faking it!
Hairba11's 1:8 version of Hogan's Hot Rod (with Mad Moose Portals) - Similar Threads
Hot Rod Husy Large Scale Rigs 16 09-22-2014 07:32 PM
Hogan's Bronco ROCKEDUP RICKY 2.2 Scale Rigs 273 06-23-2013 10:04 AM
Mad Force Nitro version of a Summit msaloney Kyosho Crawlers 11 01-28-2013 06:54 PM
Im going to be on Hot Rod TV! willipmartinni Chit Chat 28 04-29-2012 12:21 AM
