02-25-2017, 05:15 PM | #41 |
Rock Stacker Join Date: May 2015 Location: Saint Louis, MO
| Re: Hairba11's 1:8 version of Hogan's Hot Rod (with Mad Moose Portals) Not sure what specifically OP used, but McMaster-Carr probably has something that will work. https://www.mcmaster.com/#standard-rod-ends/=16iil87 |
02-26-2017, 06:40 PM | #42 |
Quarry Creeper Join Date: Jul 2011 Location: ireland
thanks i found an inline joint just have to order now thanks
03-01-2017, 04:25 AM | #43 |
RCC Addict Join Date: Mar 2007 Location: St. Louis (High Ridge)
Yeah. From the McMaster site, looks like the heavy duty rod linkage without grease zerk about halfway down the page is what I had. The rod end with the open ball instead of the stud may work better for some applications but the rod end linkage with the stud made the bottom of the truck smoother in my case. Sent from my iPhone using Tapatalk Last edited by hairba11; 03-01-2017 at 04:28 AM. |
03-01-2017, 06:47 PM | #44 |
Started this morning turning the highlift shocks down a little mostly to shave off the red and rough up the surface for paint. I also pulled the axles back off and hit them with primer I got it back together and I'm loving it. It's so cool seeing it coming together Sent from my iPhone using Tapatalk |
03-06-2017, 07:10 PM | #45 |
Got my timing belt in Saturday's mail. So I started fabbing brackets. This is how I weld while being too lazy to disassemble the plastic parts. Little hole in the lid of the water bottle. This is looking awesome! Left on the list. Dash, roof, servo mount. Sent from my iPhone using Tapatalk |
03-08-2017, 08:01 AM | #46 |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
this is too cool. don't forget the cover over the radiator.
03-08-2017, 07:44 PM | #47 |
| Re: Hairba11's 1:8 version of Hogan's Hot Rod (with Mad Moose Portals) |
03-08-2017, 09:51 PM | #48 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
You're doing a killer job!
03-09-2017, 07:48 AM | #49 |
Thanks! Yesterday I was trying to weld the music wire to the cage for the fabric roof support Problems with the heat affected zone being brittle meant any time it gets bumped the welds break. That's no good. So today I popped off the wire, did a little grinding and welded nuts to the cage This let me use two pieces of music wire to make the loop without any brittle spots I also got some pre-wired 10mm LED's in red and white, but I didn't realize they were 12mm tall. No biggie, chucked them up in the lathe and turned them down. Not the original square lights, but they'll work ok Sent from my iPhone using Tapatalk |
03-11-2017, 09:44 AM | #50 |
Got the top on Sent from my iPhone using Tapatalk |
03-13-2017, 06:10 PM | #51 |
Well there were no easy ways around it. So I cut the grill off to get to the servo so I could make mounts. I cut and bent some sheet metal, then welded some M3 nuts to it After getting both sides done I bolted the servo on I ended up welding the servo mounts in place while bolted to the servo then hosing them with my squirt bottle to keep from burning the servo. Next I welded bolts to the end of the frame pieces and drilled holes in the grill to bolt it back on so I can get to the servo in the future. Sent from my iPhone using Tapatalk |
03-16-2017, 06:22 PM | #52 |
Ok, so I got some shifters made, put in some carpet and got a dash cut out but not installed I also masked off everything and gave the cage a fresh coat of black. Then I got my lights wired up. I drug it home and ran it around a bit. She wheels pretty good for a 10.5 lb rig. Sent from my iPhone using Tapatalk |
03-16-2017, 07:42 PM | #53 |
That's a beast! Love it!
03-31-2017, 09:07 AM | #54 |
Pebble Pounder Join Date: Aug 2008 Location: Strafford Mo
Its been a few years but i remember that rig, pretty dang cool. As i remember your builds never disappoint. Very cool bud.
04-02-2017, 07:11 PM | #55 |
Got my dash and wheel in a week ago, and got to run a full pack through it yesterday Elvis brought over his CrossRC military for its maiden voyage too. Sent from my iPhone using Tapatalk Sent from my iPhone using Tapatalk |
04-03-2017, 12:58 AM | #56 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
Looking great, all the details are fantastic.
Hairba11's 1:8 version of Hogan's Hot Rod (with Mad Moose Portals) - Similar Threads | ||||
Hot Rod | Husy | Large Scale Rigs | 16 | 09-22-2014 07:32 PM |
Hogan's Bronco | ROCKEDUP RICKY | 2.2 Scale Rigs | 273 | 06-23-2013 10:04 AM |
Mad Force Nitro version of a Summit | msaloney | Kyosho Crawlers | 11 | 01-28-2013 06:54 PM |
Im going to be on Hot Rod TV! | willipmartinni | Chit Chat | 28 | 04-29-2012 12:21 AM |
