02-09-2017, 10:10 AM | #1 |
Pebble Pounder Join Date: Sep 2007 Location: denmark
| Rebuilding my TA-02 LR3 Towrig +modding trailer and trackloader(pic heavy)
Hey guys i just ordered alot of stuff to rebuild my ta-02 lr3 project here is what ive got so far Mockup frp chassis(found it at my local hobbyshop in the old ****/not complete bin) Goteck servo locked rear diff ta-02 frp chassis steering arms alloy a propdrive 35-36 1800kv motor(4mm shaft, mounted with a brass tube to a steel 5mm 16tooth pinion) alloy motor mount 5mm steel drive shaft Gmade GT02 2.2 beadlocks mounted with Tamiya FJ Offroad tires 88mm OD arms and dogbones changed to a TA-02T i bought this car on scale4x4rc along time ago first mod cutting the servo arm so it fits underneath the steel driveshaft second making space for the driveshaft and servo underneath the body i will box it in when i get my styrene while waiting for parts i ordered the trailer and track loader for this to tow around, i did not know that the trailer came almost assembled, thought it was a kit pictures before hacking the plan is to change it into a machine tip trailer like this soo lets begin cutting Halfway now its even on the rails(still need to sand the bed) cutting tires down, the plan is to get around 60mm OD the track loaders 2.4Ghz reciever The track loader esc control(it controls all four motors and end stop switches) the track loader in the bed added a pin hitch to the track loader(we use a 50mm ball for towing here) I noticed a small crack in the rear gearbox(so i replaced it with a new tree) Done Finally got done with the tires, reduced from 78mm OD to 65mm OD mounted and painted the rims i finally got the styrene for my trailer now im just missing my GRP chassis sheets |
02-13-2017, 10:36 AM | #2 |
| Re: Rebuilding my TA-02 LR3 Towrig +modding trailer and trackloader(pic heavy)
Got the GRP sheets so now the chassis is cut for my idea |
02-14-2017, 12:08 PM | #3 |
chassis mounted for the chassis i only need to do the steering linkages,move the steering servo a little,towbar and make the sides for the chassis after that i need to proceed with the trailer and figure out how to mod my trackloader Last edited by storm4710; 02-14-2017 at 12:11 PM. |
02-15-2017, 08:11 AM | #4 |
are 2.2s on a Ta02 gonna fit?
02-15-2017, 09:10 AM | #5 |
its 2.2 beadlock rims with tamiya 1.9 fj offroad tires cut to fit the rims |
02-21-2017, 12:29 PM | #6 |
update this is how it looks with the body on still need to paint the chassis, make a towbar and strengthen the interior of the body thats whats left on the main car then i need to build the geardrive system for the trailer(im still missing some screws for mounting my geardrives M1.6 is pain to get a hold off) and then theres the trackloader it runs fine chassis Trailer things done so far reduced tires by 13mm moved axles up by 6mm added a hinge point Last edited by storm4710; 02-21-2017 at 12:33 PM. |
02-25-2017, 08:00 AM | #7 |
car is almost done just need to do some wiring Towbar(not perfect but works) connected to the trailer with body on, with trackloader (on the trailer) from the front |
Rebuilding my TA-02 LR3 Towrig +modding trailer and trackloader(pic heavy) - Similar Threads | ||||
I might as well have one too (pic heavy!) | CAPCbass | Axial Wraith | 23 | 08-16-2013 01:04 AM |
chevy C30 or K30? towrig,for my highlift | 96ram85chevy | 1.9 Scale Rigs | 36 | 10-31-2006 09:25 PM |
