04-03-2017, 02:45 PM | #21 |
Pebble Pounder Join Date: Oct 2009 Location: Tacoma
| Re: Scale Trophy truck build by bmxreeves
Between the steering geometry and the suspension geometry you may have some sketchy handling out of that front end.
04-03-2017, 02:52 PM | #22 | |
Rock Crawler Join Date: Mar 2015 Location: "Crawling Heaven"
| Re: Scale Trophy truck build by bmxreeves Quote:
that's exactly what i was thinking aswell. if there is i was planning to make another chassis anyway. we will see. Sent from my iPhone using Tapatalk | |
04-03-2017, 03:04 PM | #23 |
I think if you were to give the suspension more caster, as in kick the top of the spindle towards the rear it would help the suspension. The steering is going to need a bell crank set up to work.
04-03-2017, 03:41 PM | #24 | |
excuse my newb ness, what's a bell crank? Sent from my iPhone using Tapatalk | |
04-03-2017, 04:49 PM | #25 |
| Re: Scale Trophy truck build by bmxreeves |
04-03-2017, 04:52 PM | #26 |
04-03-2017, 04:59 PM | #27 | |
| Re: Scale Trophy truck build by bmxreeves Quote: thanks guys! next chassis is definitely getting a slash front end this time. Sent from my iPhone using Tapatalk | |
04-04-2017, 02:56 PM | #28 |
So apparently the "next chassis" would be sooner than i thought. this time i am completely redesigning the whole chassis for a better look, better steering and front suspension. let's hope this time i can make something good for once. Sent from my iPhone using Tapatalk |
04-04-2017, 09:57 PM | #29 |
You had a really good start that just needed a couple of changes.
04-04-2017, 10:03 PM | #30 | |
thanks. now that i've got a little experience making the first one, i will use that to make an even better chassis. i will most likely finish the old one, sell it and do it again. Sent from my iPhone using Tapatalk | |
04-05-2017, 03:26 PM | #31 |
quick update. got the front end a little built. the front design on the new chassis is similar, skinny front end where a-arms mount, to make the track width a little shorter. Sent from my iPhone using Tapatalk |
04-11-2017, 05:12 PM | #32 |
a arms / front end is in and welded. pleased so far on how it's coming so far. Sent from my iPhone using Tapatalk |
04-28-2017, 12:19 PM | #33 |
well what do we have here? Sent from my iPhone using Tapatalk |
04-28-2017, 01:39 PM | #34 |
here is the new SSD D60 Centered housing assembled. Here are the specs inside this masterpiece: Grip Fab spool. Axial over drive HD Ring and pinion Fast eddy bearings SSD axle shafts (come with the housing ) on to more pics. the pic above is estimated wheel base. i've also got some baja try trailing arms on there way, stay tuned. Sent from my iPhone using Tapatalk |
Scale Trophy truck build by bmxreeves - Similar Threads | ||||
Bmxreeves 1.9 ibex build | Bmxreeves | 1.9 Scale Rigs | 24 | 04-04-2016 05:32 PM |
JPRC Redbull Trophy Truck VS Score Trophy Truck STRC Upgrade | joerc2013 | Axial Yeti | 10 | 11-13-2015 11:06 AM |
First trophy truck build | pbmiller88 | 2.2 Scale Rigs | 11 | 06-27-2015 01:56 AM |
Scale Trophy Truck Build | 92MNstanger | Non Crawler RC's | 36 | 06-04-2014 07:09 PM |
SC trophy truck build | 62 bugzilla | Non Crawler RC's | 8 | 09-02-2010 08:01 AM |
