04-22-2017, 07:40 AM | #1 |
RCC Addict Join Date: May 2009 Location: Weston
| Rjohns Mantis
Quick post with more to come! Picked this up off of CM9000, it's a EmeryworX Mantis chassis. I have a set of Wraith axles mounted up that include FI spools, UD rear, Vanquish claiming chubs/scale knuckles, a pair of Holmes SHV500, Velvet shocks in full droop, beef tubes and patties and Proline rubber/ dual stage foam on China wide methods. Width it right at 11 7/8 and wheelbase is 13.5. I have some more drivetrain stuff on the way. It's going to be a tight fit while getting an interior in there! |
04-22-2017, 07:46 AM | #2 |
| Re: Rjohns Mantis
I forgot to mention it's going to run Mamba X and PP 2200 stubby. This will be my first rig run on my new DX6r. Awesome radio by the way, love the thought of being able to play music while I run without needing anything else.
04-22-2017, 08:52 AM | #3 |
I wanna be Dave Join Date: Feb 2009 Location: Detroit
| Re: Rjohns Mantis
shoot, already a roller. chassis was just too big for me.
04-22-2017, 08:59 AM | #4 |
| Re: Rjohns Mantis
It's definitely bigger then I thought it was going to be. Hopefully I can make some driveshafts work, the angle is going to be a challenge I think.
04-22-2017, 09:15 AM | #5 |
| Re: Rjohns Mantis
I was going to run a lnc trans and a high turn sensored motor. I even had the thought of using a 85t lathe motor. cause the lnc trans is so small, it would fit and you could still throw interior in it. that's why I bought 2 sets of ud gears and a set of stock to try out. this chassis was supposed to mimic the mishka chassis. but I think it ended up being a bit bigger. put that servo winch mount to use! |
04-22-2017, 09:30 AM | #6 |
| Re: Rjohns Mantis
Oh I am. I ordered and low profile powershift rc winch.
04-22-2017, 09:35 AM | #7 | |
| Rjohns Mantis Quote:
LNC trans should be here today. I also pick up a carrier bearing in case I have to run a dog bone to extend an output. That's plate is really long. | |
04-23-2017, 07:15 AM | #8 |
| Re: Rjohns Mantis
I think I've got it later out how I want it. I ordered some 1/16" acetal to make a skid plate because I do t the steel plate will slide all that great. That will also give me somewhere to countersink some screws. I was think of brazing some brackets on the top to mount everything topside but I think this will be easier in the end for rebuilding.
04-23-2017, 07:15 AM | #9 |
| Re: Rjohns Mantis |
04-24-2017, 07:22 AM | #10 |
| Re: Rjohns Mantis
take a measurement from the trans outputs to the pinions on the axles. a tlr 22t rear shaft may fit with the lnc axle outputs. kinda frakenstiened but.. may work. and also, regular driveshafts should work too.
04-24-2017, 08:06 AM | #11 | |
| Re: Rjohns Mantis Quote:
I got it all together with some mips I had floating around. Seems to be just right. I braze some tabs on for a radiator and fuel cell and started on something for the interior. It's going to have to be modular since the cage is solid and I can only get it through the openings. I think I'm going to run some rock lights and a single rear red light. I have stuff in order and will post up some picks when I get a little further. I switched out the Mamba X for a MMP with no case to save some space and make wiring a little easier. | |
04-24-2017, 08:42 AM | #12 |
| Re: Rjohns Mantis
a alum seat could fit in there no problem. id make a bracket to put the seat on so you could pressure fit a battery under the seat. and if breakovers become stubborn, use a cut spring on the back shocks for enough "bump" I know that flat skid might be a pita... |
04-24-2017, 08:53 AM | #13 | |
Lol. That's exactly what I'm doing. Aluminum seat and all. The break over doesn't see like it's going to be too bad actually even with the huge skid. | |
04-24-2017, 11:20 AM | #14 |
| Re: Rjohns Mantis
that skid is bigger than a wraith skid lol.
04-24-2017, 12:26 PM | #15 |
| Re: Rjohns Mantis
That's true but with the droop suspension and the shorter links tightening up the wheelbase when they drop out so it's better then I thought it would be. I hope I don't sound like I'm saying it's good lol. It's just not as bad I thought it was going to be.
04-27-2017, 10:00 AM | #16 |
Pebble Pounder Join Date: Sep 2006 Location: keller
| Re: Rjohns Mantis
What axle side 3 link is it? Or is it home made? Sent from my SAMSUNG-SM-G920A using Tapatalk |
04-27-2017, 10:10 AM | #17 |
| Re: Rjohns Mantis
They are homemade.
05-08-2017, 08:21 AM | #18 |
| Re: Rjohns Mantis
Quick update with some interior work. I'm going to change the color to orange so don't mind the blue. |
05-21-2017, 04:51 PM | #19 |
| Re: Rjohns Mantis
Quick update. Still needs some work. |
09-29-2017, 12:58 PM | #20 |
| Re: Rjohns Mantis
did you ever drive this thing yet?
Rjohns Mantis - Similar Threads | ||||
Rjohns King Sling | Rjohn929 | Mega/Monster Trucks | 14 | 06-15-2017 04:44 AM |
Rjohns 2.2 Tundra | Rjohn929 | 2.2 Scale Rigs | 15 | 03-31-2017 04:29 PM |
Rjohns SMT10 | Rjohn929 | Mega/Monster Trucks | 46 | 03-13-2017 07:11 PM |
Rjohns Cherokee | Rjohn929 | 1.9 Scale Rigs | 1 | 02-25-2017 09:23 AM |
Rjohns Bomber | Rjohn929 | Axial RR10 Bomber | 29 | 11-06-2016 10:49 AM |
