08-16-2008, 10:22 PM | #21 | |
WWW.THEROXBOX.COM Join Date: Sep 2007 Location: The Legend of Stone Pillow
The Servo hits a little, but the servo arm does not..... My Dig works great... Make sure you clean off all of the back part of your servo arm.. see pictures and let me know if you have any other questions..Thansk | |
08-16-2008, 10:27 PM | #22 |
holly cow i can get bigger pictures to post ..... please let me if anyone what to see anything in a larger picture... Thanks For looking at this thread... The rig is going though a few changes getting ready for Moab... Updates will follow here soon |
08-16-2008, 10:30 PM | #23 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
08-16-2008, 10:31 PM | #24 |
| WWW.HBZUSA.COM ALSO ........ RPP HOBBY HAS THEM IN STOCK http://www.shop.rpphobby.com/product...productId=1034 |
08-16-2008, 10:32 PM | #25 |
| YEP ....................... |
08-16-2008, 11:21 PM | #26 |
Newbie Join Date: Jun 2005 Location: Fort Worth
Thanks for the pictures, that really helps. My arm is not hitting but the servo is. I am going to give it a rest for the night and check it out again tomorrow. I did notice that my kit came with the longer dubro links for the shift arm and with them screwed all the way down the linkage is still a little too long. I will swing by the LHS tomorrow and see if I can grab a set of the short ones. If I have any other questions I will let you know. Thanks again, Chris |
08-17-2008, 09:58 PM | #27 |
Rock Crawler Join Date: Nov 2007 Location: Bay Area (RWC)
Chris I ran into the same issue. I noticed when I removed the tab, the remaining weld was hitting the servo so I took the Dremel to it. It still hit a tiny a bit so I took a little bit more out and it fits perfect now. Here is what it looks like. |
08-18-2008, 05:23 AM | #28 |
Yup, that is exactly where mine was hitting. I had already sanded the spot welds flat but it was still hitting the tube so I gave it a little tweek and it popped right in. Thanks for all the help guys.
08-18-2008, 06:43 AM | #29 |
support@rc4wd.com Join Date: Nov 2007 Location: Lancaster, Ohio
| It will never work |
08-18-2008, 02:00 PM | #30 |
Pebble Pounder Join Date: Apr 2008 Location: Concord
08-18-2008, 09:00 PM | #31 |
I wanna be Dave Join Date: Mar 2004 Location: The Haunted Forest
Aerospace Tolerances!
08-18-2008, 09:11 PM | #32 |
Pebble Pounder Join Date: Apr 2008 Location: Tulsa
I was looking at picking up one of the pro comp ones and after seeing you VF Dig in there I had a question that might be a little dumb. I have never had a tuber in the past so... What are those tabs for if all you do it cut them off to get the dig in? Every good comp rig has a dig so if they are not necessarry then why did HBZ weld them in there?
08-18-2008, 10:08 PM | #33 | |
The tabs were put in there in case you wanted to run the stock battery plate. Some people may want to run it but most will end up at least cutting out the 2 tabs to mount a dig and use the 2 front tabs to mount their electronics to. Quote:
08-18-2008, 11:03 PM | #34 |
Now that you said that, I think I sorta read that somewhere here. I just did not realize that they were talking about the same two tabs. thanks for the clarification. |
08-18-2008, 11:32 PM | #35 |
Its just 1 tab I removed. Not 2. |
08-19-2008, 06:15 AM | #36 |
I removed both, but may end up tacking the other back in. That looks like the perfect place for my rx. |
08-28-2008, 06:08 AM | #37 |
Rock Crawler Join Date: Aug 2008 Location: B.C.Canada
| Carbon fiber issues?
Nice kit ,it caught my eye a few months ago.I'm glad i found this post to learn more about it. Any reason that your lower links are still mounted outside the chassis? Do ya think the carbon fiber will stand up to the abuse of rock rash and being that it connects the the whole thing together could it crack if it took a 15ft fall off a rock face for example? Most of the stuff we climb is steep and a rock run can go up over 150ft so if a rig flips it can be real extreme and a broken chassis is the last thing ya want. |
08-28-2008, 09:55 AM | #38 |
Quarry Creeper Join Date: Jul 2008 Location: Newark
I'm currently trying to get a delrin to replace the CF side plates...finally got my dig, and before I could even put it in...my outdrive post snapped now I need to get steel gears from RC4WD or does anyone recommend something better to withstand a cobolt 7T...If I upgrade to steel tranny gears...I would need to put a slipper clutch...have you had this kind of problem "EYE"?
08-28-2008, 10:44 AM | #39 | |
I wanna be Dave Join Date: Oct 2006 Location: Centered
Most of us at some point will hit that insane vert, or crazy hard line, and carnage is just part of it. Any rig falling from that kind of height is going to incur some damage...most of the time. The Warthog chassis itself is very stout and rigid, and I think that it will hold up very well under most roll over and drop conditions. As a side note to that, I rolled my Hustler Super down a nearly vertical wall last season, and only tweaked the rear side tube; 10 second fix, but on another day, it could have been worse. It's up to the drivers to decide if they want to take the challenge and the glory, or pay the price for trying. | |
08-28-2008, 10:55 AM | #40 |
RCC Addict Join Date: Jan 2006 Location: Oklahoma City, OK
I seen this rig at the Battle Grounds comp (SICK AZZ).. Aaron, you shouldnt lie to the people and say you built it, We all know you bought (COUGH) it like that....LMAO |
