Thread: AX10 Drive Shaft Issue
Old 08-24-2008, 09:59 PM   #1
Default AX10 Drive Shaft Issue
So I'm crawling up a huge rock and once again I hear a snapping. I thought it was the wheel hexes until I checked closer and saw that the drive-shaft was twisting inside itself and popping, and whenever I got good traction that would happen. I bought a couple new Traxxas drive-shafts, but I was wondering if anyone has had this issue before and if anyone knows of any aluminum drive-shafts are available that will work with the AX-10? I'm close to being comp ready...real close...
austinquattro is offline   Reply With Quote
Old 08-24-2008, 10:04 PM   #2
Get MIP CVD'S !!!!!
KREEPYHEEP is offline   Reply With Quote
Old 08-24-2008, 10:07 PM   #3
Get a set of the MIP driveshafts. One of the most important mods on an AX-10 IMO. If you're going to run dig, you can get the set with a shortened rear driveshaft from Thunder Tech that will fit with a dig unit like the VF Dig.
CharliesTheMan is offline   Reply With Quote
Old 08-25-2008, 08:58 AM   #4
I busted a yoke within 5 minutes of running my AX for the first time. I am buying the MIP drive shafts.
broncobill is offline   Reply With Quote
Old 08-25-2008, 09:19 AM   #5
Thanks...I'll look into those...
Old 08-25-2008, 09:26 AM   #6
MIP strong as hell
hardhead is offline   Reply With Quote
Old 08-25-2008, 09:45 AM   #7
I purchased the MIPs, but I have a problem. The pins keep slowly but surely sliding out, I've tightened the allen screws pretty tight (although, not as tight as possible). Should I disassemble them a reassemble as tight as possible?
xJeepxTJx is offline   Reply With Quote
Old 08-25-2008, 09:56 AM   #8
Yes. Clean off the grease if you got it on the screw threads both on the set screw and the screwhole. Then use Blue Loc-tite to hold the screw in place after you tighten it down.
AreCee is offline   Reply With Quote
Old 08-25-2008, 10:24 AM   #9
to all you guys with the MIP shafts...
Are you breaking anything else in your driveline? How long and how hard have you been running these MIP shafts?
helhedded is offline   Reply With Quote
Old 08-25-2008, 10:34 AM   #10
I've read where some use shrink tubing to keep this from happening. Find the right size tube, shrink it down with heat, and trim. Also, these shafts a lighter than the punisher shafts. Just thought I would add that.
Old 08-25-2008, 11:33 AM   #11
I havent broken anything yet but I believe the tranny outputs are the next weak link. Mine are looking rough where the set screw tightens down. I didnt dimple the outputs to keep the yolks on either. I thought it would make my situation worse.
But if anything breaks/fails.........it needed upgrading anyways.
j33pownr is offline   Reply With Quote
Old 08-25-2008, 12:49 PM   #12
yea it goes tranny outputs then tranny gears. i have broken all and it was not that hard either
crawler4lif3 is offline   Reply With Quote
Old 08-25-2008, 01:07 PM   #13
Mips are a possible choice.
But, for about 10-15$, I was able to convert my Axial's driveshafts to parts from the Revo and Tmaxx
The Revo shaft out back serves great for a VF/DNA dig because there is NO twisting whatsoever and it allows a smooth telescoping action.
Hildy is offline   Reply With Quote
Old 08-25-2008, 02:04 PM   #14
Default weak link
Installed MIPs and broke the trans outdrive in no time.
runs_wscissors is offline   Reply With Quote
Old 08-25-2008, 03:59 PM   #15
There is another choice. Punisher shafts from RC4WD.
J Mann is offline   Reply With Quote
Old 08-25-2008, 05:33 PM   #16
Punishers wear out at the joint in no time at all. and quality was not worth the money.
twig8 is offline   Reply With Quote
Old 08-25-2008, 05:57 PM   #17
where can i buy these mip shafts?
MaxxCrawler02 is offline   Reply With Quote
Old 08-25-2008, 06:17 PM   #18
TCSCrawlers.com
XPLORx4 is offline   Reply With Quote
Old 08-25-2008, 07:26 PM   #19
ok, thought so thanks!
Old 08-26-2008, 07:43 AM   #20
hmmm I think I'd rather have my $3.00 pede drive shaft break than something in the tranny.
