01-17-2009, 10:03 AM | #21 |
Rock Crawler Join Date: Nov 2008 Location: Maple Ridge, BC, CANADA
nothing new at the momment. I did put a battery mount on the front axle, put oil into my shocks(way more predictable.) I am in the works of a driveshaft dig. Almost done will post pics in day or two. still have not gone outside to play, still some snow at higher elevations. Just playing inside. |
01-17-2009, 05:52 PM | #22 |
well I got around today to finishing my driveshaft dig unit. I used plumbing supplies(nice and light ) Work great! and I LOVE IT!!! VIEW MY VIDS: http://video.google.ca/videoplay?docid=-2414477902695954526&hl=en-CA http://video.google.ca/videoplay?docid=3858726708835364555&hl=en-CA OLD DRIVESHAFT START OF NEW ONE WITH 3 1/2" FRAMING NAIL WITH HEAD CUT OFF TO KEEP MALE ENDS STRAIGHT TO EACH OTHER USED 1/2" PLUMBING PLASTIC TUBE AND 2 VALVE SEATS NOTCHED OUT A 6 SIDE STAR TO ALLOW LOCKED DIG FREE WHEEL 4WD LOCKED REAR MOUNTED SERVO WITH STOCK SERVO MOUNT TURNED SIDEWAYS WITH SPACER UNDERNEATH TO GIVE A LITTLE LIFT FOR THE LINK TO THE SERVO. UNDERSIDE So all it cost me was 3$ for the two valve seats, 3$ for a foot of plumbing tube, had a spare servo, 5$ for two sets of driveshafts and some time. |
01-17-2009, 07:53 PM | #23 |
Rock Crawler Join Date: Dec 2008 Location: Appleton, Wi
The front end on that thing is really short! What length upper and lower links are used on that rig?
01-18-2009, 12:36 AM | #24 |
01-18-2009, 04:18 AM | #25 |
Rock Crawler Join Date: Aug 2008 Location: B.C.Canada
hey didn't you live in Kamloops for a while? K3 site? anyway,i can't see shit...no pic's up right now |
01-18-2009, 07:33 AM | #26 |
Im gonna go to get the stuff to build one today but i was wondering what the length of the unit is if you dont know I cna just experiment a little too. I was also lookin to use a little from your thread and some from the sticky at the top of the main ax10 forum. Im gonna use steel pipe and nuts on the end for durability and dril and tread 3mm holes on the side for the screws. Ill put pics up on here when im done! |
01-18-2009, 09:31 AM | #27 |
Newbie Join Date: Aug 2008 Location: Tulsa
I spy cheap beer! Sick rig tho man.
01-18-2009, 10:02 AM | #28 | |
Nope. I have no idea why you can't see pics??? | |
01-18-2009, 01:24 PM | #29 |
Quarry Creeper Join Date: Aug 2007 Location: Amarillo, TX
None of the pics are showing for me either...
01-18-2009, 04:34 PM | #30 |
it's workin' now,cool
02-01-2009, 04:06 PM | #31 |
here some pics of my first two comps.... and the driveshaft dig work GREAT!!!! came 6th in first ever comp and last in second one (electrical problems ) also for the second comp(outdoors) I bought a set of LOSI Rock Claws for the front tires(huge difference!) Last edited by lil' lucifer; 02-01-2009 at 04:08 PM. |
02-01-2009, 04:24 PM | #32 |
Quarry Creeper Join Date: Jan 2009 Location: East Mids, UK
Nice pics and awesome rig. That dig is great too |
02-01-2009, 06:17 PM | #33 |
Quarry Creeper Join Date: Jan 2009 Location: El Cajon San Diego
How are your servo's holding up? When you flex your suspension the drive shaft will compress and extend a little. Are you using a servo saver or something?
02-01-2009, 06:39 PM | #34 |
| What is the rubber band for? Nice chassis!!! |
02-01-2009, 07:19 PM | #35 | |
| thanks Quote:
What about driveshaft compressing and extending....isn't that normal...... I find that when climbing steep inclines the rear passenger shock wants to unload then the front passenger tires comes off the ground. This way shock unloads a little but front tire stick to the ground.;) Last edited by lil' lucifer; 02-01-2009 at 07:23 PM. | |
02-02-2009, 05:34 AM | #36 |
First off Im sorry for the copy but I cant justify $100 for a chassis I just wanna do some testing on and remove a couple months down the road because once i get my setup dialed my plans are to make a custom tuber with the 60/40 distribution. But back to the subject. Im running limited E-maxx shocks with maxx springs I cut a coil and a half off and full droop in the front with springs inside to hold the shocks closed and am having great sucsess. I am also running 90wt oil in the front and 60 out back. |
02-02-2009, 05:47 AM | #37 |
Quarry Creeper Join Date: Dec 2008 Location: Suburbs
Nice chassis...very interested in it...like to see how it performs
02-02-2009, 03:46 PM | #38 |
I scored last in the last comp. But that was due to electrical glitches in the first round and burned up my steering servo the second. but as for the chassis itself there is a night and day difference. The truck climbs much more stable and with the rear sprung it has immense ground clearance without sacraficing any low cg. Im just now getting it dialed in so its time to start designing the tuber! |
02-02-2009, 05:21 PM | #39 | |
I joined the Band! Join Date: Oct 2008 Location: Bay Area
02-02-2009, 05:27 PM | #40 |
Newbie Join Date: Feb 2008 Location: Kelso
NICE! |
