07-22-2010, 05:49 AM | #1 |
RCC Addict Join Date: Jun 2009 Location: QLD, Australia
| The Nerd's SSS-R
All the same spec's as the old SSS just with a nice shiny new chassis. Pics finally. Check out that ground clearance 8-) Only thing I don't like is the front links are in the road of the tires but I have 725 hubs on the way so hopefully that will fix that. Other than that the flex feels great and it seems to be more controlled and smoother than the old version. Kieren |
07-22-2010, 05:58 AM | #2 |
Specs breakdown BWD SSS-R Axial C's Vanquish zero ackerman knuckles Vanquish SLW's V3 orange/black with 350/475 soon to be 475/725 Vanquish Hurtz dig CKRC rear lockouts Felsenfest zero slop lockers Axial CVD's Axial HD rear Axial OD front Hyperion 1100mah 35c and 45c HH puller 7t Tekin FXR CC bec Futaba S9157 The Nerd ultimate BTA (ever changing) Futaba mini servo for dig DNA motor mount (old style not BWD) HB Rovers Nova foams 5.5 dual stage 87/12 gear ratio Bout it I think. Anything I've missed let me know Kieren Last edited by Aussie Nerd; 07-22-2010 at 08:27 PM. |
07-22-2010, 06:44 AM | #3 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
Looks good but why aren't you using the front upper link/servo mount that came with the kit?
07-22-2010, 07:06 AM | #4 |
Try to Bend it Join Date: Aug 2009 Location: Perth Australia
Looks cool man... How does the pretzel go on this rig. |
07-22-2010, 08:00 AM | #5 |
Well? Come on......everyone else is talking about it.....how much does yours weigh? I saw the same issue. Trying to keep it as narrow as possible, yet using all the available steering throw is a battle of which will win out. I moved my lowers inboard more and I have all my steering, but I think it negatively affected the front geometry a bit. Still works great, but the front has just a touch of torque twist on a 62 degree incline. Last edited by Offroader5; 07-22-2010 at 08:04 AM. |
07-22-2010, 04:13 PM | #6 |
Rock Stacker Join Date: Dec 2009 Location: Calgary, AB, Canada
This makes me hate the Canadian border even more. Mine still hasn't shown up but the guy in Australia has it. It's good to see that the Vanquish dig fits in there. I was thinking about that after I ordered it. Looks good. |
07-22-2010, 04:21 PM | #7 |
07-22-2010, 07:57 PM | #8 | |||
Awesome clear's perfect Quote:
Yeah geometry is what I was worried about to, hopefully the wide hubs will fix that though. Quote:
Kieren Last edited by Aussie Nerd; 07-22-2010 at 08:13 PM. | |||
07-22-2010, 08:22 PM | #9 |
The weight as requested Hyperion 1100mah 45c weight - 95g 4 Vanquish v3 slw's, HB rovers with Nova foams weight - 660g Tekin FXR, CC bec, 6100 removed from packaging and heat shrunk, general wire and lexan plate weight - 70g Axial XC-1 painted weight - 75g Axial AX10 with BWD SSS-R and other various upgrades weight - 1080g Total 1980g or 1.98kg or 4 pounds 5.92 ounces (according to google calculator) Kieren |
07-22-2010, 09:33 PM | #10 | |
On a side note, I didn't know an FXR could handle a puller. This is something I'll need to look into. | |
07-22-2010, 10:29 PM | #11 | |
Yeah very muchly so, gets to about 4-5 I think so equivalent of running a mod motor according to the instruction Manuel. Only rated to 3s which is not enough for some people, but is plenty for the 7t. Plus it's tiny which helps in mounting. Kieren | |
07-23-2010, 04:58 AM | #12 |
My attempt at neat wiring Tekin wires were shortened to length, CC bec wires shortened (it is mounted under the plate), Dig servo wires will be lengthened. I might shorten the S9157 wires too but I dunno. Kieren |
07-23-2010, 09:46 AM | #13 |
07-23-2010, 12:40 PM | #14 |
07-23-2010, 04:11 PM | #15 | |
Massive problem I see is that your tires will want to 'lift' off the rocks to much Kieren | |
07-23-2010, 04:30 PM | #16 |
| Yeah but it'd be great at floating over gaps Last edited by TSK; 07-23-2010 at 04:33 PM. |
07-23-2010, 08:02 PM | #17 |
First trial run on the brick pile was incredible it is so much more planted and the ground clearance is very helpful Lack of steering is a big problem though, but I'll hold out on doing anything drastic till I get the new hubs. Heading out again to some real rocks this arvo so I might get some pictures then. Kieren Last edited by Aussie Nerd; 07-23-2010 at 08:10 PM. |
07-24-2010, 03:56 AM | #18 |
Tested her out on the beach today worked fantastic. It does have a bit of torque twist and the steering is well not great. Most of the pictures turned out rubbish so I filted through and got the best I could. The ground clearance alone is worth the switch from the old SSS. It seems a lot more stable and sidehills very well. Jumps nicely too Kieren P.S. to those of you that are permanently disable I commend you on your ability to compete in this sport. Crawling with a cast is nothing but annoying. |
07-26-2010, 06:07 AM | #19 |
Just a small update. I've been working on a one piece dig servo mount to replace the old 2 piece one. This is what I've got so far. Now I just need to drill some holes and she's ready to bolt up and use. Kieren |
07-27-2010, 03:46 AM | #20 |
Just another small update. Dig mount finished and it is much better, if anything better than the old style with two pieces, it allows no flex. Also got my 725 hubs today, I can get full steering with only a tiny bit of rubbing. Not sure I am liking the offset though, but we'll see how it goes. I'd rather deal with funny looking steering movement then minimum steering. Kieren |
Tags |
aussie nerd, sss, sss-r, torsion |
