12-23-2011, 12:33 PM | #1 |
Rock Crawler Join Date: Dec 2011 Location: Northwestern PA
| Shimming gears
I have been reading about installing overdrive and / or underdrive gears in the AX-10. I have read that shimming the gears is sometimes needed, which harkens to the little I know about setting up gears on 1:1 rigs. So this is my question: On these AX-10's, when you swap out the axle gears, do you need to shim the top of the carrier (small side), the bottom of the carrier (big side), or the pinion? Or, does it just depend on the specific situation and how things are meshing (or not meshing)? Thanks |
12-23-2011, 12:38 PM | #2 |
Quarry Creeper Join Date: Jul 2008 Location: fremont
| Re: Shimming gears
when i put in the o.d gears, just bolted them to locker and dropped them back in. No shimming or any additional adjustments.
12-23-2011, 12:48 PM | #3 |
| Could be any of the three, or none at all. And due to 'production tolerances' there's little chance it'd be the same axle to axle, so there's no saying it won't be different even between the front and rear axles. Going to hafta make the commitment and plunge in on that one. Best of luck to ya. |
12-23-2011, 12:58 PM | #4 | |
| Re: Shimming gears Quote:
12-23-2011, 12:59 PM | #5 |
| Re: Shimming gears
Trubble: One other question, different topic - How do I get a picture to appear by my name in the column on the left? Thanks |
12-23-2011, 12:59 PM | #6 | |
12-23-2011, 01:00 PM | #7 | |
http://www.rccrawler.com/forum/payments.php | |
12-23-2011, 01:25 PM | #8 | |
Shimming gears - Similar Threads | ||||
Shimming the HD Worm Gears | Del Monte | Team Losi Comp Crawler | 65 | 01-12-2012 08:48 PM |
Shimming the worms | omenwolf | Team Losi Comp Crawler | 2 | 06-04-2010 05:49 PM |
Shimming | Jake | Axial AX-10 Scorpion | 13 | 03-18-2010 10:05 PM |
Axle shimming? | LIKES2CRAWL | Tamiya TLT Crawlers | 34 | 10-11-2007 08:18 PM |
Axle shimming for the WK ? | Bananaclip | HPI Wheely King | 7 | 07-12-2007 07:24 PM |
