Thread: New ax10 project
Old 08-08-2014, 08:25 PM   #1
Default New ax10 project
How can i mqke my ax10 crawl and perform like my xr10? What upgrades do i need? Running a novak rooster crawler esc and an integy crawl motor. Servo is a hitec ultra torque. Any help is very appreciated.
xr10greener is offline   Reply With Quote
Old 08-08-2014, 08:39 PM   #2
Default Re: New ax10 project
You should do the xr mod. This will give you much more steering. Also put underdrive gear in the rear axle,and overdrive gears in the front axle. Parts you will need for the xr mod include beef tubes, xr axle shafts, VP wraith chubs and knuckles. These mods will make a huge difference. If your not going to comp it you could add a dig to it.
Dezertdirt is offline   Reply With Quote
Old 08-08-2014, 09:43 PM   #3
I think you'd have to run a better chassis. And the shocks are wayyyyy too long and stiff IMO. Steering is definitely lacking with the AX10 knuckles but Wraith knuckles will open it wide up. Skid is too wide, chassis is too tall, shocks are too long, stock rims are offset too much, stock tires and foams are ridiculous, links suck, shafts are too weak, axles need reinforcing...come to think of it you won't have much stock anything if you want to make it crawl like a comp XR10.
MountainStorm is offline   Reply With Quote
Old 08-08-2014, 09:55 PM   #4
5th D Owner/Driver
cboggs's Avatar
Most current builds in this section will do what your looking for.
cboggs is offline   Reply With Quote
Old 08-09-2014, 02:42 PM   #5
Yeah i was looking man and they are wicked builds! Too pricey for me though haha, any of you ax10 guys have any parts you wanna "donate" to my build?
Tags
ax10
New ax10 project - Similar Threads
Project: DUAL AX10 THE CRAWLER KING Axial AX-10 Scorpion 97 11-10-2010 06:01 PM
New Axial Ax10 project SteeleFX4 Newbie General 6 09-03-2009 11:23 AM
Another Ax10 building Project barebones Axial AX-10 Scorpion 10 07-05-2009 04:39 PM
Scale AX10 project HotRodJosh Axial AX-10 Scorpion 11 02-17-2009 12:48 PM
ax10 project NIK Axial AX-10 Scorpion 2 02-21-2008 09:12 PM
