06-12-2012, 08:49 PM | #1 |
Quarry Creeper Join Date: Jun 2011 Location: panama city
| heavy crawler
well i bought an integy steel chassis it was heavier than i thought and so i put soom large weights in the tires that are 1 inch wide and hold together with two rubber o rings and that seemed to stop the top heavy roll over and i now have this and i made some panels here and here and have now come up with this it comes in around 7.5 pounds almost 8 and wondering how to power this heavy tank i have a losi esc with a 45t and an 87/12 now but the motor gets pretty hot had a 55t and had no wheel speed so changed to the 45t. is there a better setup for heavy rigs i like the grip and climb it has. my wifes rig ( sorry no pic) but is the proline plastic tube chassis and light its set with the same esc and spur/ pinion and a novak 55t and it is a crawlin son of gun.should i ditch the heavyu chassis or change my esc/motor combo im thinking esc and motor but what is good for heavy truck? thanks guys for your input. |
06-13-2012, 01:17 AM | #2 |
RCC Addict Join Date: Oct 2011 Location: British Columbia
| Re: heavy crawler
Yeah, I'd send the chassis to the shelf. Too heavy and too high, IMO. Most of the guys building shafties are looking at 5lbs max and some are under that. If you can't see yourself scrapping the chassis, try a Holmes Hobbies Crawlmaster. A 16T version can handle that type of weight. My Wraith is 8.5 lbs with that exact motor and it handles it with ease. |
06-13-2012, 03:44 AM | #3 |
| Re: heavy crawler
I have the same chassis, and even the same color. lol. Mine weighs in at just under 6lbs. I used Losi shocks to get the COG down a bit and it seems to be working really well. Although a lighter chassis would be nice it does the job for sure.
06-13-2012, 06:11 PM | #4 |
| Re: heavy crawler
Thanks you guys. is the T in the 16t is that for "turn"? because i thought that going lower in turn was the wrong way. I will look up the HH 16t. and look at another chassis too. maybe find one cheap. i love the bodiless chassis' the most. any one with some more advice would be great. |
06-13-2012, 06:18 PM | #5 |
| Re: heavy crawler
the T does stand for Turn but the CrawlMasters have a different number of magnets so you can't judge speed/torque by that number. Go to his web site and look at the rpm info... I'd post it for ya but I'm on my cell phone... you may want to go a little higher. |
06-13-2012, 06:22 PM | #6 | |
Nobody Join Date: Sep 2008 Location: Maine
| Re: heavy crawler Quote:
Crawlmasters are a 5 segment armature with very similar characteristics to a standard 3 segment armature that has twice as many turns. A 16t 5 segment is similar to a 35 turn 3 segment. | |
06-13-2012, 06:27 PM | #7 |
| Re: heavy crawler
^^ yeah, that's the ticket! ^^
06-13-2012, 07:52 PM | #8 |
| Re: heavy crawler
so a 16t with a heavy unit like mine? is a 35 in reality. heat is my problem with a 45t and 12/87 so stay same gearing with a 16t?
heavy crawler - Similar Threads | ||||
Heavy crawler vs light crawler | holycaveman | General Crawlers | 31 | 02-06-2018 02:32 PM |
Heavy crawler? | rcdude | Newbie General | 4 | 08-21-2011 01:24 PM |
Another AX10 build - but it's not a crawler... ;) (warn-pic heavy) | beomagi | Axial AX-10 Scorpion | 3 | 06-18-2008 10:34 AM |
top-heavy TLT "crawler" | microgoat | Tamiya TLT Crawlers | 24 | 11-24-2005 05:43 AM |
