08-02-2012, 11:09 AM | #1 |
I wanna be Dave Join Date: Oct 2006 Location: Milwaukie OR
| ===The NEW CreationFab PREMIUM Delrin Tubes!!!===
Sneak peak of the new addition to the tube line. More to come soon as soon as I iron out some little details. This version should be stronger, easier to install, and use less hardware to keep the caster set This is just a proto, so dont mind the crappy finish. Purchase here. All wide tubes have been updated to the Premium Versions. CreationFab - CreationFab Parts Delrin Tubes With any luck, I will hopefully have these up on the site by sometime next week. Last edited by Chris_The_Battery_Man; 10-01-2012 at 10:25 PM. |
08-02-2012, 11:11 AM | #2 |
RCC Addict Join Date: Mar 2011 Location: Katy / west houston
| Re: ===The NEW CreationFab PREMIUM Delrin Tubes!!!===
Nice! |
08-02-2012, 11:55 AM | #3 |
Rock Crawler Join Date: Nov 2008 Location: The Lone Star State
Sweet!!! With all these new products looks like I'll be getting back into a AX10. |
08-02-2012, 01:12 PM | #4 |
RCC Addict Join Date: Apr 2009 Location: Token's life matters
Do you have any plans to offer this in Aluminum? I am thinking for 6s FOFF durability the AL would be perfect.
08-02-2012, 01:27 PM | #5 |
I could probably custom make something. It would give me a reason to push forward with the splining process I want to offer for bergs. Feel free to PM me if you want to figure something out
08-02-2012, 07:29 PM | #6 |
Rock Crawler Join Date: Mar 2010 Location: Hampton
The new product looks real good. My beef tubes are already starting to rust and I havent even got to run them yet. Aluminum would be a great option though.
08-02-2012, 08:36 PM | #7 |
I wanna be Dave Join Date: Mar 2009 Location: SW Missouri
I've been trying to decide what base to use for my new sporty build I'll be starting in a few weeks. I've given serious thought to doing a LCC or even a Creeper, but this may have just convinced me to go ahead and use my Axial axles. |
08-02-2012, 09:02 PM | #8 |
Rock Crawler Join Date: Sep 2008 Location: estacada
i am runnin some proto's of this design and have had zero issues. i had a set of his originals and kept spinning them even with 5 screws per side, amazing what 3s and a 13t crawlmaster will do |
08-04-2012, 10:53 AM | #9 |
Rock Stacker Join Date: Sep 2008 Location: Williamsport
Appears that you wont need to cut the axle housings?
08-04-2012, 10:22 PM | #10 |
Updates Finally.... I havent had time to post these on my site, or make a thread in the vendors section for these yet. For now, PM me for more info/prices. They will be more than the regular wide splined because of the extra time involved. But they will come with 4 3x6 button head stainless screws to hold em in These ones are pretty simple really. I had a tool cut to put an inside groove on the tube. This allows you to keep some of the ears, run 2 screws into the stock hole location, and rock-n-roll. No more need to set your caster. This will be set already. You will only need to drill the holes on the top and bottom to keep the chubs on. Those holes will not be drilled, so that you can set your caster where you want. You do need to cut a little off the end. Basically flush with the edge of the raised hole for the stock chub to screw into. From there, you sand down the ears and such to nearly flush. But leave some to take up the slack. I would recommend shaving some off a little at a time to make sure they fit nice and snug. You will also need to shave the inside bearing stop out completely for the tube to slide all the way through. I marked in silver where you need to trim/shave And now you're done. You can still put extra screws into the rest of the housing for safe measure, but I really dont think that will be needed. |
08-04-2012, 10:58 PM | #11 |
Chris...that's a lot cleaner/easier to use setup. I wouldn't mind another set to replace the ones I have since I didn't get the caster set exactly the same on either side |
08-05-2012, 01:16 AM | #12 |
Not a problem. Shoot me a PM. We can work something out. I could use some foams or something in trade |
08-05-2012, 07:16 PM | #13 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Nice job Chris, cant wait for them to arrive. It should give me close to a 6.5 pound C3 scaler.
08-05-2012, 10:35 PM | #14 |
Thats awsome! I need to order some of these |
08-06-2012, 11:09 AM | #15 |
| Re: ===The NEW CreationFab PREMIUM Delrin Tubes!!!=== |
08-06-2012, 02:53 PM | #16 |
Rock Stacker Join Date: May 2009 Location: French
I am interested in a pair for my AX10 sportsman |
08-09-2012, 08:43 PM | #17 |
RCC Addict Join Date: Jan 2010 Location: Dallas
I have been wanting to widen my stance some but have not wanted to put to much money in my sporty as my berg is really my true comp rig. That being said I had intended on playing with this some and finally got around to it. Well I can happily report that I am going to be able to keep my dlux weights, keep my chubs, and knuckles and be able to widen my front end.... I think. I wound up with a set of the axial exo cvd's and while the full cvd kit will not fit, the most important part will. The drive shaft looks like it will fit in the old cvd cup for the axial ax10 cvd's. I did order the wide tubes tonight and will get picks upon my build soon.
08-27-2012, 08:10 PM | #18 |
RCC Addict Join Date: Mar 2007 Location: Penngrove
Awesome design! I need to a pair of these on my Trail Tough FJ40 before champs!
08-28-2012, 04:03 PM | #19 |
Newbie Join Date: Dec 2011 Location: valley of the sunstroke, az
can someone confirm to a noob what i think i see is an axle beef up and clockable knuckles?
08-28-2012, 05:27 PM | #20 |
Rock Crawler Join Date: May 2007 Location: Glendora
===The NEW CreationFab PREMIUM Delrin Tubes!!!=== - Similar Threads | ||||
CreationFab Delrin AX10 Tubes =NEW STYLES= *NOW TAKING ORDERS* | Chris_The_Battery_Man | Axles, Trannys, T-case | 136 | 10-11-2015 10:48 PM |
CreationFab Delrin tubes! Put XR shafts AND AX10 R&P in your axle... | Chris_The_Battery_Man | Venom Creeper | 13 | 08-06-2012 12:11 PM |
CreationFab Delrin SCX10 upper spring retainers! | Chris_The_Battery_Man | Chassis and Suspension | 7 | 08-06-2012 11:13 AM |
CreationFab SCX10 Delrin upper spring retainer! | Chris_The_Battery_Man | General Crawlers | 10 | 06-26-2012 09:18 AM |
CreationFab delrin SCX10 upper spring retainer | Chris_The_Battery_Man | Axial XR10 | 15 | 06-25-2012 10:59 PM |
