02-01-2013, 01:29 PM | #1 |
Pebble Pounder Join Date: Apr 2012 Location: BritishColumbia
| Comp Sporty Build
so my ridge crest took a back seat. I am starting on a new sporty comp build. I got ax10 axils and sling shot chassis. Although this truck is a bit of a mutt i figured it would be best put in this thread. I still need a transmission, but is well on it way. If anyone has any advice or tips please let me know. i happy to get info on this chassis. lucas |
02-01-2013, 04:34 PM | #2 |
Rock Crawler Join Date: Jan 2007 Location: West Seneca
| Re: Comp Sporty Build
Ive always liked the slingshot chassis, and youre going to want either wheel wideners or different wheels those wraith wheels are a narrower offset.
02-01-2013, 05:26 PM | #3 |
What size of wheel wideners and what transmission should I go with?
06-04-2013, 01:26 PM | #4 |
Quarry Creeper Join Date: Jul 2011 Location: Hemet
i would say a stock axial ax10 tranny... and if you have some dough, buy the heavy duty outputs... if I was you, I would take the side posts of for the body and buy something ike gunnar body mounts... or make ur own vertical body mounts... I made some using 1/2 long bolts, and 1/4 cutting board... made the cross braces out of the cutting board, and drilled 2 holes in the cutting board for the bolts to go thru next to eachother... I only did it at the front so the rear of the body raises when I scrape over rocks so I don't get hung up on the body.... just my 2 cents
06-04-2013, 01:26 PM | #5 |
no idea what size of wideners or rims you should do
06-04-2013, 02:00 PM | #6 |
RCC Addict Join Date: Jul 2012 Location: Oreganastan
The stock XR10 beadlocks are a wider offset than those Wraith wheels. They add about 1/2" width per wheel. I don't know the vendor but here is a pic & a cheap price. Axial 2.2 Rocksters Beadlock Black Chrome AXI8095 [e7yexhBZ] - $6.64 : Site title Also looking at these: http://www.rpphobby.com/product_p/sypsc4.htm They can use VP SLW hubs so you can choose the offset you want. |
Comp Sporty Build - Similar Threads | ||||
Dutch AX10 sporty build | douwe | Axial AX-10 Scorpion | 232 | 11-29-2015 11:27 AM |
WaCkAdOoDlE Sporty build | Chris_The_Battery_Man | Axial AX-10 Scorpion | 55 | 02-19-2015 11:46 PM |
PhantomRS10's '13 Sporty build | PhantomRS10 | Axial AX-10 Scorpion | 12 | 03-20-2013 12:59 PM |
1st build - Sporty | AWDPete | Axial AX-10 Scorpion | 28 | 10-02-2012 04:45 PM |
