09-30-2013, 02:10 PM | #281 |
| Re: BOOSTED's 5th D sporty build ~Suckerpunch Sally2~ rebuild pg11
Looks good bruh. Let me know how those Ti spools hold up. My v1 AL spools seems pretty sloppy already |
09-30-2013, 09:18 PM | #282 |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
The spools seem like they should hold up fine I don't have any worries about them. Got everything finished up and took it out back for a little late night test run and the fxr seem to be glitching out pretty badly, so I tore it down swapped in the mamba micro I've been too lazy to put in. Man what a difference, in overall smoothness, drag break and size. I know I should have made the swap sooner as the fxr Db is weak and the bottom end is twitchy, but like I said. Too lazy Cleaned up the wiring and and mounted the esc and rx on top of the elec, tray and the bec underneath. Moved the tierod behind the axle, suprisingly it tucks away nicely Trucks feel damn better than ever, hopefully I can make to my clubs first comp on the 5th. Sorry for the shitty pics, lost a light in my garage. Last edited by boosted4lyf; 09-30-2013 at 09:24 PM. |
10-01-2013, 12:40 PM | #283 |
Looks good bromo Oh and how iwide are you outside to outside of tire? My truck got a little TLC lately and i'm at a nice 10.5" with full steering p.s. Your forearms are growing beards of their own Last edited by TSK; 10-01-2013 at 01:26 PM. |
10-01-2013, 01:18 PM | #284 |
E.Y. Designs Join Date: Sep 2011 Location: Springfield, OR
| Re: BOOSTED's 5th D sporty build ~Suckerpunch Sally2~ rebuild pg11 |
10-01-2013, 01:26 PM | #285 |
10-01-2013, 01:57 PM | #286 |
If I remember right just just a hair over 10.75" front and a touch over 10.5@ rear. Maybe. I've been playing with hubs and spacer to find a nice narrow width while still maintaining stability on sidehills and such. Oh and Trav. I know you fall into the while hairless Asian stereotype, so if want buddy I can send you some trimmings and ca glue and you could be bearded4RYF the island version |
10-01-2013, 02:16 PM | #287 | |
| Re: BOOSTED's 5th D sporty build ~Suckerpunch Sally2~ rebuild pg11 Quote:
10-02-2013, 03:00 PM | #288 |
I wanna be Dave Join Date: Dec 2006 Location: here
| Re: BOOSTED's 5th D sporty build ~Suckerpunch Sally2~ rebuild pg11 Lmao that's my arm I'll post a video soon.. Just not enough time in a day to edit.. I'll post any uncut video I have in this thread. If a man doesn't know his own hand no one will. Last edited by tapped-out; 10-02-2013 at 03:03 PM. |
10-02-2013, 03:05 PM | #289 |
10-03-2013, 04:55 PM | #290 |
I've received quite a few Pms about link lengths so I figured I'd post some finally numbers as I'm happy with the wheelbase which is 12.5 at rest and 12.5 squatted out. These numbers are using the Chaotic Crawlers ax10 upper link mount plates Found here: AX10 4 Link Plates I honestly can't send these guys enough love, nick and mark have outstanding customer service And hopefully with these numbers they can set you up with a bitchin set of Ti links Rear uppers 116mm Rear lowers 123mm Front uppers 90mm Front lowers 114mm I hope this helps you guys that are wondering and ill be posting this in the chassis thread as well. |
10-03-2013, 05:58 PM | #291 |
I am running 113mm front lowers and 129mm rear lowers and still an under 12.5 so whatever. Hahaha
10-03-2013, 06:10 PM | #292 |
10-03-2013, 06:13 PM | #293 |
| Re: BOOSTED's 5th D sporty build ~Suckerpunch Sally2~ rebuild pg11 I;m running 3.5" big bores though which don't have as much bump, so maybe that's why I end up short of 12.5" still.
10-03-2013, 06:41 PM | #294 |
Ya I knew you had big bores and that's where the difference came from
10-03-2013, 07:03 PM | #295 |
Big bore, short stroke. can't win em all |
10-16-2013, 03:31 PM | #296 |
Hey buddy thanks for filming my 2.2s run. As sexy as it is, I didn't like looking @ your ass every time I opened this video so I removed it. See I'm not gay. https://www.youtube.com/watch?v=DJTs...e_gdata_player Last edited by tapped-out; 10-17-2013 at 09:19 AM. |
10-16-2013, 03:39 PM | #297 |
10-16-2013, 04:35 PM | #298 |
Such a fantastic spotter and camera man.
BOOSTED's 5th D sporty build ~Suckerpunch Sally2~ rebuild pg11 - Similar Threads | ||||
Herbie Rides Again!! Sporty Rebuild Thread | alexchen86 | Axial AX-10 Scorpion | 65 | 03-28-2014 04:43 PM |
BOOSTED's 2014 build The 5th Dimension: MKII begins:pg 11 | boosted4lyf | EnRoute Berg | 239 | 10-10-2013 12:08 PM |
5TH Dimension Minimal berg rebuild | tapped-out | EnRoute Berg | 70 | 10-01-2013 02:40 AM |
the freak of nature (mr. flex) rebuild sporty | lowridinjuggalo | Axial AX-10 Scorpion | 21 | 12-01-2012 05:02 AM |
1st build - Sporty | AWDPete | Axial AX-10 Scorpion | 28 | 10-02-2012 04:45 PM |
