04-29-2013, 12:44 PM | #81 | |
I wanna be Dave Join Date: May 2009 Location: Tehachapi,Ca
| re: BOOSTED's 5th D sporty build ~Suckerpunch Sally2~ rebuild pg11 Quote:
Thanks Calvin, I appreciate ya hookin me up I know you're pretty busy getting ready to move | |
04-29-2013, 04:50 PM | #82 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
| re: BOOSTED's 5th D sporty build ~Suckerpunch Sally2~ rebuild pg11 |
04-29-2013, 05:03 PM | #83 |
Started on front uppers. grabbed some aluminum stock drilled and tapped to 4mm With the Revo rod ends eye2eye length is 81 mm. |
05-01-2013, 12:54 AM | #84 |
Got bored. Rollers done te to cut down some shocks |
05-01-2013, 04:47 PM | #85 |
Got the titanium idler shaft and slipper eliminator shaft installed I think aside from a different transmission case I can pretty much call this one built With the front shocks I replaced the shafts with a shaft from a 3 inch shock and removed just under a half inch from the shock body itself. Internally limited 7 mm Externally limited 3 mm Losi mini t green springs 25WT oil Since the chassis was meant to have a raked stance I didn't cut the shocks down in the rear Internally limited 9 mm Externally limited 3 mm Losi Mini t blue Springs 25 WT oil Also got my front drive line cut down and everything slapped back together Wait as of right now is 3 lbs. 14oz. That's including a body the knuckle weights and the weights inside of the dirty Harry's. I'm sure I could be down to almost 3 pounds even if I removed all that weight Ground clearance at highest point on the skid is 3 inches lowest point is 2.75 inches Last edited by boosted4lyf; 05-03-2013 at 04:31 PM. |
05-01-2013, 04:54 PM | #86 |
Sweet! Where'd you get that top shaft from? I've never seen one of those before...
05-01-2013, 04:55 PM | #87 |
Some old man |
05-01-2013, 04:56 PM | #88 | |
| re: BOOSTED's 5th D sporty build ~Suckerpunch Sally2~ rebuild pg11 Quote: | |
05-01-2013, 05:01 PM | #89 |
05-01-2013, 05:05 PM | #90 |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
05-01-2013, 05:07 PM | #91 |
Ya he does. But he's not here often I can pick one up for ya Saturday if ya want.
05-01-2013, 05:11 PM | #92 |
RCC Addict Join Date: Jan 2008 Location: Apple Valley,CA
Looking good Steve. That thing has got to be close to 30/70. The front shaft length is super short like JD's.................. attention span. With the links being so short in the front does it still articulate fine and no shaft binding or anything? He did a run of 50 I believe so he probably still has a few. |
05-01-2013, 05:12 PM | #93 |
Forgot to add this one earlier Cut shock next to Stock shock |
05-01-2013, 05:13 PM | #94 | |
05-01-2013, 05:15 PM | #95 | |
Jim...I have NO idea why you would say that my attention span is....YOU SEE THE SIZE OF DEM CHICKENS?!?! I now pronounce you...Curious George. | |
05-01-2013, 05:17 PM | #96 |
Man you guys are hard to understand. |
05-01-2013, 05:17 PM | #97 |
| re: BOOSTED's 5th D sporty build ~Suckerpunch Sally2~ rebuild pg11 Dentist gave you good meds huh?
05-01-2013, 05:23 PM | #98 |
05-01-2013, 05:24 PM | #99 |
05-01-2013, 05:24 PM | #100 |
Hey Steve, can you see if they still got any left, im interested I forgot to complement you on the rig too |
BOOSTED's 5th D sporty build ~Suckerpunch Sally2~ rebuild pg11 - Similar Threads | ||||
Herbie Rides Again!! Sporty Rebuild Thread | alexchen86 | Axial AX-10 Scorpion | 65 | 03-28-2014 04:43 PM |
BOOSTED's 2014 build The 5th Dimension: MKII begins:pg 11 | boosted4lyf | EnRoute Berg | 239 | 10-10-2013 12:08 PM |
5TH Dimension Minimal berg rebuild | tapped-out | EnRoute Berg | 70 | 10-01-2013 02:40 AM |
the freak of nature (mr. flex) rebuild sporty | lowridinjuggalo | Axial AX-10 Scorpion | 21 | 12-01-2012 05:02 AM |
1st build - Sporty | AWDPete | Axial AX-10 Scorpion | 28 | 10-02-2012 04:45 PM |
