06-26-2013, 12:28 AM | #1 |
| Hittman's El Niņo III
Time to get this build thread up. I was running that custom billet works chassis for a long time and it was working great for me. When I went to the AZ Shootout it had broke. It cracked on the fourth course and got completely destroyed on the 5th course. With the NM State Championships just two weeks after that I was nervous about getting a chassis in time. While in AZ I was truly impressed by the El Niņo.. And being a Chaotic guy myself the decision wasn't hard. I got it ordered up and got building. Through all my parts I had I was able to get some usable links for it and got it together. I finished it the day before I headed up to the State Championship.. I had only run it for 10 minutes in my garage and that was it.. For not really knowing the chassis, I must say this thing crawls! I ended up taking 1st place at the State Championship. I made it through the day with only one reverse and ended up with a -99 for the day. Second place finished with a -53 so I had a big lead all day. I will stop boring you and give you some specs: Chassis: Chaotic Crawler El Niņo III Axial scx plastic bodied shocks (rear normal, front internally limited) Front uppers - 4mm carbon links Rear uppers - shortened axial bent links Front lowers - T1e 60/40 Special Ops (yes the pro chassis) front lowers Rear lowers - custom 7075 bent aluminum hc links Dlux delrin sliders Front axle: Axial OD gears Grip fab SS Spool Vanquish xr knuckles and c's CW Crawlers steering arms Cut down xr universals Custom 1/8" tie rod Custom front Cf servo/batter plate made by me Cut down Dlux knuckle weights with 1/2 .3" weight ring Rear axle: BWD carbon fiber rear link mount Axial UD gears Grip fab Al. Spool Vanquish shock razors Tires/wheel: OTTSIX Voodoo's (Gold) Ytown lw 4 post glue on wheels BC-Brian Slim Shift hubs Front - CI comp cut 6" inners, CI 5.5" soft outter, CI 5"/5.5" soft tuning ring Rear - CI single stage medium, CI 5"/5.25" medium tuning ring Trans/driveline: Hot racing aluminum gears (lightened) Axial steel out drives (lightened) Lw aluminum middle gear shaft Robinson racing 87t spur 14t pinion stock case w/ brass insert mod Axial WB8 shafts with insert mod Electronics: Smashed castle sidewinder micro Castle bec set to 7.2v direct wired to servo Futaba 2106 receiver Hitec HS-7980 servo Holmes 30t custom pro Maxamps 430mah 3s lipos Misc: Shocks- Front - plastic scx, losi mrc silver spring, AlexG cf spring cups, 9mm internal limiters, 2mm external limiters, 25wt oil Rear - plastic scx, losi mini-t rear green spring, AlexG cf spring cups, 6mm external limiters, 25wt oil Custom fiber motor guard Custom fiber 7980 servo guard *coming soon* Rtr weight - 3lbs 8.4oz My fancy body I painted Front shot Body off Bottom shot Custom Fiber Motor guard Overall side shot showing links and placement I worked with BC Brian a while back and we came up with these Slim Shift hubs. They are equal to a 225 VP hub. Voodoo on the Ytown wheels Rear weight - 4.3oz Front weight - 4.0oz Last edited by Hittman; 06-26-2013 at 10:46 PM. |
06-26-2013, 12:29 AM | #2 |
| Re: Hittman's El Niņo III
Steering set up Dlux knuckle weights Front shocks Rear shocks Steering shot Front width - 11 1/16" Rear width - 10 7-8" Last edited by Hittman; 06-26-2013 at 12:34 AM. |
06-26-2013, 12:36 AM | #3 |
I do have to say thanks to all my sponsors! I couldn't do it without you guys! *The CW steering arms are awesome! They give just the right amount of steering and they are Über strong *The Custom Fiber motor guards and servo guards help protect those expensive electronics.. We spend enough on them, why not spend a little more to protect them *And the OTTSIX Voodoo's are just great. Going up there he set I had was brand new. I was a little worried but since we were comping on sandstone I wasn't sweating it. The new foam set is perfect for the weight. The right balance of support and softness. In almost every spot out there I could see where they excelled over the other tires ran. On my pro rig, they were the only tire to make the tricky 10th gate on course 1. The other tires sat ther and spun.. Once I got the right line and my rear tires lined up, the Voodoo's just walked the gate. On the sporty they give that little bit of added clearance. With this foam set up, they side hill like no other. Before states I was impressed with these tires.. After states, I am just astonished with them. I feel that they can be tuned for any terrain or environment. to you OTTSIX Last edited by Hittman; 06-26-2013 at 12:45 AM. |
06-26-2013, 11:46 AM | #4 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
Thanks man! Appreciate the good words I had someone ask if anyone had ever broken a 7075 arm. I said no but if it happened i'd gladly replace it |
06-26-2013, 03:19 PM | #5 |
Don't like the drag link. Do like the rear lowers. And I shaved off all the upturn tips of the shock mounts as I broke one and it's not really needed. Looks good |
06-26-2013, 10:41 PM | #6 |
Quarry Creeper Join Date: Mar 2012 Location: Living on the edge
Solid Rig man and Hella driving at states....Way to drive Bro. Cool Truck.
06-26-2013, 11:30 PM | #7 | |
| Re: Hittman's El Niņo III Quote:
06-27-2013, 12:02 AM | #8 | ||||
Good idea. I hadn't thought of that but I can see what you are sayin. Thank ya Quote:
But seriously, thank you for the kind words | ||||
06-27-2013, 12:05 AM | #9 |
Oh yeah.. I forgot this pic |
06-27-2013, 12:26 AM | #10 |
| Re: Hittman's El Niņo III |
06-27-2013, 12:27 AM | #11 |
06-27-2013, 01:21 AM | #12 |
Its a HARDKNOCKZ Life... Join Date: Feb 2011 Location: Southern Kali...
Rig's lookin good there Slim & congrats on the finish. You chose what I believe is the best sporty chassis available today but Im curious...why didn't you grab the Ti links from Chaotic? Or even a set of Ottsix Ice Links? I think the sporty platforms a great place for the slick surfaced links Ottsix has to offer. Keep up the good work & practice. You'll see a whole new caliber of course & driver come September...even more so than the AZ Shootout JD |
06-27-2013, 02:13 AM | #13 |
Rock Crawler Join Date: May 2012 Location: Australia
Nice work man. Im really loving how my el nino is working for me. It still impresses me every drive |
06-27-2013, 02:17 AM | #14 |
I've got a STUBBY! Join Date: Apr 2011 Location: Newcastle Australia
Great build What is your reasoning for staying with the standard width front housing instead of using long beeftubes? Josh |
06-27-2013, 03:21 AM | #15 | |||
When I ordered the chassis they were not in stock.. I needed a chassis within two weeks so I didn't have much of a choice other than use what I had. I have some ice links.. I might bend them up. Personally I think these work just fine.. The rear has stupid clearance and the front has a little added clearance. The geometry seems fine as well.. If I have something that I am happy with an it works great.. Why change it? Quote:
Just personal preference | |||
06-27-2013, 05:05 AM | #16 |
As with all ur builds slim jim, very impressive build and great driving! (In ur state) eww burn... lmao! Seriously tho always a step up on ur custom parts and appreciating for ur rig and sponsors. Keep up the driving. Some fresh Custom Fiber for nats is in order and on the works bench for ya.. :thumbup::cool: |
06-28-2013, 10:18 AM | #17 | |
07-14-2013, 11:29 PM | #18 |
New wheels! These are Dlux g10 wheels. They are light and the quality is second to none. I chose to get the wheels with 7/8" cross braces. A little narrower than I am used to but it isn't a huge difference so I should be fine. And yes, I am running three cross braces. I am sure Erik would highly advise against it but I think it's fine. There is very little flex in the wheel only using three braces. With all six braces and aluminum hardware, each wheel weighs in at 18g. My wheels with three cross braces and aluminum hardware weigh in at 14g. Not a huge loss, but if there arnt strength issues, it is worth it in my eyes. Backside New tire shape. The front stayed the same, but the rears rounded out a little. This is with the same foam setup as before. Front on left, rear on right. I am unsure of the mounted up weight. I will get that, and a few pics of them on the rig tomorrow |
07-15-2013, 09:35 AM | #19 |
Pebble Pounder Join Date: Jun 2009 Location: totowa
Very nice build been looking at this chassis myself
07-15-2013, 11:18 AM | #20 |
Hittman's El Niņo III - Similar Threads | ||||
Hittman's SMASH Build | Hittman | Axial XR10 | 994 | 02-28-2015 09:21 AM |
***HARDKNOCKZ El Nino III*** | HARDKNOCKZ | Axial AX-10 Scorpion | 208 | 03-23-2014 11:39 PM |
Hittman's Featherweight Sporty | Hittman | Axial AX-10 Scorpion | 104 | 05-19-2013 09:08 PM |
°°° HARDKNOCKZ El Nino III Flick °°° | HARDKNOCKZ | Videos! | 3 | 04-26-2013 06:45 PM |
Hittman's mini | Hittman | Losi Mini-Rock Crawler | 17 | 10-01-2012 07:00 PM |
