Thread: Another CCC Boxer Sporty
Old 04-05-2015, 02:00 PM   #1
Default Another CCC Boxer Sporty
Hi there,
I'm opening a thread to show you my little sporty build.
This truck will be based on ClassiCutCustoms products :
- CCC boxer 2.2S chassis
- CCC Ti lower and upper links
- CCC front servo plate + CCC electronic tray
- CCC rear upper link plate
- CCC bulldog tranny + AL spool and main Ti Shaft
Thanks Barry for all the advices, availability and excellent products
This truck will be comp ready, no doubt
This truck will be powered by a Team Brood 30T CONFLUX motor with all Team Brood goodies on it
For sure, I'll have RcBro items on it too : Rcbro beef tubes, steering arms, double ear weigth holders, ...
Teaser pix
Bergm@n is offline   Reply With Quote
Old 04-07-2015, 07:42 AM   #2
Default Re: Another CCC Boxer Sporty
Great start there Bergm@n! It sounds like you have been having fun making parts on your lathe
ClassiCutCustoms is offline   Reply With Quote
Old 04-07-2015, 01:36 PM   #3
Yes Barry, I'm having fun with the small lathe
I've worked on my BB : 2 rear ones on the left
- Rc Bro springs
- 30 WT oil to start with
Old 04-07-2015, 01:38 PM   #4
Very nice Sir! May I suggest you turn the bodies too? It makes them look so smooth!
Old 04-07-2015, 02:43 PM   #5
Yes Boss, bodies will be lathed down in few weeks ;) it's on the TODO list but on the less important things side
Old 04-08-2015, 11:43 AM   #6
Now ... the main shaft of the tranny ...
It was useless for me to do it but I like doing useless things
What about AL 1 piece spool/shaft ?
It would be maybe 1g lighter than the CCC one and for sure, it will have less strength than the main CCC Ti shaft, but I want to play
Let's start !
One side done
Among the chips
After / Before
Draft version, trying to figure out a drilling help to center the drill bit
Test fitting in the CCC Bulldog tranny
Old 04-08-2015, 12:04 PM   #7
Beautiful work with the lathe. Yes I too have made a one piece locker from 7075 and the results were not worth the efforts. Sometimes just the fun is in trying new things and I understand that too!
Old 04-09-2015, 01:20 PM   #8
Time to speak about ... wheels and share some pix of these beauties
Playing with screws
Old 04-09-2015, 01:25 PM   #9
Very nice! Bling bling!
Old 04-09-2015, 01:49 PM   #10
Front axle is almost done ...
Specs of front axle :
- OD axial gears
- Felsenfest Zero Slop spool by Egressor
- FastEddy bearings
- XR10 axleshafts
- RcBro al burly splinned tubes
- Wraith VP Chubs
- Wraith VP Knuckles
- RcBro KW holder + Tungsten weight holder
- CCC plate and servo mount
- 7950TH servo
- 3mm Ti steering rods
I'm just missing Chub screws, waiting for final position ...
Rcbro al steering arms soon in the mail
Old 04-09-2015, 02:58 PM   #11
very nice
david511 is offline   Reply With Quote
Old 04-09-2015, 06:24 PM   #12
Nice DesTroy plate!
Good looking parts list, as well...
winnerone23 is offline   Reply With Quote
Old 04-09-2015, 06:34 PM   #13
Nice build!!! Do you think it is possible to have more pics of your destroy plate, i am building my shafty at this time and use the same destroy plate and would like to see the final result. Thanks
pyranahryder is offline   Reply With Quote
Old 04-09-2015, 11:15 PM   #14
Nice build
Couldn't you put à pic of the Tungsten weight holder ?
Could you tell us where to find them please ?
Thanks.
pat13 is offline   Reply With Quote
Old 04-10-2015, 12:24 AM   #15
look at pat-store
Old 04-10-2015, 01:07 PM   #16
Thanks for the kind words dudes!
Yes I will post more pix of the plate soon ;)
Pat31, these come from ytown web site.
Old 04-11-2015, 02:08 PM   #17
Playing with the tranny shaft length ...
I'll end up a little longer than this one and put SDI driveshaft front and rear
Some words about the rear axle :
- UD axial gears
- FastEddy bearings
- CreeperBob Ti axleshafts
- ax10 plastic lockouts
- CCC rear plate
Old 04-16-2015, 02:52 PM   #18
hi Folks
Oh ... Yes ... I think I got it rolling
Time to show some pix of this babe :
Kind of steering
Old 04-16-2015, 02:57 PM   #19
Wow! That looks amazing Bergm@n. Who needs that much steering?? Lol. You have set a high standard for Crawllife..... I hope he can keep up!
Old 04-16-2015, 03:09 PM   #20
You may ask about weight ...
We will speak about it ...
Here is the weight with 60.5/39.5 bias :
3.3 lbs RTR with 500mAh Brood lipo and 1 oz KW on each side
Now I have to drive it, make some small tuning and spend some time on the body
Another CCC Boxer Sporty - Similar Threads
Boxer sporty for huskerfan406 huskerfan406 Axial AX-10 Scorpion 32 12-07-2019 09:52 AM
boxer CCC david511 Axial AX-10 Scorpion 20 08-23-2016 01:39 PM
Boxer Sporty Build all24 Axial AX-10 Scorpion 30 10-20-2014 04:04 PM
