12-04-2013, 03:18 PM | #1 |
Pebble Pounder Join Date: Jul 2012 Location: Crawlerado Springs
| SSS-Revival
I built this rig several months ago and have just crawled the crap out of the poor thing! I swapped controllers with a co-worker of mine one day, and he promptly (not intentionally) drove it off a 12' cliff. Since I am waiting for a new control arm I decided it was way past due to show the poor thing some love. What it is now.. Billet Works Design SSS-R (awesome value, great performer) Hitec 7950 Holmes Hobbies Torquemaster Sport 35t with Hand wound armature added Axial od/ud gears Ax10 housings Creation fab tubes Crawler innovations DD Foams Hot Bodies white dot Rovers (shaved) XR10 steering conversion (universals, c-hubs, knuckles, zero Ackermann arms) Stampede shafts Parma Xciter body (when the sexy BWD Dub Topper is not in place) Gunnar mounts Castle Creations Sv2 ESC Castle Creations BEC Flysky gt3b Narrowed axial Beadlocks What needs to be done... Obviously the control arm Fast Eddy Bearings throughout Locked Up RC slipper eliminator Motor inspected Re-make the steering linkage (when I first made it I did not realize the bolt I welded on to the tie rod was not 3mm like I wanted OOOPS) Tidy up some wiring (Something I suck at) Lube everything again. Good thing my crawler is not one of my kids or I would be in the "Grey Bar Motel" for neglect Parts incoming. Will post pics of progress |
12-04-2013, 04:14 PM | #2 |
Rock Crawler Join Date: Feb 2013 Location: york
Sweet rig how wide is the front axle outside of tire to outside of tire
12-04-2013, 04:37 PM | #3 |
| Re: SSS-Revival Thanks Chris! Not super custom like yours though! It is a shade under 12" depending how flat spotted the tires currently are.
12-04-2013, 08:23 PM | #4 |
That sucks bout ur rear lower man.. I love this chassis, its an amazing performer! I ran the same setup before goin with the sss-rs in CF. Same chassis, just an extra row of holes to mount the shocks too. So far last season and the first half of this season, its Killing it! Bwd makes one hell of a rig. I also run a mini mantis in 1.9 class(which I'm keeping)... Can't wait to see where you take ur build.. |
12-04-2013, 08:36 PM | #5 |
I wanna be Dave Join Date: Dec 2008 Location: anderson
| Re: SSS-Revival
only good thing is I think you still can get parts for that thing from bwd
12-04-2013, 09:23 PM | #6 | |
| Re: SSS-Revival Quote:
Not sure for how long but Don was more than helpful in getting me a replacement on the way. | |
12-04-2013, 09:38 PM | #7 |
| Re: SSS-Revival
Did get a little bit done. Tore the motor and transmission apart I am no expert so let me know if you spot something with the motor I missed. The brushes had lots of life and the comm looks to have little wear since last machining and did not see any signs of extreme heat Slipper clutch has seen better days. Time for the crutch to go bye bye. Had it so tight it never slipped anymore anyway |
12-08-2013, 11:32 AM | #8 |
| Re: SSS-Revival
Was a little slow at work so I roughed out a knuckle weight hanger. I later heard that RcBros has a really good price on their hangers. Took me all of about a minute on their web site to decide that was a better way to. I am still going to try go with a clutch pilot bushing just so I can say "I made those" Will post pics as parts come in. |
12-08-2013, 12:34 PM | #9 |
I wanna be Dave Join Date: Jun 2007 Location: Earth
| Re: SSS-Revival
Those rear lowers should land there first of the week. |
12-08-2013, 01:35 PM | #10 |
| Re: SSS-Revival
As Always Don, top notch service and Fast shipping! The sss chassis is a killer setup! Without or with shocks. I just spent all the loot on building a second set of axles for my new chassis, just so I didn't have to pull mine apart.. its a "dream" alright, everytime it makes a climb and ur smiling ear to ear |
12-08-2013, 02:25 PM | #11 | |
| Re: SSS-Revival YAY! Thank you. One segment of the Colorado Winter Series is scheduled for the 15th, and if it is somewhere close to home I will put the rebuild on hold and participate. Sure it wont have the upgrades completed yet but I am dying to see how my rig and skills compare. Quote:
12-15-2013, 05:43 PM | #12 |
| Re: SSS-Revival
Been a bit of a wrench fest around here. With a comp coming up shortly I sorta ran out of time. Don got my control arms to me just like he said. My Locked Up RC slipper eliminator arrived, and some Fast Eddy Bearings. So I quickly got to work rebuilding the transmission and both differentials. You would think as an Automotive Technician I would be a lot better about preventative maintenance but I digress. I replaced all the bearings, lubed it all up and tossed in the slipper eliminator. Then put the whole thing back together so I could make the comp. Which sadly was cancelled! So now to take it apart again and continue with the rebuild. RcBros Weight Hangers showed up yesterday but I am having a heck of a time finding the right sized pilot bushing. Will hopefully get to the knuckle weights on Wednesday. Need to finish a bit of shopping and what seems like a ton of wrapping so who knows.........
12-16-2013, 03:42 PM | #13 |
RCC Addict Join Date: Oct 2009 Location: San Francisco
| Re: SSS-Revival
looks good on the rig. I personally never ran a slipper since it was more of a nightmare chasing it down to tighten it than anything. Best of luck on the rig and don't go driving off any more cliffs! If you keep breaking the arms consider getting a pair made in glass filled Delrin. It weighs more and may not slide as well but should be tough as heck |
12-21-2013, 08:34 PM | #14 | |
12-21-2013, 09:20 PM | #15 |
| Re: SSS-Revival
I did get my knuckle weights made. Couple minor problems. The rims on my SSS-R wont clear them, and they are currently on my Ridgecrest. The Ridge has rims that will clear the knuckle weights and has the same knuckles as my SSS-R. Once I get some rims for the crawler I will put the knuckle weights on it. The Ridge is just a basher and has no need for them. The pilot bushings I came up with were not really what I wanted. They are brass impregnated alloy of some sort, and about a 1/4in too large in diameter. So had to machine them down to 1.6in od and drill out the middle to .750in id. Drill and tap for a couple mounting screws and done. They came out pretty well and the cost was right. I will toss them on the scale before I mount them but I am expecting them be right at 3oz each. I also got a set of blue dot Voodoos to run once I get some rims. These things are sticky! And not even their sticky compound! I can see why all the cool kids run them. I can't wait to see how they grip the sandstone we normally crawl on. Will post updates of course. They have the reputation for not disappointing and I am sure I will be no different. Last edited by Scocrawler; 12-22-2013 at 10:26 AM. |
12-22-2013, 10:22 AM | #16 |
| Re: SSS-Revival "They have the reputation for disappointing and I am sure I will be no different." ...they do? |
12-22-2013, 10:28 AM | #17 |
| Re: SSS-Revival
Terribly sorry! Edited. These tires are going to be insane! I AM VERY EXCITED
SSS-Revival - Similar Threads | ||||
Phoenix revival | losikid | Team Losi Comp Crawler | 14 | 10-08-2013 06:25 PM |
Joe's flatty The revival! | Metal Masher | 2.2 Scale Rigs | 125 | 12-18-2012 08:48 PM |
old thread revival? | Hounddad | Newbie General | 11 | 01-16-2012 10:32 AM |
NTXRCC Scalers revival | Lankenstein | Texas | 5 | 12-10-2010 12:34 PM |
Help In Revival Of A Nylint | wheely king | General Crawlers | 5 | 02-20-2008 02:52 PM |
