07-10-2014, 11:44 PM | #1 |
Quarry Creeper Join Date: Jan 2012 Location: Durango
| Programming a DX4C for 4ws for my AX10
Hey guys, I am usually on the wraith section but I got two ax10s in a trade and took one apart and the other I made it 4ws. I just bought a Spektrum DX4C and I can get it to either do traditional 4ws or crabwalking, I can not get it to lock the rear and keep the front steering. Any idea? Thanks
07-13-2014, 02:39 PM | #2 |
Rock Crawler Join Date: May 2008 Location: The Beautiful South
| Re: Programming a DX4C for 4ws for my AX10
go to the reverse menu and reverse the aux channel? assuming your mix is throttle and aux channel.
07-28-2014, 11:44 AM | #3 |
Quarry Creeper Join Date: Oct 2012 Location: Cashmere (central WA)
set the MIX on the rear servo cannel : 0% - 0% (top mix) 100% - 100% (bottom mix) (may have to swap them) in the one position it will 4WS and in other it will center am still trying to figure out how to get all 4WS/Crab/Center to work |
07-28-2014, 04:24 PM | #4 |
| Re: Programming a DX4C for 4ws for my AX10 Is it different than the 4s? It looks pretty clear cut on the menu but I havent tried it.
07-28-2014, 04:44 PM | #5 |
Quarry Creeper Join Date: May 2012 Location: vernon bc
Yes this radio is different then the 4s or 4r the 4c will not 4ws crab and straight on the rear axle. I just bought a 4c and called horizon and asked and he said I would need the 4s or 4r if I wanted to be able to switch between more then two types of steering
07-30-2014, 11:59 AM | #6 |
you can set rear servo as 3 position, and have non-liniar crab/4ws/strait The DX4S has special program that has 4WS option all set up - ???? don't know why it isn't included in the DX4C other than $$$ http://www.spektrumrc.com/ProdInfo/F..._update_EN.pdf . Last edited by Pat M; 07-30-2014 at 12:02 PM. |
07-30-2014, 12:51 PM | #7 | |
| Re: Programming a DX4C for 4ws for my AX10 Quote:
07-30-2014, 08:28 PM | #8 |
have done these seperate setups: 3 position winch (Heyok 3pos controler) , and 3 position rear stear full 4WS/nutral/full Crab 3 position winch (Heyok 3pos controler) , and linier 4WS with nutral 3 position winch (Heyok 3pos controler) , and linier Crab with nutral 3 position winch (Heyok 3pos controler) , linier 4WS/NO nutral/ linier Crab X2 3 position winches using x2 Heyok 3pos controlers |
Programming a DX4C for 4ws for my AX10 - Similar Threads | ||||
New 4 channel Spektrum, Dx4c | indyducati | Electronics | 36 | 03-18-2015 10:46 PM |
Programming my Spektrum DX6i for 4WS on my Axial Wraith | Kobier | Electronics | 0 | 01-13-2012 12:56 AM |
Programming a 4PL for 4WS and Winch | Harley | Axial Wraith | 15 | 12-05-2011 11:01 AM |
