12-31-2014, 01:18 AM | #1 |
Rock Stacker Join Date: May 2014 Location: Australia
| Plastic housings
Hi I have just built up a sportsman crawler for the start of the 2015 season and am having a heap of issues with the front axle The axle is a plastic ax10 axle housing with brass burly tubes and xr10 universals The problem I had was one of the tubes pulled the two screws holding it in place while driving around the house so I fixed that by adding two extra screws to each tube through the housing as well as adding longer screws to the ends of the housing through the collars But while out testing for the first time I came across another problem This is that for some reason, the tubes are rotating just enough in the housings for me to notice that the c hubs are out of alignment My screws have all been lock tited in place Does anyone know what is causing this and how to fix it? I think I will have to go to aluminium housings so they hold the screws better Thanks heaps Jayden |
12-31-2014, 06:21 AM | #2 |
Rock Crawler Join Date: Feb 2013 Location: york
| Re: Plastic housings
It sounds like your screws are to long and are touching the universals or you have a binding issue some where. You should dis assemble the axle to find the culprit
12-31-2014, 07:47 AM | #3 | |
| Re: Plastic housings Quote:
Good to see you posting again mang! Anyways.. I agree. Sounds like ur longer screw's are a little too long maybe.. Try backing the longer screw's out just a little at a time. When things are spinning smoothly, you'll know how much shorter ur screw's need to be. I don't think an aluminum axle case is need. It's just Heavy! I run the stock housing and delrin tubes, without issue, when everything is put together right. A little axle research is the way to go. | |
12-31-2014, 10:15 AM | #4 |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
As mentioned, longer screws may by needed, or longer screws depending on whats needed. Just make sure the screws are actually engaging and threaded into the burly tube. Ive had some customers swear they drilled and tapped the tube later to find out all they did was wallow out the hole and the screw isn't secured to any material. Both scalers and sportys alike, a single well placed and secured screw should be enough some like to do one on each side of the inner housing to be certain. |
12-31-2014, 08:17 PM | #5 | |
Quarry Creeper Join Date: Feb 2009 Location: Rockaway
This happened to me with a couple of screws. They were fully seated into the housing but wouldn't engage the tube. After a little patience I was able to get them tight but it was a P.I.A. I also have one on each side of the inner housing like Mr. Bro suggests. | |
01-03-2015, 02:41 AM | #6 |
Hi guys Thanks for the replies After much testing and pulling apart I found the culprit of my mis aligned c hubs... The problem was not within in the tubes them selves but with in the c hubs The problem was that the play in the c hub splines caused the c hubs to mis align with use So I fixed this my adding another screw in the very back of the c hub slot to punch the c hubs back so they had no more play on the tubes Thanks for the help Jayden |
Plastic housings - Similar Threads | ||||
Metal or Plastic Axle Housings? | YellowRabbit | Newbie General | 7 | 02-04-2014 09:26 PM |
Housings | CronusTRD | Tamiya TLT Crawlers | 3 | 03-02-2009 12:06 PM |
Need to know the best plastic on plastic friction reducer. | TurboB18C | Chit Chat | 2 | 04-06-2005 04:28 PM |
