01-11-2015, 02:03 AM | #1 |
Pebble Pounder Join Date: Nov 2010 Location: Spain
| Custom gearbox?
Hello. Iīm thinking about build my own gearbox, but I donīt understand why everybody use XR gears. If you use 2 unit of XR gears 12/36, the 36 gear for the shaft (from XR) and a pinion of 12T you get a reduction of 27:1. But new with the stock tranny from axial I get a reducction of 18.6:1 (2.6:1 from the tranny and a 7.1:1 from the pinion and the 86 spur). So, with these XR pinions we have a bigger reduction than with the stock tranny. Are my numerical operations correct? Or am I doing some thing wrong? Thank you!! |
01-11-2015, 02:52 AM | #2 |
Rock Crawler Join Date: May 2012 Location: Australia
| Re: Custom gearbox?
Reduction In gears gives greater torque Match this torque with a higher speed motor and you have a really good combination for crawling. |
01-11-2015, 03:45 AM | #3 |
| Re: Custom gearbox?
Ok, you are right. But now I have another question...What motor could I need for this kind of gearbox? Thank you. |
01-11-2015, 03:11 PM | #4 |
| Re: Custom gearbox?
I've used 2 of the hulksta transmissions Both have been with 30t motors. Both have great wheel speed on the ax10 platform. Using a 18-20t pinion |
01-12-2015, 11:59 AM | #5 |
Rock Stacker Join Date: Aug 2010 Location: truckee
| Re: Custom gearbox?
Also consider when xr gears (or similar ) are used, there is no more big fat spur gear anymore.
01-12-2015, 05:45 PM | #6 |
RCC Addict Join Date: Mar 2011 Location: Way out there!
| Re: Custom gearbox?
Gotta love a space saver. Who doesn't have a set of stock XR gears laying around. Sure can't use them in an xr for long.
Custom gearbox? - Similar Threads | ||||
Gearbox problems.... | CTPATRIOT | Axial AX10 2nd-gen | 6 | 11-09-2012 06:40 PM |
1/6 scale jeep with custom cordless drill gearbox | klem klubfoot | Scale Videos! | 2 | 07-31-2012 06:35 AM |
Custom Gearbox Ratios........... | ap714 | General Crawlers | 0 | 03-02-2006 07:06 PM |
Making your own gearbox.... | MrPhantom | General Crawlers | 11 | 12-25-2005 09:43 PM |
