02-05-2015, 02:15 PM | #1 |
Rock Stacker Join Date: Aug 2010 Location: truckee
| suspension setup help
Building my first 2.2 sportsman and can't find a good thread on setting up the chassis. I made a wheelbase jig and need to know how to set up for a 45/55 bias. It's a joker chassis. I have the axles set at 12. and was going to set up at full compression but not sure if I should set the chassis on the ground or set it on the same plane as the center of the diffs? Next do I set the chassis centerline at the center of the 12.5 wb or do I move it for a 45/55 bias, or is that wrong? Don't really need an explanation of how suspension works just how to set the chassis so I can make links. Thanx
02-07-2015, 04:35 AM | #2 |
Rock Crawler Join Date: Jun 2011 Location: San Diego
| Re: suspension setup help
Make it so it's 12.5" when it's as long as it will get. Have the eyelets of the links at the same height, so put the chassis at axle height.
suspension setup help - Similar Threads | ||||
Best suspension setup I've seen! | Bluebox | Axial Wraith | 21 | 04-29-2013 09:23 AM |
suspension setup? | cliffdawg | Team Losi Comp Crawler | 5 | 04-11-2010 10:00 AM |
Suspension setup help | Joush | Losi Mini-Rock Crawler | 12 | 08-03-2009 09:16 PM |
Suspension Setup | Steve182 | Tamiya CR-01 | 2 | 09-10-2008 12:35 PM |
My suspension setup | fetish | General Crawlers | 4 | 10-15-2007 05:31 PM |
