Thread: To much flex?
Old 04-12-2017, 09:12 PM   #1
Default To much flex?
I've been doing some home made mods to my ax10 to get rid of slop and movement in some areas and change of weight. But I'm now getting the lower lions and wheels hitting the shocks.
Was thinking of putting some machined stops in the shocks over the shaft to reduce the amount of flex which will also stop the lower links hitting them.
Will this cause over issues?
Sent from my A1601 using Tapatalk
nurgs is offline   Reply With Quote
Old 04-12-2017, 09:16 PM   #2
Default Re: To much flex?
Yes, too much flex.
AngelowDoom is offline   Reply With Quote
Old 04-12-2017, 09:22 PM   #3
Best fix? Or how to reduce it?
Old 04-12-2017, 09:53 PM   #4
Damn that's an OG rig right there
Nitro fuel tubing works well to limit shocks inside or out and acts as a bumpstop.
Cheap performance mods would be to put an scx10 skid on there. It has a better profile to slide over obstacles and it provides triangulation to the lower links. Lose the Y upper links too in favor of independent uppers.
I have some scx/ax10 link plates I'd mail you if you want them. Carbon fiber front and G10 fiberglass rear, yours for the taking.
WHITE-TRASH is offline   Reply With Quote
Old 04-12-2017, 10:01 PM   #5
I did make some of my own yet to test them. Lol hey it's a working progress and my first rc ever so I'm learning.
Was going to machine up some aluminium to fit in the shocks
Old 04-13-2017, 01:15 AM   #6
Would do what white thrash suggests. Maybe his plates allow for the battery to be mounted on the axle.
My guess is that the springs is a bit stiff also. At least if they have the spring go that they came with new.
For the scorpion I like the stock shocks (same as Wraith) just move the bumpstop inside to make them a little bit shorter, and replace springs with the softer hpi 6590 springs. To avoid rubbing on the front springs, it is smart to widen it a bit with a wheel widener rc4wd has a good one that widens it 12mm.
Old 04-13-2017, 07:48 AM   #7
The springs are rather soft the start compresing with very little weight on them
Old 04-13-2017, 11:23 AM   #8
Then they probably have been changed to the softer ones. Is there a green mark on the springs?
Old 04-13-2017, 12:57 PM   #9
Natedog's Avatar
X2, yes too much flex and get the battery down on the axle plate.
YOu're headed the right direction, trying stuff and having fun, that's what counts.
Old 04-13-2017, 01:36 PM   #10
that is an OG rig right there....very nice.
check the sticky for AX-10 tips and tricks. has a lot of great tips and tricks in there.
jason1973 is offline   Reply With Quote
Old 04-13-2017, 06:11 PM   #11
Problem with moving the battery is it's for my 4 year old son and he runs it with nimh so they are to big and mount up top.
It seem I have been able to almost completely reduce the touqe twist going forward but when I go back it's a little crazy with how high the rear right wheel lifts off the ground
Old 04-14-2017, 03:26 AM   #12
I'm faceing the same issue with little Betty. The parameters to control the flex are stiffness of the springs and shock travel right?
The og shocks are not adjustable and 128mm (eye to eye), which length would be better, using the og chassis, without loosing too much ground clearence?
Gesendet von meinem Nexus 5 mit Tapatalk
magic_yeti is offline   Reply With Quote
Old 04-14-2017, 04:00 AM   #13
I thinking I will put a limiter on the shock shaft out side to limit the travel in the shocks. I figured if I put it over the shaft on the inside of the shock body it will reduce my ground clearance to much.
Old 04-14-2017, 10:33 AM   #14
check your springs.
like i said that sticky says a lot. twist was one of the biggest issues when this came out and tyere are ways to get rid of it.
good luck.
Old 04-14-2017, 12:29 PM   #15
5th D Owner/Driver
cboggs's Avatar
Link geometry plays a big part in getting rid of almost all the torque twist. A proper setup rig will not have to run stiff springs and limit shocks when your links are correct. Try to get more triangulation on your lowers, moving the links on the skid towards the center.
cboggs is offline   Reply With Quote
To much flex? - Similar Threads
How much flex is enough mindless HPI Wheely King 13 12-28-2022 05:38 PM
more flex Moparguy 1.9 Scale Rigs 5 01-21-2011 12:42 PM
How to get more flex 98sierra Axial SCX-10 25 01-13-2011 09:26 PM
Will this get me more flex? rwagner Losi Mini-Rock Crawler 3 12-30-2010 11:13 PM
flex!!! toyota man General Crawlers 13 05-18-2006 02:20 AM
