01-27-2008, 07:10 PM | #221 |
Newbie Join Date: Jan 2008 Location: Central Coast
| basically stock
AX10 Integy 80s motor Traxxas XL-5 ESC JR XR3i radio Futaba S3305 servos 10t pinion bodies Betty and stock Turbo Optima dove tailed Jeep Cj, VW stock tire & wheels Fab work strip/drill chassis and links strip flip drill & slot top plate made new bottom plate "Nerf Pods" (just to be different, goin inside w/ links works) set up for full time rear steer normal/crab (way too much fun) shorten/lengthen servo wires (not too much fun) drive shaft brass tubes and top collars drill tap and bend 1/4' alum tube for bent lower links used stock bottom plate for RX custom servo mounts custom split battery mounts mod battery for saddle mounting drill shock pistons add 3/32" hole 30wt oil (going to 1000 w/ soft springs) mod radio handle 'c' button for direct menu acces/rear servo switching on the fly motor flip to do longer servo mounts for upper link mounting fix it as it breaks Last edited by AnEv942; 11-27-2017 at 12:11 PM. Reason: Stupid photobucket fiasco |
01-28-2008, 08:27 PM | #222 |
Quarry Creeper Join Date: Nov 2007 Location: Lakewood-Crawlerado
| my ax10
been working on this since november novak rooster crawler esc integy 55t tq2 (tq3 on it's way) some sort of hobbico servo (works great though) homade delrin links, skid plate, 4-link lexan upper link mounts grappler body losi soper soft springs coper plumbing bushings on drive shafts radio tray made from old battery mounting relocated body posts 50wt oil in left rear shock 6 cell saddle pack works great, almost no tourque twist, very low cg, blackjack, hc links,dig and maybe brushless on the way |
01-28-2008, 08:39 PM | #223 |
RCC Addict Join Date: Nov 2007 Location: CALI "209"
My Trail/Crawler ax10 moded New Bright rock crawler body made to fit my scorpion |
01-29-2008, 07:41 AM | #224 |
Pebble Pounder Join Date: Jan 2008 Location: winston-salem
| prettyt much factory except grooved/cut rock lizards |
01-30-2008, 04:38 PM | #225 |
Newbie Join Date: Dec 2007 Location: Peabody
My AX-10 specs. -Novak Rooster -Hitec metal gear high torque -JR XR3i -integy 55t -modded skid plate and link mounts -Pro line Moabs -Semi droop, probably go back to outer spring mounts (an awesome setup is only as good as it's driver.....(and I suck .......for now) -TCS boomerangs front and rear -homemade saddle packs -HPI Rubicon and Pro-line Harddrive bodies |
01-30-2008, 06:07 PM | #226 |
Newbie Join Date: Jan 2008 Location: Salem
heres mine: stock chassis tcs internal "medium" shock springs shock spacer inside shock for lowered ride hieght integy 65t lathe links de anodized and polished mounted inside chassis proline masher m2's hpi deep offset wheels proline f250 body novak super rooster Hitec 645 stick and saddle pack mounts on front axle. balanced chassis(highly suggested) The flex shot: Last edited by CeeBlock; 01-30-2008 at 06:15 PM. |
01-31-2008, 11:19 AM | #227 |
Pebble Pounder Join Date: Jan 2008 Location: nowhere near the HAMMERS!!
| THIS IS MY BEHIND FRONT AXEL STEERING |
02-01-2008, 03:39 PM | #228 |
Quarry Creeper Join Date: Dec 2007 Location: St. Louis
Ax10 Rooster Crawler esc/motor combo Hitec 645 Traxxas tq3 and receiver 4 link frnt/rear (bent) Moab 2.2 M2's Stage 2 kit on its way Last edited by Nacho; 02-01-2008 at 03:59 PM. |
02-01-2008, 03:49 PM | #229 |
| Hey guys, as fun as deleting posts is, please stop posting chit chat or questions in this thread. Last edited by EeePee; 02-08-2008 at 09:39 PM. |
02-01-2008, 06:58 PM | #230 |
Rock Crawler Join Date: Jan 2008 Location: Vancouver, BC, Canada
| Here's Our Ax10 Scorpion Last edited by GH Racing; 02-09-2008 at 12:21 PM. |
02-02-2008, 06:23 AM | #231 |
Quarry Creeper Join Date: Dec 2007 Location: ON THE "EDGE"
here's mine after the build. no upgrades included. update to follow. I love this thing...first build so the body came out kinda crappy... |
02-04-2008, 04:32 PM | #232 |
RCC Addict Join Date: Oct 2005 Location: $t. Helen$, OR
02-04-2008, 10:00 PM | #233 |
Newbie Join Date: Oct 2005 Location: United States
My first real crawler....planned on a tuber, but never followed through. Has the usual stuff Stage 2 Kit Rooster crawler 55 package deanodized most of the green cut the foams blah...blah....blah...all the usual stuff. Tons of torque twist so I put in a rear aluminum plate and will be moving the mounts around to try to sort it out. 130W oil in the left rear shock HPI whites in front, yellows in back ....and an old traxxas radio setup I had not great pics yet, but it's 95% finished. Body still needs to get positioned and drilled. Hoping to make it to some gtg's soon for some crawling and feedback from others. Great site...always a blast to see what everyone else has got going on. |
02-05-2008, 11:15 PM | #234 |
Newbie Join Date: Nov 2006 Location: Fairfield, CA
| i'll add mine to the m |
02-06-2008, 08:05 PM | #235 |
Pebble Pounder Join Date: Jan 2008 Location: Rancho Cucamonga
after some more mods....... |
02-07-2008, 09:40 AM | #236 |
Pebble Pounder Join Date: Aug 2007 Location: Anaheim/Gardena, CA
02-08-2008, 07:57 PM | #237 |
RCC Addict Join Date: Jan 2008 Location: Mount Juliet
| My Betty
Spektrum DX 3.0 Traxxas XL5 ESC Novak 55T Brushed Motor TCS Bent Lower Links TCS 4 Link Plates F/R RC4wd R2D Transmission TCS Transmission DIG Servo Mount Spektrum Z590 DIG Servo Skyion 10KG Steering Servo TCS R2 Transmission Mount/Skid Plate TCS Medium Internal Springs Elite 6 Cell Split Pack on Front Axle TCS Axle Battery Plates Star Cut Foams |
02-08-2008, 09:41 PM | #238 |
02-10-2008, 12:37 PM | #239 |
Newbie Join Date: Oct 2007 Location: San Antonio
| Flat Betty
Finally got it together and working. Axial Tranny and Axles Blackjack Chassis Traxxas Hard Anodized 3.5 Shocks Custom male-female-male Pede shafts IMEX Rubicons soft 12 tooth pinion Lengthened uppers Bent stock lowers Novak Rooster Crawler Integy 55t TQ3 with 3rd channel mod 5.5oz lead in each front 2oz lead in each rear Starcut Axial foams TCS Axle plates 7 cell split pack Hitec HS5955 |
02-11-2008, 07:42 PM | #240 |
Newbie Join Date: Aug 2006 Location: Woodinville
| Red Bull Edge |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/axial-ax-10-scorpion/82403-axial-ax-10-picture-archive-no-talking.html | ||||
RE: Anyone Have a Mini MGT? | This thread | Refback | 10-05-2011 08:59 AM |
Axial AX-10 Picture archive - No talking - Similar Threads | ||||
1.9 scale rig picture archive - No talking | 123abc | 1.9 Scale Rigs | 2041 | 03-26-2024 03:44 AM |
Redcat Picture Archive - No talking | EeePee | Redcat Crawlers | 404 | 02-08-2024 06:23 PM |
1.5 scale picture archive - No talking | 1BadJeepBruiser | 1.5 Scale Rigs | 358 | 07-04-2023 03:22 PM |
SCX10 Picture Archive - No talking | BENDER | Axial SCX-10 | 3332 | 06-04-2023 05:40 PM |
Wraith Picture Archive - No talking | Harley | Axial Wraith | 1586 | 03-22-2023 11:32 AM |
