03-28-2013, 05:53 AM | #1 |
Pebble Pounder Join Date: Dec 2010 Location: Roanoke, VA
| I killed it....
The other day I was playing around in the snow a little and the Ridgecrest started smoking. It was the motor so I shut it down. When I turn it on now there is a faint hum but I do not hear the initial beeping that it typically would do. I'm assuming the motor is toast but does that sound like the ESC is toast as well?
03-28-2013, 02:45 PM | #2 |
Newbie Join Date: Oct 2012 Location: Reno
| Re: I killed it....
No beeps=no good. Try replacing the motor first because sometimes if the esc doesn't recognize there is a motor there, it won't sync up and won't operate.
03-28-2013, 04:13 PM | #3 |
| Re: I killed it....
I think the ESC might be good. I played around with it and the indicator lights do work. Green for throttle, red for brake, etc.. I'll order another motor and go from there.
03-28-2013, 07:02 PM | #4 |
| Re: I killed it....
Sounds like your ESC survived. You should be checking motor temps after each run. If you can't hold your finger on the can of the motor for about 5 seconds without burning yourself, you need to gear down. The stock 20/80, IIRC, gearing is fine for bashing around, but running the rig in wet sticky snow at WOT most the time is going to easily overheat the stock motor. Pick a motor that has an "open" endbell, meaning you can take it apart and clean/service the motor. |
03-29-2013, 06:49 AM | #5 |
| Re: I killed it....
It was a fluke for me to run in the snow, I don't really plan on doing it anymore. I picked up a stock motor for $15, it was fine for the general trail riding that I was doing previously. Hopefully it will get me back up and going.
04-04-2013, 04:55 AM | #6 |
| Re: I killed it....
Replaced the motor and all is well |
04-05-2013, 01:09 PM | #7 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
| Re: I killed it....
just a heads up in case anyone else sees this thread and wonders - with "castle creations" style ESCs, the beep doesnt come from the ESC, it actually comes from the motor magnets oscillating. SOOOO, what I'm saying is, dont blame the ESC when it doesnt beep, its typically a "normally" much cheaper motor condition.
I killed it.... - Similar Threads | ||||
I think I killed my HH TorqueMaster BR-XL | MetalNut | Axial Wraith | 20 | 02-10-2013 06:40 PM |
somebody killed bigfoot..... | ScaleReady | Chit Chat | 11 | 08-30-2012 10:34 AM |
You killed the FJ40 for this?! | microgoat | 1.9 Scale Rigs | 9 | 02-29-2012 07:21 PM |
killed 3 servos....now what? | GSRswapandslow | Electronics | 19 | 05-12-2009 08:44 PM |
Help!Help! I think I killed it | SouthernHighLife4x4 | General Crawlers | 11 | 06-04-2006 09:48 PM |
