12-28-2013, 02:33 PM | #1 |
Newbie Join Date: Dec 2006 Location: Carmichael
| Want to convert old AX10 to Deadbolt; what do I need to change?
Hi all. I have an AX10 that is very original, and I'd like to change the suspension and body mounts to be more like a Deadbolt, as I like the Deadbolt but I don't want to drop $300 on a new rig and I have too many RC cars as it is. Can I keep the original chassis and axles and swap out the suspension arms, or do I need to also swap out the axles as well? I'd also like to swap out the body to the Deadbolt or something similar. Will the Deadbolt body posts mount up to the original AX10 chassis? This isn't going to be a comp crawler, but something I can bash with the kids on the acreage around our house. Many thanks, Angelo |
12-28-2013, 05:29 PM | #2 |
Newbie Join Date: Dec 2013 Location: Cypress
| Re: Want to convert old AX10 to Deadbolt; what do I need to change?
Im not much help as Im a newbie, but I do have the Deadbolt and could take pictures and post them if that would help?
12-28-2013, 08:36 PM | #3 |
if I'm not mistaken, the old ax10 uses scx10 axles, whereas the deadbolt and ridgecrest use wraith axles
12-29-2013, 08:20 AM | #4 |
RCC Addict Join Date: Mar 2013 Location: Oklahoma City
Get a deadbolt body and mock it up....see how it works with the current chassis. Make it work! You'll be the first that, I know of, to do it.
12-29-2013, 12:21 PM | #5 |
Pebble Pounder Join Date: Dec 2011 Location: On, canada
mike flea is right, the axles are not as wide the chassis is different also. Nothing prevents you from making the deadbolt body fit on your ax10 though. As for wanting the drivetrain, i believe pretty much everything is different from both vehicles.
12-29-2013, 07:52 PM | #6 |
Rock Stacker Join Date: Dec 2011 Location: Gosport
You can definetly put the body on the old AX10, but the towers wont work off the the Deadbolt. Im sure you could create something to work for vertical body posts insted of horizontal.
02-08-2014, 12:03 AM | #7 |
Rock Stacker Join Date: Jan 2014 Location: Hamilton, Ontario, Canada
By the time you invest in all the parts...if possible, You might as well buy a deadbolt RTR Honeslty, dell your ax10 gen1 and get a deadbolt....that's the best thing to do. |
02-08-2014, 05:33 PM | #8 |
There is so many differences that you'd be better off selling your AX10 for say $150 and getting a $300 Deadbolt. You'd literally be time and money ahead.
02-09-2014, 05:58 AM | #9 |
Quarry Creeper Join Date: Jun 2007 Location: east michigan
I agree that you should sell the AX10 and buy a deadbolt. By the time you round up the parts to build you'll be over what it costs to buy as a RTR. If you choose to go costly route check e-bay and RPP hobby salvage yard.
02-09-2014, 07:30 PM | #10 |
Pebble Pounder Join Date: Nov 2010 Location: Simi Valley
The only thing that is the same on the ax10 scorpion and the ax10 ridgecrest/deadbolt is the transmission. So your best bet is just selling the original ax10 and buying a new one.
03-02-2014, 08:25 PM | #11 |
Quarry Creeper Join Date: Apr 2012 Location: lake wylie
As stated trans is the only thing the scorpion shares with the deadbolt. Easiest way to make a deadbolt is to buy a deadbolt. That being said there is nothing wrong with the scorpion with easy to buy or build mods it can hang easily with a deadbolt. I have a scorpion and my oldest daughter has a deadbolt and stock to stock they both need help. But my modified scorpion kicks her truck's butt in general crawling. The main place hers is better is handling at higher speeds than mine because the wider wheel track. Now mods to make a simular truck would be links, axles scx10 outputs for the trans, and wild boar shafts. Then you would have the same drive train and you would either have to make longer body side mounts or make top body mounts. You would be still stuck with the scorpion chassis. Last edited by slim_chance; 03-02-2014 at 08:35 PM. |
Want to convert old AX10 to Deadbolt; what do I need to change? - Similar Threads | ||||
Noon with ax10 deadbolt...upgrades? | johncraddock445 | Axial AX10 2nd-gen | 15 | 09-29-2014 02:32 PM |
Ax10 deadbolt chassis recommendations? | johncraddock445 | Axial AX10 2nd-gen | 6 | 12-04-2013 01:29 PM |
Axial AX10 Deadbolt | Lentsnh2012 | General Crawlers | 4 | 10-29-2013 12:10 PM |
Rylands new AX10 Deadbolt | jason | Videos! | 0 | 10-25-2013 11:33 AM |
