Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Heritage Crawlers > Axial AX10 2nd-gen
Thread: SWX "Blue inside" build
Old 02-14-2016, 12:37 AM   #1
Default SWX "Blue inside" build
Been planning and buying parts for a build for some time, so here we go.
SWX bender chassis
Wraith axles
STRC aluminum Chubs, knuckles, covers, diff holder, sterring, rear truss, bent links
Beef tubes front and rear
GPM wraith transmission case
These links wont work without shortening them so I have been working on my own.
Lordtuna is offline   Reply With Quote
Old 02-14-2016, 12:55 AM   #2
Default Re: SWX "Blue inside" build
Got my Dlux trusses in the mail the other day, and some 8/32 all thread and some Traxxas 5525 rod ends. Thanks again Eric, these trusses are sweet. Very easy to build as well.
Old 02-14-2016, 12:57 AM   #3
Front truss installed and front lower links done, sorry for the blurry pics.
Old 02-14-2016, 12:58 AM   #4
Front uppers. More to come tomorrow.
What do you people think?
Old 02-15-2016, 12:46 AM   #5
Got my original Losi XXXT shocks and mocked them up in the front and got some new gear in the mail. Knuckle weight holders from RCbros, and an ultimate wraith motor plate from supershafty.com. Both are very nice, ill get a pic of them installed tomorrow.
Old 02-15-2016, 08:48 AM   #6
Looks good I like it! Where did you get that chassis? My stock plastic one is starting to deform lol
Nalleywhacker is offline   Reply With Quote
Old 02-29-2016, 12:44 AM   #7
The chassis came from RC-RECYCLER.COM - Remote Control Cars & Parts, they get new stuff in all the time.
Old 02-29-2016, 05:42 PM   #8
Looking good hope to see you out at the P.A.R.C comp soon.
Diamond D is offline   Reply With Quote
Old 03-13-2016, 11:36 PM   #9
Got some work done. My HB Rover White dots and my RcBro's AX10 battery plate showed up. None of the screw holes line up for the battery plate in front since i ditched the stock truss and went with the Dlux fab front truss. So i mounted out back, not sure if ill use it. Looks good tho.
Old 03-14-2016, 12:45 AM   #10
Got my servo and ESC mocked up. I mounted the stock wraith servo plate vertically to the back of the Dlux truss servo mounts and then strapped my ESC to it. Not sure if Ill use the 1060WP or not, I have a new MMP in the box. Still need to order a servo. Sorry for the blurry pics.
Old 03-14-2016, 01:07 AM   #11
I had an idea. I really wanted to mount my battery up front so i went on a scavenger hunt in my garage.
I mounted servo mounts to the front of the truss.
Old 03-14-2016, 01:13 AM   #12
Found this brass plate in the garage, drilled and mounted it.
Old 03-14-2016, 01:20 AM   #13
What do you think of my battery plate? Too big, too tall? I need to weigh it.
Old 03-14-2016, 01:25 AM   #14
Here's an overall shot without the brass plate mounted, its getting there.
Old 05-21-2016, 06:08 AM   #15
Any updates?
Desmo is offline   Reply With Quote
Old 05-21-2016, 09:25 AM   #16
Looks good. I still like those SWX chassis. What wheelbase does that come out to?
kmnss is offline   Reply With Quote
Old 06-10-2016, 11:12 AM   #17
Hi, your Rig Looks like it's coming together nicely, just one question, why a Wraith gearbox???? I live in Germany and most all the shafty Guy's run homemade gearbox's made outta XR 10 gearboxs and that brass weight up that high might not help your sidehilling, but trying it out don't cost anything or?? Good Luck with your Build!!!!!
Phatz is offline   Reply With Quote
Old 06-12-2016, 02:09 PM   #18
Heres my Swx build. Wating for the electronics tray and a new servo.
Old 06-19-2016, 11:52 AM   #19
all that work supplied by a shitty sevo, last I used one of those it lasted 30s
crawlhog is offline   Reply With Quote
Old 06-19-2016, 05:36 PM   #20
onebullet's Avatar
they have one up now for 53, for that price you might as well just get a more modern chassis. The unstuck from krazed builds is only 60
onebullet is offline   Reply With Quote
SWX "Blue inside" build - Similar Threads
"SCREAMING BLUE" rock rod build spitfireat808 2.2 Scale Rigs 26 04-14-2015 08:04 AM
"Blue Crush" JK build jeeper03 2.2 Scale Rigs 50 12-04-2013 10:58 AM
Jkabee's "total noob" TJ build "this should be fun!" jkabee Axial SCX-10 128 03-24-2013 12:10 PM
Chaotic Crawlers "DEMON" build! aka "Kreacher" Mac10 EnRoute Berg 96 09-26-2010 01:49 PM
