01-31-2017, 12:16 AM | #1 |
Rock Stacker Join Date: Jan 2017 Location: Houston
| First Upgrade.?
Alright guys, so I'm new to the rc crawling world and just ordered an axial deadbolt and was wondering what the first mod should be that I do.? I keep hearing steering rod is really weak and flexible. What would be the best one but not super expensive.? Thanks Sent from my SAMSUNG-SM-G530AZ using Tapatalk |
01-31-2017, 11:46 AM | #2 |
Pebble Pounder Join Date: Sep 2014 Location: Hamilton Montana
| Re: First Upgrade.?
Steering links and clamping servo horn. Axial makes a good horn and STRC or vanquish makes good links. You are on the right path. You will need more upgrades but can wait til you break parts.
01-31-2017, 12:46 PM | #3 |
| Re: First Upgrade.?
Thanks for the info. I think steering links will be #1. As for the clamping servo why should I add or upgrade.? Sent from my SAMSUNG-SM-G530AZ using Tapatalk |
01-31-2017, 12:57 PM | #4 |
| Re: First Upgrade.?
I guess the steering servo horn is just flismy plastic like the steering links.? Sent from my SAMSUNG-SM-G530AZ using Tapatalk |
01-31-2017, 01:20 PM | #5 |
| Re: First Upgrade.?
Yes its plastic and it strips out the splines very quickly. The axial brand horn is up to serious abuse.
01-31-2017, 01:30 PM | #6 |
| Re: First Upgrade.?
Oh ok, i see what you mean now. Thanks Correll. Sent from my SAMSUNG-SM-G530AZ using Tapatalk |
01-31-2017, 01:40 PM | #7 |
| Re: First Upgrade.?
Am I correct about the deadbolt and the wraith being able to share the same steering links.? Sent from my SAMSUNG-SM-G530AZ using Tapatalk |
01-31-2017, 01:53 PM | #8 |
| Re: First Upgrade.?
That is correct, same as wraith AR60 axle. Not telling you to not post up with questions, but try the "search" function on this site up in the right corner. Or the moderators will get after you! Just some advise. Or post up in the newbie section. Again, not busting your balls! And add pics of your Deadbolt as you go.
01-31-2017, 01:55 PM | #9 |
| Re: First Upgrade.?
Ok, i thought so just wanted to double check. And yaa, i figured since I was already here and already in topic I would just ask you real quick. Lol. Thanks for the help though. Sent from my SAMSUNG-SM-G530AZ using Tapatalk |
02-01-2017, 11:37 AM | #10 |
| Re: First Upgrade.?
I think you may have an SCX10 version of the deadbolt. This is the AX10/deadbolt/ridgecrest section so I think my advice on steering links is wrong man sorry. I would ask the moderators to move this to the SCX10 section.
02-01-2017, 11:51 AM | #11 |
| Re: First Upgrade.?
Yes I believe it is the scx10 is the newer version the green one. Sent from my SAMSUNG-SM-G530AZ using Tapatalk |
First Upgrade.? - Similar Threads | ||||
What first upgrade? | NTA_Shawn | Vaterra Ascender | 10 | 02-12-2016 05:39 AM |
Next upgrade? | 95yjsahara | Axial Wraith | 12 | 03-18-2015 11:37 PM |
Best upgrade for $20? | flyingrc | Axial SCX-10 | 21 | 02-16-2012 08:01 AM |
You only get one upgrade!! | RickM | Losi Mini-Rock Crawler | 28 | 06-11-2010 10:51 PM |
no.1 best upgrade | caljones | Newbie General | 12 | 07-20-2009 01:00 PM |
