08-04-2017, 07:38 PM | #1 |
Pebble Pounder Join Date: Apr 2015 Location: New England
| do MIP 11116 driveshafts fit the deadbolt ax10?
Hi guys, I still have the stock driveshafts on my ax10 deadbolt, I don't wanna be rock crawling and have them crumble to bits when I am crawling I have had them for 1 year and a half, so I mean I read that the wraith driveshafts are the same as the deadbolt ax10 and ridgecrest, since the wraith has a longer output on the rear and a longer chassis and the rear links are the same for the wraith and ridgecrest, I read the driveshafts are exactly the same... So the MIP 11116 driveshafts will fit I think after reading a thread on rccrawler... Thanks -Spence Last edited by Spence; 08-04-2017 at 07:40 PM. |
08-04-2017, 11:01 PM | #2 | |
Quarry Creeper Join Date: Dec 2016 Location: Cawston, British Columbia, Canada
| Re: do MIP 11116 driveshafts fit the deadbolt ax10? Quote:
But then again, people I know using MIPs swear by them. Only down side they say is the added weight compared to the WB8s. | |
08-05-2017, 07:30 AM | #3 |
Well, I guess if they don't fit I can always return them...
08-05-2017, 07:03 PM | #4 |
Anything guys? I guess I am taking one for the team to see if they fit... I found junfac axles for the wraith for a length comparison, although the junfacs aren't as good as MIP's, I really wished MIP would put a length on their axles assembled, regardless I can fix them with $20 worth of the shorter stub axle outdrives if they don't fit. Funny stuff, axial wants to make a killing of of you with the wb8 driveshafts to fully rebuild them it costs more than a set of MIP's at $14 per single outdrive! Well, comparing to the junfacs, they are the same length as the stock long axle tubes with ends that fit my rig, I hope they fit, just compared to the MIP's that don't have a length in the world...
08-08-2017, 07:05 PM | #5 |
I bought Junfac's for my Ridgecrest 4 yrs ago and never looked back. Used the Ridgecrest drivetrain for my 1/6, 14.5 lb Jeep, and knock-on-wood, haven't had any issues.
08-09-2017, 11:41 AM | #6 |
Well guys thanks for not helping guide me, they barely fit, its the extra long outdrive on one side that is for the wraith... This can be fixed for $20 by buying shorter MIP outdrives, but wraith MIP's do fit the deadbolt ax10, but you will need to remove one of the upper link mounts to install them since its a little tight... Hey I came up with a solution lol, I found some plastic propeller adapter rings and since I made custom lower links, I just made the lower links slightly longer Cost me zero$
do MIP 11116 driveshafts fit the deadbolt ax10? - Similar Threads | ||||
which MIP driveshafts for AX10 deadbolt? | ussprinceton2004 | Axial AX10 2nd-gen | 2 | 07-07-2016 01:13 PM |
MIP install question Kit 11116 (driveshafts) | IPT | Axial Wraith | 11 | 06-06-2014 10:53 AM |
Which MIP stub axle will fit MIP AX10 center driveline cups ?? | sweli | General Crawlers | 2 | 11-08-2011 06:59 PM |
